Question about Alpine Car Audio & Video
Alpine cde-9870 non-ipod mp3 player AUX FUNCTION
Got an aftermarket cable for cde-9870 ipod connection cable to use with a different mp3 player, which plugs into the headphone jack....how do i get this to work? or how do i turn on the aux source function?
When you press the SOURCE/( ' ) button and select iPod as the source, make sure you turn on AUX+ so that the external device is used as the source. AUX+ is turned off when you want to use an iPod with this head unit.
I don't know why some people thought to answer your question with an answer based on a different model.
Posted on Sep 13, 2012
KaeZoo
  • 156 Answers
SOURCE: auxilary RCA inputs have no volume control
Your problem stems from the fact that the CDA-7892 is not equipped with an RCA aux-input jack. If you're plugged into RCA connectors at the back of the head unit, they're outputs, not inputs. The sound you hear is just feeding back through the outputs and into the head unit's amplifier. If you want to play your iPod through this head unit, you need to purchase either the auxiliary input adapter (KCA-121B) or iPod adapter (KCA-420i).
Posted on Mar 15, 2007
SOURCE: DEH 7700 MP Pioneer in
i need help
im trying to hook up a pioneer in my car but i cant figure out the wires
Posted on Nov 05, 2009
SOURCE: Accessing aux port on Alpine CDE 9881
If you happen to have the tool which allows you to remove your head unit from the dash use it. If not go to crutchfield.com and get one it's useful for any audio enthusiast. Once you have the tool pull the head unit out on the back of the unit there is a cable that is black with a blue connector tip. This is what you plug your cable that you got from your audio dealer into. As for making the cable accesible you may have to drill a hole in your dash or run the wire around and out the glovebox which is also common and suggested for your particular car.
Posted on Jun 11, 2009
  • 166 Answers
SOURCE: how do you set the clock on a cde-9870
Hello there,
This is from Page 7 of the Owners Manual, found through Alpine's site.
1 Press and hold MUTE/SETUP for at least 2 seconds
to activate the SETUP mode.
2 Press or to select the CLOCK ADJ mode, and
then press //ENT.
The time indication will blink.
3 Press or to adjust the hours while the time
indication is blinking.
4 When the hour has been adjusted, press //ENT.
5 Press or to adjust the minutes while the time
6 Press and hold MUTE/SETUP for at least 2 seconds
to return to normal mode.
• To synchronize the clock to another clock/watch or radio time
announcement, press and hold //ENT for at least 2 seconds
after setting the “hour.” Minutes will reset to “00”. If the display
shows over “30” minutes when you do this, the time will advance one
hour.
• Pressing AUDIO/RTN will return to the previous mode.
• If no operation is performed for 60 seconds, the unit will return to
normal mode automatically.
Posted on Jul 12, 2010
SOURCE: Ok...I have an Alpine CDE-9845
You will first need an audio cable that has a 3.5mm male end on both sides of the cable.
You will plug in one end into your mp3 player, and the other end into the 3.5mm audio jack on the front of your cd player. On rare occasions its on the back of the cd player.
Then instead of putting your cd player on the radio, or cd, the other option will be Aux. Start your mp3 player up and you should be able to hear it on your car audio system.
This is the standard setup for running an mp3 player through your car stereo. Thank you for choosing Fixya!
-Daniel
Posted on Aug 10, 2010
Where do you plug mp3 or ipod connections
Unfortunately your deck does not have any ports for ipod or mp3 players. If you would like to connect such items you need to upgrade. Here is the link that has your deck specifications
http://www.crutchfield.com/p_500CDE9843/Alpine-CDE-9843.html?search=Alpine+CDE9843&tp=5684&tab=features_and_specs
I am not a fan of CDE line, you are better off with CDA line.
Sep 19, 2010 | Alpine CDE-9843 CD Player
Ok...I have an Alpine CDE-9845 and i wish to play my ipod by using an aux cord but i have no clue where to plug it in at
-Daniel
Aug 10, 2010 | Alpine CDE-9845 CD Player
How do you "Set AUX + SETUP to OFF" as it says you should do to connect an iPod to the Alpine CDE-9872 Receiver? Page 17 of Users Manual.
By re-reading the complete User's Manual (which I downloaded for free). The directions on how to set AUX + SETUP to OFF were contained in this manual. I had been looking at the Quick Reference Guide (not the complete Manual) which came with the receiver.
Jan 07, 2010 | Alpine CDE-9872 Car CD/ MP3 Player
How can i use mp3 player on cde 9870
it may need an adaptor , possibly used in the aux rcas if the unit has them . i have seen them on ebay
Dec 01, 2009 | Alpine CDE-9874 Car CD/ MP3 Player
How do i connect and play my ipod through my cde-9843
look at the back have an aux input if not you have to get a fm modulator and let some one put in for you
Jun 22, 2009 | Alpine CDE-9843 CD Player
AUX to work
Hello alex_maya21,
The AUX input on your CDE-9845 is on the back of the receiver. To use it, you need a cable with the appropriate connectors on each end. The receiver end needs to be a standard "mini plug" and the device end needs to match the output connector on your mp3 or iPod. There are many commercially available cables that you can plug in and run the device end under the dash to a convenient location. Almost any car audio retailer will have the correct cable or you can order one online from www.crutchfield.com.
Hope this helps.
Jun 21, 2009 | Alpine CDE-9845 CD Player
How to use MP3 on it
That model has a front-auxillary port on it.
Just purchase a cable online (http://www.yourcablestore.com/6-Foot-25mm-Stereo-Headphone-Cable-Male-Male_p_76.html) or in Walmart, BestBuy, etc.
When you get it, hook one end into the stereo and the other end to your MP3 player.
Set the Aux as the source and press Play on the MP3 player.
Apr 13, 2009 | Alpine CDE-9874 Car CD/ MP3 Player
I have a CDE-9872 and it wont pick up my ipod touch
Add Alpine's optional "Full Speed" connection cable and you'll be able to use the CDE-9872 to control your iPod. -Crutchfields website
This is compatible with first and second generation iPods touch.
fyi- if you have a mini-stereo aux in jack on the deck you can connect a ipod touch compatible mini stereo cable to the earphone jack of your ipod.
Dec 28, 2008 | Alpine CDE-9872 Car CD/ MP3 Player
Alpine CDE-7858 external input?
yes there is an adapter cable made for this search alpine aux adapter on ebay they run aprox $30 it will plug into cable on back and give you 2 rca inputs to use for ipod and such...
Nov 23, 2008 | Alpine CDE-7858 CD Player
Car Audio & Video Logo
1,214 people viewed this question
Top Alpine Car Audio & Video Experts
xxxxxx xxx
Tygh Duval
Tygh Duval
Jaime Hernandez
Are you an Alpine Car Audio and Video Expert? Answer questions, earn points and help others
