Question about Asus Eee Pc 701Sd Notebook
I have just purchased an EEEPC701SD with linux installed. I am new to linux but enjoy the challenge. I have been trying to connect to my dialup isp account. I have used the network connection manager and set up a profile - it works on my windows machine. When I run connect I get "No modem or modem driver not working" I have found out from searching the net that the internal modem is not factory installed and the manual seems to assume that it is. Can I get an appropriate driver for the internal modem (download with my windows machine) and transfer via usb flash drive. As yet I only have the "easy" desktop so I assume that I will install the driver from the console so if you can could you give me instruction of exactlt what to type. Regards Brian from Tasmania
  • bloosey99 May 06, 2010
    Thanks
    Seems strange but I am sure you are right. If I can get a usb modem can you give me any advice regarding what I should look for in order for me to run it from linux? Also is it possible to download repositories on another system and then transfer them over via usb flash drive.
  • ASUS Master
  • 13,433 Answers
Hello
Your Asus EEPC701SD does not contain modem hardware. On the side you do have a modem port (non-functional, empty). So there is no driver or program to use this laptop as a modem, as there is none.
I checked with Asus, there are no drivers for this device, everything is already included in the pre-installed linux and the cd that comes with it.
So the port is there but there is no hardware.
I believe you can purchase a USB modem, but I can't guarantee its function with linux.
Posted on May 06, 2010
  • Ekse May 06, 2010
    Don't you have any other options for internet access? dial up is quite costly, I remember around 10 years ago when I was using dial up.... the bill one month was huge...
  • Ekse May 09, 2010
I have a netzero dialup and when i try to establish a connection i get "dialing, redialing in 5 seconds, dialing..., unable to establish a connection" How do i establish a connection?
If you turn your sound up on the computer, do you hear a dial tone? Does it then begin dialing? If not you may have a bad modem. Try dialing the ISP's number with your phone, it should dial in and you should hear various beeps and so on, if not the ISP is down.
Dec 24, 2014 | Compaq Presario 2100U Notebook
Belkin Wireless router driver for Ubuntu
No drivers are required since routers are not installed but are administered. Connect the ISP modem to main uplink port. Then connect pc to any other port. Done!
HTML Browser based User Interface (http://192.168.2.1) Default is no user. No password. Hold the reset till it cycles in the back to clear any custom settings. From here use the firmware update, but make a backup before actual update.
Oct 24, 2012 | Belkin F5D8236-4 N WIRELESS ROUTER4PORT...
How to do dialup connection with E627-5279
You need a modem and the software installed for that modem. Then you will need some software that will actually "use" the modem, such as a FAX software package if you're going to FAX or site specific software if you're going to connect to some remote ISP.....
Jan 04, 2010 | Computers & Internet
DSL-2640U connect to internet but want to setup second dialup connection from pc
Sounds like you have high speed internet and also want a dialup connection as well. Maybe as a backup.
Anyway, your pc will need have a dialup modem installed in it.
If you already have one installed then you will also need a dialup ISP account. Some times an ISP will provide dialup in addition to broadband. Ask you ISP or call AOL.
Sep 05, 2009 | D-Link ADSL2/2+ Modem/Wireless Router...
Trying to connect to dialup with acer laptop notebook
Right click My Computer icon and then My Properties. Click on the Devices tab and check hhe list for Modems. See if your modem appears and if is correctly installed (an exclamation point beside iyour modem, means there is an instalation error).
If everything is OK, you still have to setup the dialup connection:enter the phone number to connect , the username and password, supplied by your ISP provider.
Look here for a walkthrough:
http://209.85.229.132/search?q=cache:OIgea_RPOhEJ:www.learnthat.com/courses/computer/windowsxp/dialup/+dial-up+connection+setup&cd=2&hl=pt-PT&ct=clnk&gl=pt
Jul 22, 2009 | Acer Aspire One AOA150-1405 Notebook
Getting on the internet
Plug an ethernet cable in and it should use DHCP (autoconfigure) to hook up if you have a broadband service... If you have Wifi then it depends on what Operating System you use ie Windows XP, Vista, Linux, OS X but it should scan for networks in the area and connect to which ever one you would like to use. Also if you have a dialup ISP you will need to plug the laptop modem to a phone line and dial out that way... The easiest way is to run the disc that your ISP gives you after everything is setup like in the directions.
Mar 29, 2009 | Dell Latitude D610 Laptop Computer -...
Linux
A shell script is a plain text file that contains instructions for a Unix style shell to run. The most common shell on Linux is BASH.
e.g. a minimal example
#!/bin/bash
# script that says hullo
echo "Hullo world"
(you would normally do _much_ more than that.)
By the way most Linux distros have easy to use tools to set up modems (dialup and pppoe). Or you can usually access the modem/ADSL router directly through a web interface. (see the documentation that comes wioth your modem. (you wont need those silly disks you got with your ISP account :)
Jun 30, 2008 | Computers & Internet
Outlook express
This wants your mail settings, not your dialup settings.
dialup should look something like
user@dialup.com
userpassword
mail settings should be
mail.dialup.com (usually pop.domainname.com)
smtpmail.dialup.com  (Usually smtp.domainname.com)
user
userpassword
Try your webmail. What ISP are you using?
Oct 09, 2007 | Microsoft Office Standard for PC
Asus Eee Pc 701Sd Notebook Logo
49 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
