Question about V1 Radar Detector
Valentine one alarm keeps going off
As soon as my valentine one radar detector is turned on, the radar alarms go off...all lights are flashing on the unit, won't stop going off until I turn it off.
3 Suggested Answers
  • 134 Answers
SOURCE: my valentine 1 radar detector gives afalse alert to the rear
It has to go back in for service. Possibly the tech either forgot or didn't properly reflow the solder contacts on the LO board which makes contact between the LO board and the horn's ridge. It isn't something which you should even think about attempting to repair yourself. Send it back in and they will get it right this time.
Posted on Mar 17, 2009
  • 13 Answers
SOURCE: Can you tell me what is wrong with my valentine one radar detector please
Old thread but This is probably a fried DC/DC converter inside the detector. Fuses are good for shorts but connecting to double the operating voltage will kill your electronics every time. Valentine 1 is the best. I beat laser with mine. Mike Valentine stands behind his product but you broke it so they probably will charge you for repair. If you have 24V system for stereo then any plugs or terminals need to be obviously marked. Try using a color that you can't mistake like yellow. .Or use a 12v power amp and your neighbors will be much happier.
Posted on Apr 02, 2012
How can i stop my radar detector from going off so much?
Turn off the X band if it's not used in yourt part of the country.
Aug 09, 2014 | EarlyWarning Vehicle Parts & Accessories
LIGHTS DONT FLASH WHEN ACTIVATING THE ARLARM
I thought mine were burnt out. Turns out i had accidently set the dimmer to off on the radar.
Nov 24, 2013 | Vehicle Parts & Accessories
My valentine one will not pick up speed camera vans now it was working on KA band then went to K band now will not pick up?
They are using instant-on radar that has a weak K-band signal that is used to turn on the radar when you are in range. The signal is so weak that you cant detect it until you are in range of the main radar set. This is also known as radar detector countermeasures. Laser is worse. I have beaten laser twice with my Valentine 1 in California where it requires 2 reads to nail you. Slam on the brakes when your detector alerts..
Jul 17, 2011 | V1 Radar Detector
I just bought a v1 but it goes off everywhere. how do i set it correctly for nz roads
That's the way it should be.. Burglar alarms and stoplight sensors transmit on the same wavelengths as radar but mostly X and K band which are hardly ever used for traffic radar anymore. KA band is better and that is what most use now. depends on where you are, Find out what the local jurisdictions use. You have to get used to alerts and learn what is real or not. It's like using any kind of locator like a metal detector. It tells you there is a signal and even tells you the direction. Would you want to trust it to decide which signal was real?
Feb 21, 2011 | V1 Radar Detector
Goes off frequently with no radar nearby
False alarms are common with most radar detectors. You may need to adjust your detector's settings to compensate for the interference that sets off the alarm. Check your user's manual for instructions on using the menu.
Jan 04, 2011 | Passport 8500 Radar Detector
The K band keeps going off when I install it in my car with a Viper Alarm with radar field perimeter sensor
See if you can turn off the field perirmeter sensor - these can make detectors alarm. This sensor should have been wired so that it was only on when the alarm was "Armed".
Jan 01, 2010 | Vehicle Parts & Accessories
Keeps going off randomly.
if its when your driving, then its picking up alarm systems.
If you are not on a major highway this is less likey.
the unit has city mode and highway mode.
If you put it on city, it will go off less from alarm systems.
Dec 05, 2009 | Passport 8500 X50 Radar Detector
Getting false alarm from laser. Laser alarm keeps
If the laser continuously falses even with the car's ignition turned off, then your radar detector has an internal electronics problem. If your radar detector frequently or nearly continuously falses for laser while you are driving even in the middle of nowhere, then most likely the cause of the problem is either poor power and ground connections or electrical noise within your vehicle's electrical system. Jump over to radardetector.net for help in resolving these issues.
Mar 15, 2009 | Passport 8500 X50 Radar Detector
How do you get the back light to stay on
hit the B/L button until you see DIM-DIM or DIM-Brt where the first term is until the unit is not alarming and the second is when the unit is alarming.
Dec 05, 2008 | XCS800 Radar Detector
Valentine one
hi there
Im new to valentine one or any radar detector as purchasing only a few months ago but try to reprogram the V1 by holding down the volume nob on the off position then turn it to the on position while stil holding it down then remain to hold it down until all light are shining from the V1 display if this does not occur your volume button might be damaged and this could be repair by V1 service department http://www.valentine1.com/moreinfo/
gudluk in fixing this problem
Jul 28, 2008 | V1 Radar Detector
V1 Radar Detector Logo
475 people viewed this question
Top Valentine One Vehicle Parts & Accessories Experts
John Nolan
Christian Krentz
Christian Krentz
Are you a Valentine One Vehicle Part and Accessory Expert? Answer questions, earn points and help others
