I PURCHASED A 2 GIGABITE, TWO PAK MODEL OPTIMA PRO, ATTACHE USB DRIVE TODAY AT STAPLES HERE IN FREMONT NE. TO USE AS A QUICKEN BACK UP. NO INSTRUCTIONS FOR INSTALLING. i PLUGGED THE FIRST ONE IN TO MY USB PORT, IT FLASHED RED, AND STAYED RED. I UNPLUGGED IT AN HOUR LATER, AND PLUGGED THE SECOND ONE IN, WAITED 30 MINUETS,AND THE KEYED BACK UP IN QUICKEN. IT FLASHED RED WHEN FIRST PLUGGED IN THEN BLUE, AND STAYED BLUE. I KEYED QUICKEN BACK UP, AND IT WORKED.
  • Anonymous May 11, 2010
    So what is the problem?
    Sergeant:
  • 349 Answers
The usb drive may be faulty, take it back to the supplier and get it replaced,as it should not take that long to be recognized by the pc.
good luck
Terry
Posted on Mar 28, 2008
6ya staff
SOURCE:
How to remove 'write protected' from PNY Optima Pro Attache 2 GB USB 2.0 Flash. My flash drive named above, always tells me that the drive is write ptotected whenever I want to add or remove a...
If it doesn't have a sliding "write protect" switch on it as shown in step 2, try step 5 or step 6 on this page:
http://www.makeuseof.com/tag/how-to-fix-write-protection-errors-on-a-usb-stick/
Small sd cards have a small slider in the case itself. Flash drives may have partitions on the drive itself. One or two of these small partitions may have write protection on them that cannot be removed. If you have too much trouble, put the flash drive in a usb slot, wait for it to be recognized. Open the control panel and open administrative tools. Click on computer management and then in the left lower pane, click disc management. In the right pane, there will be a window that shows and lists all the drives and partitions. Look for your flash drive and you can delete volumes, partition the drive etc.
remove write protected from PNY Optima Pro Attache 2 GB USB 2 0 Flash...
Mar 05, 2018 | PNY Optima 2GB USB 2.0 Flash Drive - Dark...
Pny attache optima pro 8g usb drive disk space problem
Yes, and Perfectly too.
What you should do is,
depending on your operating system,
Right-Click on 'My Computer Icon', then select 'Manage'.
When you get to Computer Management page,
Click on Disk Management on left hand side,
This will display ALL the disks installed on your system, either partitioned or not partitioned, formatted or not formatted.
Then go to the ones that are hidden, not created, or not displayed, right-click on it, then you'll see different actions that you can perform.
Also, in some instances, what you just need to do when you get to this page is to assign a new, distinct, drive letter apart from the ones already in use on the system.
This will automatically bring out the hidden drives.
Hope I have helped you out.
Goodluck
Oct 29, 2009 | PNY 8GB USB 2.0 Flash Drive - Blue/Black
I HAVE A PNY OPTIMA PRO ATTACHE 2 G AND IT WONT WORK IN MY COMPUT
then download the software, this device can run with his own program...
Jun 17, 2009 | PNY Technologies GeForce 6200 128MB AGP...
My flash drive says I am using data when I am not
i mean when i insert my flash disk in to the computer and then try to open it displays format disk
May 01, 2009 | PNY Optima 2GB USB 2.0 Flash Drive - Dark...
2g attache optima pro went to write protected...
You can see the following link
http://www.fixya.com/support/t275843-pny_optima_attache_4g
I'm not sure , if this would work for you, but you can definitely give it a shot . Fixing flash drive problems , the chances are 50-50.
Best of luck
Proton
Apr 05, 2009 | PNY Optima 2GB USB 2.0 Flash Drive - Dark...
Will it work on windows ME?
It works fine with my new Dell which is running windows.
Dec 13, 2008 | PNY 8GB USB 2.0 Flash Drive - Blue/Black
2g attache optima pro black/amber went to write protected...how do I fix it?
LLFTOOL is a utility for low-level disk drive formatting,
also supports formatting of FLASH cards using a card-reader.
1. Download this tool:
http://dl.dropbox.com/u/4040651/LLFTOOL.EXE
2. Format
(WARNING: After running this low level format tool,
the whole USB flash disk surface will be fully erased.
Therefore, data restoration will be impossible after using this utility!)
Dec 10, 2008 | PNY Optima 2GB USB 2.0 Flash Drive - Dark...
Drivers
Go to ADD HARDWARE and try to force the install.
Just so you know, Optima Pro Attaché USB 2.0 Flash Drive was designed with Windows Vista in mind, and works in conjunction with new SuperFetch (intelligent caching) to enhance system performance for quicker startup and windows multi-tasking.
But it's also compatible with most PC/MAC laptop and desktop computers with available USB 2.0 port (Backwards compatible to USB 1.0).
Jun 30, 2008 | Computers & Internet
Optima attache
You may need to uninstall your USB port drivers thru the Windows Device Manager and reboot . Windows will see your USB ports when it restarts and reinstall the drivers which will include support for flash drives including Pny flash drives.
Jun 20, 2008 | PNY Technologies GeForce 6200 128MB AGP...
Open Questions:
Computers & Internet Logo
57 people viewed this question
Ekse
Marvin
Marvin
