Question about Dell 926 All-In-One InkJet Printer
I am having problems getting my printer to delete a job, what do I do. I've cancled the print job, restarted the computer, unplugged the printer from the computer and nothing has worked...can you help me asap, I have a ton of homework to get done.
  • Dell Master
  • 5,129 Answers
In Windows, you can force the queue to empty from a command prompt window (or Start > Run) With Vista and Win7, right click and Run as Administrator. You can also do this by stopping the spooler service in services.msc . Run services.msc and click stop then start, Apply, and OK.
For the command prompt (or Run) type "net stop spooler" <enter> without the quotes; then type "net start spooler" <enter> (again without the quotes). Next reboot the computer. The queue should be empty after the reboot. (If you only do the first command, it can take a long coffee break before the queue resets.)
I hope this helps.
Posted on May 06, 2010
I cancelled a document while it was printing and it is still in my queue days later as deleting and it wont let me print anything else or restart that print job.
The best way to delete the print job is to turn the printer off, then disconnect the cable from the printer to the computer. Turn the printer on with the cables off, and go to your computer and delete the document, Then once it's deleted, turn the printer off again, and then hook the cable back up. Then turn the printer back on. That should do it.
Good Luck
Mark
Sep 13, 2014 | HP deskjet 3940 color inkjet printer -...
How to cancel print job in brother's mfc 6800 printer?
open printers left click on printer and cancle aii printing jobs. if this don't work delete printer and reinstall
Aug 31, 2013 | Brother MFC 6800 All-In-One Laser Printer
Only prints first job - can't delete from que
Please try this approach instead:
1. Browse to Start -> Run... and type in NET STOP SPOOLER (this will stop the print spooler service)
2. Browse to your windows\system32\spool\PRINTERS\ folder. You should see files there ending in .SPL and .SHD created around the time you tried to print - delete these files.
3. Browse to Start -> Run... and type in NET START SPOOLER (this will restart the print spooler service)
4. Double click the printer icon in the lower-right corner of your taskbar to examine your print job queue and browse to View -> Refresh.
I hope this information has been helpful.
Dec 20, 2011 | Lexmark X6170 All-In-One InkJet Printer
Trying to cancel a print job after it's already scrolled to printer?
Sometimes this is a right royal pain int he **** to actually do. You need to cancel from the pc that send the print job, then you might have to turn the printer off and restart it a few times. Usually just once if you leave it off for a half minute does the trick. The idea is to clear the memory or buffer.
If it will not clear on the pc then it gets annoying as you won't be able to print until it is out of the way. Cancle the job then delete it from the cue. Then try a reboot or two. If nothing else you can remove the printer from the printer menu, then reboot and add it back in. That force the OS to clear out the spooler and so on. You used to have to hunt down the print job file and manually delete it.
Sep 02, 2011 | OKI C5500n Printer
Printing job stopped
Have you tried deleting the print job and then reprinting the pages that you need. If this doesn't work, you could try deleting the printer and reinstalling it. Let us know how it goes and good luck!
Mar 13, 2010 | HP PSC 1315 All-In-One InkJet Printer
Tried to delete printing job, shows deleting, but is locked up & I can't get it cleared. Have unplugged & turned off printer, but problem still persists.
Hello.
try to reinstall your printer drivers, i have the same problem with my printer.
After you do a reinstall, restart your computer but dont use the printer yet.
after a restart, you can try a print test page.
If its ok, then you need to increase your virtual memory.
Pm me if problem continues.
Ill be happy to help :)
Thank you
Aug 08, 2009 | HP J4680 Office Jet All-In-One Printer
There is a frozen deleted job in my print queue
turn off the printer and unplug it from the computer. after which you restart computer
Mar 27, 2009 | Office Equipment & Supplies
HP Laserjet 1018 won't delete a printing job
to delete the print job.
shut off the printer, disconnect the printer cable to the computer.
go to strat>>printer and faxes.
open the pirnter queue. stop the print job then delete. you may have to restrat the computer.
once the job is deleted, connect the printer cable back to the computer and turn on the printer.
Jan 09, 2009 | HP LaserJet 1018 Printer
Will not print
Try unplugging the USB cable from the back of the computer, not from the back off the printer. Also, try deleting the printer from/at the printer/fax page and restarting your computer so it will reinstall. In either case, when checking the printer/fax folder, make sure there is nothing pending printing. If there is, click on delete all pending printing jobs. If there is a print job pending and you can not cancell/delete this job, then you must delete the printer icon and restart your computer. Aloha!
Sep 20, 2008 | HP OfficeJet 4215 All-In-One InkJet...
Document printing hangs at 99%
same problem. everytime i restarted my pc and deleted the printed files from control panel/printers/lexmark x5150.
Dec 18, 2007 | Lexmark X5150 All-In-One InkJet Printer
Dell 926 All-In-One InkJet Printer Logo
102 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
