Question about Dynex 32 in. LCD Flat-Panel HDTV
The picture on my new 32" does fill the screen. What should I do to correct this problem?
  • Dynex Master
  • 736 Answers
I assume you have pressed the zoom button on the remote control that came with the tv. If you have a cable box or satellite tv box press the # button or hd zoom button or aspect button or format button on that remote control. If you are connecting a high definition cable box or satellite tv box to this television make sure that the high definition cables are connected to the right high definition inputs on the television and that the television is switched over to the right corresponding input. If all else fails and this is just happening on one hd channel it is the hd channel.
Posted on May 06, 2010
Change TV resolutions to view slide shows
Nope. The picture resolution has to be 1080 to fill the screen completely. Using stretch and zoom will distort the low rez pictures. No option to change resolution on the TV itself.
Jan 23, 2014 | Sharp Aquos LC-32G4U 32 in. HD-Ready LCD...
I just set up my new TV and it's working but the picture doesn't fill up the screen. How do I correct this?
Most TVs will have a display button the the remote that when you push it, it changes the display, that or zooming in should fix your problem
Aug 05, 2011 | Dynex DX-L32-10A 32" LCD HDTV
A simple question - My new 42" LG tv is fine -
You should be able to change the aspect ratio to fit the size of your screen. This will be the 16:9 4:3 16:10 settings.
You can access these by going to MENU---> PICTURE -----> Select ratio that works----> exit out and watch TV.
IF this will not fix it you need to look into the signals being fed to the TV as sometimes they can have a funny effect on the output picture. Some cable boxes will alter the picture and then it won't come out right on the TV. If it is all inputs doing this tho then changing just the Aspect ratio on the TV should solve the problem.
Jun 07, 2011 | LG 32LG30 32 in. LCD HDTV
I just bought a new insignia LCD TV and the picture does not cover the entire screen. Instead of the 32 inch. diagnal I should, I have a 24 inch picture. Is there something I can do about it?
The "picture size" on the TV needs to be set correctly. You should have a "ZOOM" button on your remote. Press it a few times, cycling through the options... see if this fixes the problem.
Be advised, many (most) HD channels do not show HD content all the time. At the broadcasters discretion, they may choose to ADD the black bars to either side (and/or top an bottom) of the image. This is what the "ZOOM" button is actually for... to allow you to correct this, filling the screen with the image.
*Note: many cable box have a "FORMAT" or "HD ZOOM" button. When used in conjunction with the TVs zoom feature, you can end up having one device set correctly, while the other is not. The result is often a picture that is expanded far beyond the bounds of the displayable area of the screen. If you can not find a solution using the "ZOOM" button, pick the setting which shows the most image. Now adjust the cable box setting (FORMAT / HD ZOOM).
Mar 06, 2011 | Insignia Televison & Video
I cannot figure out how to fill the screen with an image. It has the black side strips instead of a full screen image.
If you were to go to the picture menu and select picture aspect ratio and select 16 X 9 or a different one that you have at present, that will fill the screen.
Mar 05, 2011 | Dynex 32 in. LCD Flat-Panel HDTV
Some programs donot show on full screen
Not all programs are broadcast in HD yet. The picture should fill the screen if it is broadcast in HD. The TV will shrink the picture of a SD broadcast to give you a correct picture aspect. SD is broadcast in 16:9 and HD in Widescreen
Hope this explains it.
Kaufman605
Dec 11, 2010 | Sanyo DP32746 32 in. LCD Television
Just purchased a 32 inch insignia flat screen model # NS-32L430A11, How do I make the picture the full 32 inc instead of the small screen in a box?
Look for 'ASPECT', 'MODE', 'VIDEO', or 'DISPLAY' on the remote button to change the aspect ratio.
One thing to remember is that if the video was made for 4:3 old TV format, when you expand it to fill 16:9 screen, people will loof short and fat.
Dec 04, 2010 | Insignia IS-LCDTV32 32 in. Television
Can't get picture to fill entire screen on Emerson 32" LC320EM1
Hi
On the remote there's a button labeled "screen mode". Depending on what you're watching this will change the screen to what you like.
Jun 05, 2010 | Emerson LC320EM8 32 in. LCD TV
Set up new tv
Try using your TV remote by pressing View Source. I didn't have Toshiba but my pix did not fit screen either. I used View Source on remote and it changed how the picture filled the screen.
Jan 17, 2009 | Toshiba 32AV500U 32 in. LCD HDTV
FLICKING
hi what you need to do is get onto the tvs menu and turn off the auto function that selects best picture like widscreen 16.9 the screen ratio if you put it on one of the other settings other than auto you wont have this problem just try each setting untill you have correct picture so as it fills the screen.
Let me know if you need further asssistance ok
Feb 29, 2008 | Toshiba 32AF62 32" TV
Dynex 32 in. LCD Flat-Panel HDTV Logo
364 people viewed this question
Top Dynex Televison & Video Experts
Jaime Hernandez
Are you a Dynex Televison and Video Expert? Answer questions, earn points and help others
