Question about KitchenAid Architect 24.5 Cu. Ft. Counter-Depth Side-by-Side Refrigerator - Stainless-Steel
Cleaned the refrig. today, didn't turn it off, cleaned the coils, now the temp. won't go down. It's 50+ degrees. What did I do?
5 Suggested Answers
  • 323 Answers
SOURCE: My Call Service light is on and the refrig. keeps beeping
unplug unit overnight and let defrost, return air ducts are iced up
Posted on Oct 31, 2009
  • 84 Answers
SOURCE: The refridgerator will not cool down past 49
These are the condensing coils. Most of the time lint clogging them up causes the Refrigerator not to cool properly. You should have a fan on the back pulling air through the coils. If this is all working, I need to know if the evaporator coil (the one that gets cold) is frozen up.
Posted on Mar 11, 2010
kel1guy2002
  • 3740 Answers
SOURCE: my refrigator temp will not
It appears the model listed on the post is not the same as your model because the model listed has a mechanical temp control that is item 5 of this link:
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5132929&diagram_id=28175033#d28175033
I am assuming you have a different Kitchen-Aid unit that has thermistor controlled temps. Given that assumption.....this is probably way to much information but you need to understand how your unit works:
TEMPERATURE CONTROL
The electronic control checks the resistance of
the thermistors, and compares it to both the
customer temperature settings and the last
thermistor reading taken. This information is
used to determine when to begin a cooling
operation, and if a change is necessary in the
damper setting, or the evaporator fan or compressor
speed.
When a warm refrigerator is first put into a
cooling mode, the air door partially opens, and
the compressor and evaporator fan motors
start to run at maximum rpm. The air door will
gradually move to its fully open position.
As the actual temperature in the refrigerator
nears the selected temperature setting, the
electronic control compares the temperatures
in both compartments. The compartment that
has the greatest need for cooling, will control
the speed of the evaporator fan motor.
Freezer Temperature Control -
Temperature Increasing
When the freezer calls for cooling, the compressor
begins to run at minimum rpm, (see the
chart on page 3-3), and the evaporator fan
begins to run at 2000 rpm. The compressor
and evaporator speeds are continuously updated.
Speed changes are made based on:
• The difference between the actual temperature
and the selected temperature settings.
• The rate of temperature change.
If the temperature increases 4°F above the
selected temperature setting, the evaporator
fan speed begins to gradually increase. The
evaporator fan motor reaches the maximum
speed of 3000 rpm at 5°F above the selected
temperature setting, and the compressor speed
begins to gradually increase. A maximum compressor
speed of 4500 rpm will be reached at
9°F above the selected temperature setting.
Temperature Decreasing
When the freezer temperature begins to decrease,
the process will reverse. The compressor
speed decreases, followed by the evaporator
fan speed.
Refrigerator Temperature Control -
When the refrigerator calls for cooling while
the freezer is satisfied, the air door begins to
open, and the evaporator fan starts to run at
minimum speed. If the temperature continues
to rise, the air door will continue to open. If the
temperature continues to rise after the air door
is fully open, the evaporator fan speed will
gradually increase to a maximum of 3000 rpm.
If the temperature continues to rise, the compressor
starts to run, or if it has already been
running, begins to increase in speed.
As the refrigerator temperature approaches the
selected setting, the control compares the temperatures
in both compartments to determine
which compartment will control the fan speed.
If the freezer is further from the selected temperature
setting, it controls the fan speed, and
the air door begins to close, thus reducing the
airflow to the refrigerator.
If the freezer is satisfied, the air door remains
open, and the fan speed begins to decrease.
When the selected temperature setting is
reached, the air door closes.
Here is the bottom line.... the termperatures are controlled by thermistors in the freezer and refrigerator compartments. Most likely you have a thermistor problem. The freezer thermistor is on the left wall near the back and the refrigerator compartment thermistor is on the back panel left side. They are accessed by removing the single mounting screw and tilting the cover off with the retained thermistor. The thermistor connectors are directly behind the cover. The resistance of the thermistors should be (in Ohms)
8750 at 32 deg
10,400 - 11000 at 25 deg
6800 - 7220 at 40 deg.
If you have no resistance or the resistance readings are way off and / or shorted the thermistor is bad.
If it checks good:
NOTE: If the resistance of the thermistor(s)
was normal, perform the following voltage test.
1. Set the voltmeter to read a maximum
voltage of 10 volts DC.
2. Connect power to the refrigerator and
allow it to enter the "cooling" mode.
3. With the thermistor disconnected and the
refrigerator in the cooling mode, touch the
voltmeter test probes to the thermistor
main harness connector pins. The meter
should indicate approximately 5 volts DC.
If the voltage was not present, check for a
thermistor output at the main control board.
If it fails this test the problem is most likely the control board.
Check them out and let me know what you found out.
If I totally missed the mark here please respond with a good model number so I can go back and start all over.
Thank for choosing FixYa,
Kelly
Posted on Aug 04, 2011
  • 207 Answers
SOURCE: I have a Kitchenaid S x S KSCS25INSS00
Try replacing the circulating fan first. If it's not turning, it's more than likely bad. However, the fan might not be your only problem. The problem may lie with the icemaker. The icemaker is essentially the brain of the unit. It tells when to cool, when to defrost and when to maintain temp. Your icemaker may be stuck in defrost mode.
Posted on Sep 04, 2011
I have Kitchen Aid french door fridge with large temp fluctuation. Please help
Clean your coils first, if they are dirty from dog hair or lint in general it will overheat compressor and cause temps to fluctuate
Oct 17, 2016 | Refrigerators
Fridge and freezer at 50 degrees with settings on max cold. I can hear compressor cycling and all power is on. Suggestions?
Your Refrig/freezer should be set as follows:
Refrigerators: 36 to 40 degrees. Ideal temp is 37 Fahrenheit. Note: A temp above 42 degrees promotes bacteria.
Freezer: temp should be -5 to 6 degrees Fahrenheit. Ideal temp is 0 degrees.
Then check the door seals around the edges to see if any splits, tears or cracks have messed up the seal. This will cause your compressor to constantly run as it's trying to cool off the warm house is being sucked into the freezer (or Refrig). A sure sign the door seals are damaged is lots of ice in the freezer door area or water pooling in the bottom area of the refrigerator.
Wait about 4 hrs after you readjusted the Refrigerator/Freezer settings so everything settles down. If you still have problems then the coolant may need to be serviced (topped off) or the motor serviced/checked.
Don't procrastinate because a water heater and Refrig/freezer are the 2 largest energy users in your home- they run 24 hrs a day.
Hope this helps...
Nov 23, 2012 | Whirlpool 25.6 cu. ft. Side-by-Side...
Kenmore Refrig Model 596.50699000, not getting cold as should. Frost forming on top row of coils only?????
Clean the condenser. Probably below refrig. Reset all settings to mid point and check to see if you have a restricted drain tube.
Jun 17, 2012 | Kenmore Side by Side Refrigerator
I have a Kitchenaid S x S KSCS25INSS00 refrig/freezer. We lost power for 30 hours, it worked fine before the outage, now it won't cool the fridge below 48 degrees, or the freezer below 43 degrees. ...
Sep 04, 2011 | KitchenAid Superba Architect KSCS25INSS...
My refrig and freezer wasn't working good, i replaced the heater that goes underneath the coils. now my problem is the freezer is on 0 degrees and the refrig is on 60 degrees, i noticed the flap that...
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Aug 28, 2011 | Refrigerators
The ice maker in my Whirlpool Gold refrigerator has stopped making ice. There is ice in the tray, but it won't empty itself.
If the " tray " you are refering to , is the ice maker mold , then clean the coils in the front , under the refrig ( condensor coils ) . Also check the fan behind the refrig , to make sure it is working . An ice maker has to be 5 degrees to cycle . Bothe the coils and the fan , have to be checked to be sure the freezer is at the correct temp for the ice maker to opperate properly . If both are ok , then replace the ice maker .
Sep 23, 2010 | Whirlpool Refrigerators
Icemaker has ice in icemaker, but does not drop it and refill to make new ice. What do I do?
Check the coils under the refrig , to make sure they are clean . If not clean , then please clean , and wait about a day . If still no ice , replace the ice maker . An ice maker will not harvest ( dump ) , unless it is 5 degrees . Dirty coils will make a freezer temp anywhere from 10 - 18 degrees , yet food will still be frozen , but ice maker will not work .
Sep 26, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Top mounted freezer on refrigerator not working
Move the refrigerator to a room that is at least 50 degrees F.
Temps on most refrigerators are regulated by the fresh foods temp. If your garage is let's say 35 degrees, the fresh foods temp will most likely never raise enough to turn the refrigerator on. With the refrigerator never running, the freezer compartment will warm to 35 degrees, resulting in everything melting. Even if garage is a bit warmer, say 45, the refrig will not run long enough for the freezer to maintain a low enough temperture. If the garage temp falls to below freezing, say 20 degrees, the food in the fresh foods compartment will freeze. (outdoor beverage dispensers have internal heaters to prevent product from freezing !) Please don't rate this if not a Fix-Ya for you, as anything else lowers my score.
Jan 22, 2009 | Frigidaire 5 cu. ft. / 142 liter Chest...
Temperature 94 in refrig. normal in freezer
Check to see if refrigerator door is lower than freezer door. If so remove toe panel, (bottom front). Under refrigerator door hinge at bottom right is adjuster for door. Adjust upward so door is even. On some models when door is too low it causes light to stay on some times, raising ref. temps.
Nov 04, 2007 | GE (PSS26MSRSS) Side by Side Refrigerator
KitchenAid Architect 24.5 Cu. Ft. Counter-Depth Side-by-Side Refrigerator - Stainless-Steel Logo
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
mike cooper
Todd Arndt
Todd Arndt
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
