Question about RCA P52926 52" Rear Projection Television
Rca tv is blurry
I was wondering how to change the screen without breaking the tv
    Sergeant:
  • 418 Answers
2 types. If wooden top rail of screen surround: remove end screws of top rail by removing caps over screws on upper front sides. Remove the two screws. Remove top wooden screen bezel piece. Now pull up and out screens. If sceen surround is plastic one-piece all-around: remove speaker grill board. Remove screws along lower front of screen bezel. Pull bottom of screen bezel out a 1/2 inch. Lift up on screen bezel to remove entire screen assembly.
Posted on May 06, 2010
It has kind of like blurry lines going accross the screen?
my tv also had wavy lines when running thru the cable jack or your standard RCA jacks. i used a S Video cable to hook up my cable and dvd player... with no lines. they are about ten bucks at walmart one of the componets on the signal board.. my dvi also works without any lines. just for the record ihave been fixing tv's in my garage now for about a year all these experts say they cant fix that with this model tv i'll try picking up a parts tv and changing what i think has gone bad inside this tv and let everyone know.. but i have told you a way to get around it and get back to watcing your tv without any of those annoying lines
Jan 25, 2010 | Samsung HCN653W 65" Rear Projection...
Blurry Screen on Panasonic CT-32HL44
I solved my problem. Apparently the RCA cables where missing with the image. So I bought some Component cables and that fixed my problem.
Dec 30, 2008 | Panasonic CT-32HL44 32" TV
WD-52525 screen is jumping all around with wavy horizontal lines etc.
Good Day;
Keep talking to the factory, it is their product. Best Buy won't replace unless it is deemed not repairable and/or terms of the contract. You purchased the extra warranty because you most have felt that the TV might break down. Well, it did, now use the contract to repair your TV.
Good Luck, big IRISH.
Sep 29, 2008 | Mitsubishi WD-52525 52" Rear Projection...
RCA r56wh78 rear projection screen is blurry
if you have little knowledge about electronics, you have to open the back of your tv and adjust the focus adjustment located at the back of the flyback transformer the large black colored like hard plastic... and if it is still not working replace the CRT socket....
Aug 07, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Do we need a new TV?
I dont think this problem can be fixed without solder work or part replacement of convergence section. Its no just matter of fuse. You should get repair facility from concern service center because TV has dangrous voltages inside and qualified person knows how to deal with TV.
Jul 23, 2008 | RCA R52WM24 52" HDTV Projection Television
RCA 36
I got an RCA 27" TV from someone who had moved it to another room but found it was "blurry" after moving it. I brought it home and tried all the suggestions I had found online but it was still blurry. I looked at the back of the TV and found 2 tiny knobs on the right (from the back view) which I began to fiddle with while looking at the screen. It fixed the blurriness immediately! I now have a beautiful screen.
Apr 30, 2008 | Toshiba 36A40 36" TV
RCA P61929 picture problem...
The TV was working fine, some time during the night the power went out, its plugged into a surge protector, everything else works fine, the TV won't turn on, the fuse is fine, is there a reset switch?
Dec 06, 2007 | RCA P61927 61" Rear Projection Television
Rca tv picture blurry and arched up at bottom
Replace the Sanyo I.C. chip on the heat sink of the power supply convergence board STK730-XXX. Last 3 could be 130/010/020, any will work.
http://www.electronix.com/catalog/product_info.php/cPath/6_308/products_id/9541
Sep 20, 2007 | RCA P60921 60" Rear Projection Television
RCA D32F750T TV
Did you adjust the two controls on the new flyback? The top one is almost always the focus control and the bottom is the G2/screen control (brightness) If you adjust the G2 do it until the picture looks normal, too high and you will get retrace lines through the picture.
Jan 25, 2007 | RCA D32F750T TV
Blurry tv
Sounds like theres a leaky capacitor in the screen drive circuit. I have seen this problem also be a gassy crt but was able to clean off the grids of the CRT with a crt/rejuvinator. It happens because of low emmissions in the tube and when white is on thats a mix of all the colors, so the tube works harder. I bet when you whatch a movie and the scene changes suddenly to a white or brite scene the pic looks a little washed out. If this is not the case then I aggree with the Pravin and try it on another TV just to be sure .. This is not a repair for a consumer to do, though however it is only a three year old set you stated, so there should be life left in the tube, so im kinda thinking a capacitor is bad. Seek out a yechnician to check this out for you as a TV is not a place to see it you can fix it or to exoeeriment with. Good Luck
Jul 26, 2006 | Toshiba 36A40 36" TV
RCA P52926 52" Rear Projection Television Logo
282 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
