Question about Garden
I have a simplicity zr-38 mower with kohler 17.5 hp motor last time i mowed it died but started back up finished mowing went to start it this week and wouldnt start and discovered it has no spark could this be control module went bad
    President:
  • 1,902 Answers
That sounds like your issue exatly. That would be the only thing that would let it die, re fire, then not restart again. If it was a fuel issue it would have still restarted, a spark issue it would still have started.
Posted on May 06, 2010
Why is my Kohler courage18 motor leaking oil from bottom of motor
When you over fill an engine it will make the crankshaft swim and splash in the oil that has too high a level in the crankcase. It will increase the pressure in the crankcase and then it comes out the crankshaft seals and out the crankcase breather. Hope this helps, plese post solved on fixya.com. So I get credit for a solved problem if it does.
Apr 25, 2014 | Simplicity Regent 19.5/38
After mowing I changed my oil last week. This week I mowed a side lot w/out any problem. Started a 2nd lot and the mower died. I noticed the motor was running hot, so I let it cool down. After cool down...
Did you try jumping it or turning the motor by hand to see if it ceased? Is it possible your battery went dead. Also if it was overheating, check to make sure you used the right oil, and that the cooling fins on the motor are not clogged with grass or other debris.
Sep 08, 2013 | John Deere L100 Series
My mower will die everytime i engage the blades to mow
Check to see if one of your deck spindles isn't seized. Disengage the blades and turn each blade to see if its free. Sounds like either a spindle is seized or your electric clutch on the motor has a problem.
Jul 20, 2013 | Yard Man Yardman Riding Lawn Mower 38in...
Simplicity landlord water cooled 17 hp kohler runs rough.
are you going threw coolant like the head gasket to be blown?is that engine old enough to have points and a condenser and there breaking down
May 21, 2012 | Garden
Simplicity zero turn electrical problems
charge the battery not hooked up to the mower let it sit overnight and try again the battery might just be died they only last a couple years put a volt meter on the battery when off then start it and watch the battery voltage should be around 14 volts running the pto clutch draws the most thats why it shuts off first the ign doesn't take any the carb needs very little
Apr 22, 2012 | Garden
My cub cadet won't stay running. I can mow for a will and it just sputters, and or dies. I let it cool off for about 10 minutes.It starts right up after it cools. It also starts to smoke when it gets...
Similar issue - buddies CubCadet with Kohler Courage 22 would not stay running. Turned out the coils got rusty where it interacts with flywheel. cleaned the contacts (be careful to shim for proper spacing) and ran like a top.
May 29, 2010 | Toro 42 In Deck 19 Hp Kohler Courage Twin...
I have a troy bilt riding mower, 6 years old, 26
many of these units use the starter motor as the generator to re-charge battery. check voltage regulator & wiring.
Sep 28, 2009 | Garden
Mower mows graet for 30 mins then starts to load
Yes you need to replace the needle and set in the carb.
Aug 23, 2009 | Poulan 38-Inch Steel Deck 15.5 HP Briggs &...
Husqvarna YTH2348 drive belt slipping
Is there the proper amount of tension on the belt?Look in your owner's manual to find out how to adjust the tension.
Aug 02, 2009 | Garden
LTX1000 42" 18HP Kohler - Blowing fuse after 2-4 min mowing.
sounds as though you are on the right track
but be sure to check the wiring directly from the electric clutch on the front of the motor back to the switch
a wire could be pinched in the frame and shorting out intermittingly
look around and find those wires and move them around and look for chaffing and tightness
and what you could also do is to unhook the clutch at the connection to it at the front of the motor and engage switch and ride around and see if fuse blows and if not you may have an electric clutch issue
Jun 07, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Garden Logo
145 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
