I have a Whirlpool Cabrio washer and have discovered that a large item of clothing is stuck between the baskets of the washer. As a result, the basket will not rotate. Any ideas how we can get the item out of the washer. Thanks.
  • 3 more comments
  • lbel76 May 06, 2010
    Thank you, thank you! Can you post it here? My husband has tried with no luck to remove the item.
    I'm not sure how this works. If I accept your solution can you still reply to me?
    I'm really not sure how this allworks.
    Thank you so much. We just pulled my husbands boxers from the basket!
    FixallPhil....not sure why it says I didn't accept your solution. Your pictures were what sealed the deal. Thanks again!
    President:
  • 949 Answers
This may be a repeat, sorry but my first response to you may not have gone through, I have a service manual I can email you with details on how to remove the basket if you wish. Or I can cut and paste the pages here, your call.
Thanks
Posted on May 06, 2010
  • 3 more comments
  • Philip May 06, 2010
    Yes, it will take a couple of pictures so if my post here ends check again in a couple minutes for the next batch.
    I sent 3 pictures with text on them, Let me know if these will work I am not going anywhere I promise to stay here and help you fix this.
    Sorry that what I sent did not help, I just got an email that says you did not accept my assistance, I apologize for not meeting your expectations. If there is anything I can do I will be here.
    FixAllPhil
    That is fantastic!!!! Great job!
    It changed on my end now. Thanks!
    President:
  • 1,382 Answers
The agitator's movement back and forth is important for the cleaning of your laundry. If it doesn't function properly, your clothes won't be as clean as possible. If your agitator does not move, moves only in one direction or its movement is very weak, you will probably need to remove the agitator. Furthermore, in order to inspect the tub for leaks, the clutch assembly, the splines, or to remove the spin drum, you will have to remove the agitator. Hi,
The agitator is fastened to the agitator shaft and its movement is driven either by splines or a simple clutch assembly. The splines are usually plastic or rubber nubs on a cylinder that fits over the agitator shaft. If the nubs wear down, the shaft will not turn properly or it will turn weakly. If the agitator is moving in only one direction, the likely cause is the clutch assembly. The clutch has dogs that depress and pop up with each turn. If those dogs are worn, they will not engage properly and the agitator will turn only in one direction. Various makes and models differ in how the agitator is removed. In some newer models, the agitator just lifts straight up and out. However, in most models you will have to do some combination of the following steps. First remove the fabric softener dispenser, if any. It should either lift or screw off. Next remove the cap. It may lift off, screw off or failing that, it may need to be pried off. Beneath the cap some agitators are secured in place by a bolt. Use a socket wrench with an extension to remove that bolt. Some Maytags may have a screw near to the bottom of the agitator post that must be removed. Now try to lift the agitator straight up, possibly with a little back and forth rocking motion. Use caution when pulling, the agitator may come loose suddenly and hit you in the face or send you flying backward. If the agitator is particularly stubborn, you can loop some rope under one side of the agitator at the bottom and then up over a broom handle. Now loop it again under the other side of the agitator and back up to the broom. Brace one end of the broom handle against the top of the washer and lift up on the other end. Double check that you have removed anything that may be securing the agitator in place. Do not use too much force or you may damage the washer cabinet, agitator or injure yourself.
Whirlpool Cabrio gets unbalanced load at 7 minutes
Make sure load is properly sorted with like materials and paired up, do not mix things like towels with pants or shirts all together as different items absorb more water then others and can create unbalance when trying to enter final spin. If issue continues, it is very possible and item of clothing may have found itself stuck between spin basket and outer tub. This is very likely scenario due to design of this washer. If that is the case, spin basket must be removed then remove clothing to resolve issues.
Jun 02, 2014 | Whirlpool WTW6400SW Cabrio Washer
I need the service manual for a Whirlpool Cabrio WTW6600SW2 to find out what the code F50 mean and how to replace RPS sensor.
The F50 error code indicates that the RPS (rotor position sensor) detects no motor rotation. Check to see if the basket spins freely. If not, you could have an item caught between the outer tub and the inner spin basket. A toy or other item underneath the washer could also prevent the basket from spinning and would result in this F50 code.
If the basket spins freely, you could have a wiring failure that would prevent the motor from spinning.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question#$%^
Jun 29, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
ERROR MESSAGE F50
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question%^&*(
Jun 14, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
My Whirlpool Cabrio WTW6400SW2 has a F50 error. I
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question$%^&
May 10, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
I am trying to wash clothes with my whirlpool cabrio he but it keeps stopping and saying f50. what should i do?
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question!@#$
Apr 06, 2010 | Whirlpool Ultimate Care II LSQ9564J Top...
My Whirlpool Cabrio 6600sw2 has lots of problems, it stops and flashes F50 over and over again, it also flashes many of the other codes, it doesn't fill with enough water and it is not washing the clothes...
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question****
Jan 03, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
F50 Error Code on Whirlpool Cabrio Washer
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question&&&&
Aug 23, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Whirlpool Cabrio Model WTW6400SW2 Fault F50, Motor Control board shows no sign of any damage. Could mu problem be the RPS sensor? Motor simply wont turn
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question^^^^
Aug 04, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Whirlpool Cabrio
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question%%%%
Jul 10, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Whirlpool cabrio washer keeps flashing code F50
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question$$$$
Jan 16, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Washing Machines Logo
43 people viewed this question
Top Washing Machines Experts
