Question about Kenmore Dryers
Kenmore 90 series electric dryer does not turn on. Once the start switch is pressed, you can hear an electric hum and then goes out after about 6 seconds like it timed out.
  • 7 Answers
SOURCE: Kenmore Dryer 90 Series will start but suddenly stop...
what starts and stops? the entire dryer or maybe the drum? Do you do anything to make it restart other than pushing the start button? This initially sounds like a temperature switch is opening and resetting after it cools. If you can describe the problem a little more in detail it would help.
Posted on Jan 27, 2008
  • 1073 Answers
SOURCE: Electric Dryer Starts, runs, warms, stops (Kenmore series 90)
you have a bad motor that needs to be replaced
Posted on May 06, 2008
kachbibi1
  • 979 Answers
SOURCE: Kenmore 90 series electric dryer blowing cold air only
1st check the breakers
2nd check wiring in back to see connections are secure.
3rd check element. It would be burned in two.
4th check thermal overload switch which is located underneath top of dryer. Easy to remove top. Probably 4-6 screws.
Posted on Jan 15, 2009
TheMobilian
  • 8220 Answers
SOURCE: electric kenmore 90 series working but no heat?
Most likely that is the heat element. Some dryers have the element in the front but most of the time yours can be accessed from the rear.
Posted on May 10, 2009
  • 66 Answers
SOURCE: press the start button on dryer, it hums but wont
Sounds like a weak motor. You'll have to get a new motor installed. They are fairly inexpensive and easy to install yourself on that type of machine if you are handy. Motor is located in the bottom right of the machine, attached to the drum belt through a small pulley underneath the drum next to the motor.
Posted on Dec 27, 2009
Kenmore Dryer Series 90 momentarily started then stopped. I have an electrical meter. What could cause it?
Electric dryer no start does nothing
Check dryer Terminal block prongs both outside prongs should give combined 220, and 110 each if u check 1 outside & 1 center (ground) prong. Also check house electrical outlet for full voltage.
CHECK THERMAL SHUT OFF THERMOSTAT USUALLY LOCATED ON THE BLOWER. for OHMS or resistance with a meter. Should show a closed circuit. Ohms WHEN THIS FUSE BLOWS IT WILL SHUT DOWN EVERYTHING.
NEXT Test the PUSH start switch with meter for OHMS. Should show OHMS when pushed in or on start, and no ohms or infinity when in off position.
If you hear a humming/clicking sound from motor area you more than likely have a bad motor.
Try this test out to see if u have weak windings or relay/capacitor on motor.
Open the dryer door and turn by hand the drum while machine is on ON position. And you or someone else presses the door engagement switch in. If it starts up then u have bad windings
Another thing to check is the belt safety switch. With a multi meter.
Especially if u just replaced the belt. The belt safety switch is attached to the Tensioner and motor. IT LOOKS LIKE A DOOR SWITCH SOMEWHAT a little black pc of plastic with 2 prongs going into it. Sits at bottom of motor. Under the Tensioner. Attach meter clips to the 2 prongs on switch, Then when the little white push button is pressed in it should show continuity and none when released.
Lastly check ut push start button for continuity with a meter when pushed in the on position, it may have gone bad.
https://www.youtube.com/watch?v=sTRP6kHqAFs
Jul 08, 2014 | Kenmore Dryers
Need help with gas dryer Kenmore 90 series serial
Check the lint caught in the exhaust vents. If it is clear replace the spark ignitor if no click is hear upon starting up
May 14, 2010 | Kenmore 73952 Gas Dryer
Press the start button on dryer, it hums but wont turn. With 2 people pressed the start button again, held the door switch, reached in turned the drum, it hummed stopped humming then no more nothing....
Dec 27, 2009 | Dryers
We have a kenmore 90 series dryer. Probably 6-8 years old. When you press the start button it makes a humming noise but won't start. Any ideas what it might be?
chance it could be the motor is to weak to turn the drum or it is bound up by the belt or bad rollers check breakers if half tripped this can keep motor from fully engaging
Nov 13, 2009 | Dryers
Kenmore 90 Series Model 11060912990 Dryer won't start
check motor (you have 2.4 Kohm ) very high read
for motor must be lower.Check capacitor if hawe.
Feb 15, 2009 | Kenmore 62602 Electric Dryer
Jan 15, 2009 | Zanussi TC7102W Electric Dryer
Kenmore 90 series won't start timer ticks
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Dec 03, 2008 | Kenmore Elite HE4 Electric Dryer
Kenmore 90 Series Electric Dryer will not run
chech to see if your belt is broken. It may have a belt switch
Oct 28, 2008 | Kenmore 62602 Electric Dryer
Dryers Logo
164 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
