Question about Bosch Dishwashers
Bosch SHU 3032 heating element out. How do I fix this? Is it hard and is there instructions on how to do it?
  • sassydeel May 06, 2010
    Water does not heat up during wash cycle so it never advances, just stays in the wash cycle forever if you let it. It ran all night one time, so I posted a question and Richie suggested the heating element. My email is sassydeel@yahoo.com. Thanks
  • sassydeel May 07, 2010
    Oops found it after testimonial. So sorry. Yes if you could please send me the manual to sassydeel@yahoo.com. Your help is much appreciated as I am hoping this indeed is the problem. Part is approx $8.00 much cheaper than replacing the dishwasher.
  • Bosch Master
  • 2,605 Answers
Hello sassydeel, changing the heating element is quite a job, but are you certain you need one ? I ask because I have serviced Bosch built dishwashers for alomst 20 years and I have never seen an element faulty, that's not to say I haven't seen heating issues or it doesn't happen...I'm just saying how rare it is, so make sure it is faulty. Have you confirmed it with a meter ? Let me know, and if you'd like to provide an email address I can send you a complete repair manual via "pdf" through email. Macmarkus :)
Posted on May 06, 2010
Testimonial: "Couldn't figure out how to leave a comment to reply to your last answer. Please send me the manual through my email. I also was at work so have not tried any suggestions yet. Thanks,"
  • Mark MacDonald
    Mark MacDonald May 06, 2010
    Hello again,
    Thanks for the reply, I want to start by saying I don`t want to step on anyones toes, but I don`t want to see anyone spend money on parts that are not likely at fault.
    Having said that I`d first suggest checking the thermostat inside the door panel, based on you description of the timer not advancing and the water not heating. The SHU 30** unit`s with a mechanical timer have very few if any, issues with the actual element as I stated previous. If the thermostat within the door panel is not satisfied, the water won`t heat, hence timer will not advance.
    ** Turn off the breaker at the service panel before attempting any service suggested **
    If you have a #20 torx screwdriver, remove the door panel by taking out the screws around the panel ( watch the edges they are very sharp ) Once the panel is removed you should see the thermostat over by the detergent dispenser clipped to the inner door. Remove it and test it, you`ll need a ohm meter/multi-meter plus a lighter or match to heat it up( or carefully set it on a stove burner for a few seconds until you hear it "click" or watch the meter move if it has alligator clips to fasten to the thermostat connectors..don`t burn yourself or the wire leads ) to see if it open`s & closes.
    I can send you the training manual later, but I`ve got run off to my "day job".
    Let me know how you make out in the mean time.
    Good luck.
    macmarkus :)
  • Mark MacDonald
    I have to make a slight correction to what I said this morning ( it was early and I was still half asleep !). If the problem is what I suspect, (thermostat inside the door) the timer doesn't advance and the water won't heat because the thermostat IS open which would tell the heater it IS satisfied. It should be in the "normally closed" position and open on the rise at approx. 160f. which then shuts off the heater, if it stays open when it should close (after cooling) than the heating element doesn't come back on. There is the rare case the 185f. hi-limit thermostat goes as well, but not very likely unless the flow switch and circulation pump both failed first. I hope this makes some sense to you. I didn't realize what I'd wrote and how I phrased it until I proof read it now...better late than never I hope.
    Sorry if I caused any confusion in the mean-time. Let me know how you make out OK. Do you want me to send you the training/service pdf file via email ?
    Regards,
    macmarkus :)
How to fix a heater zwg 7120p
You will have to purchase the heating element which for your model might look something like the one shown on this site.
Washing Machine Heating Element with Sensor
The instructions to replace this should come with it.
If not then try to download instructions from here which is usually similar for most European front loaders like yours.
How to replace washing machine element front mounted in Bosch washer
Sep 02, 2014 | Zanussi Washing Machines
Bosch she56c02uc dishwasher does not cycle, stuck on wash
If the display is stuck on 2H it often means the heater is not working. If the water is not heated, the cycle will never complete. It is possible the heating element is bad, but a more likely problem is with the control module PC board. The solution requires some basic repair and soldering skills plus the tools to do the job. Bosch recommends re-soldering the connection to the heating element relay (see page 11 of "SHU/SHI/SHV Dishwasher Troubleshooting Tips") free download here The problem is that the circuit board copper is not heavy enough to handle the heating element current, causing the copper to heat and melt the solder connection. A better solution is to solder a short length of copper wire between the two pins to provide more copper and reduce the chance of heating as shown in the attached photo.
Nov 11, 2013 | Bosch 24 in. SHE56C05UC Stainless Steel...
Bosch dishwasher time delay problems
Bosch Dishwasher Repair
When the display is stuck on 2H it often means the heater is not working. If the water is not heated, the cycle will never complete. It is possible the heating element is bad, but a more likely problem is with the control module PC board. The solution requires some basic repair and soldering skills plus the tools to do the job. Bosch recommends re-soldering the connection to the heating element relay (see page 11 of "SHU/SHI/SHV Dishwasher Troubleshooting Tips") free download here
Jan 11, 2013 | Bosch 24 in. SHU5305UC Built-in Dishwasher
I have a 1999 bosch SHU 4300 dishwasher given to me. It worked great for about two weeks. Now it takes for ever *3-4 hours* to complete a cycle (if it does). I have opened the door to see it filled with...
Hi, I have an older dishwasher also and recently mywife also complained about it not cleaning right... so me being the man I amtried in vain to clean the things... Bought new spray arms online and installedthem in minutes...now the thing works like new... However I have also foundthat if the heating element goes bad then that also can mess things up bad...So I would buy new spray arms, and also check out the heating element to makesure it is working... Here is a tip that will help you with the onlinebuying...
Dishwasher SprayArms not Spinning
How to Buy ApplianceParts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The HeatingElement not Working
DishwasherMaintenance DishwasherResidue and Film on Dishes
heatman101
Asker's Testimonial "explanation very clear. will give it a go and see howsimple it was. thanks Ronnie " - ronnieshomes
May 14, 2011 | Bosch 24 in. SHU43 Built-in Dishwasher
Bosch SHU 3032 dishwasher gets stuck halfway through the wash cycle and just continues to wash until you manually advance it. I turned in on before bed one night and it was still running the next morning....
It obviously sounds like a timer issue here, and as it's embedded in a big chip on the control board, I would think a new control board is needed.
The exception to this is if it is not heating at all, in which case it won't advance if the water is not hot enough. Try it again and see if it gets warm.
If not - replace the heating element.
Most machines just stop to heat up the water, but to cut down cycle time they may recirculate the wash-water first to speed things up.
May 04, 2010 | Bosch 24 in. SHU30 Built-in Dishwasher
Bosch SHU 8805 upper arm is getting no water.
replace the upper water arm conduit and wash arm hub as they leak under years of pressure and the o-rings leak water and then it can't hold pressure and supply the upper arm with full pressure water,also replace the center arm conduit if it has one as this will wear out too
Mar 23, 2010 | Bosch 23 in. SHU 8805 Built-in Dishwasher
Impeller is going bad. What will cost to fix on a Bosch shu 9990
Hello there
Normally you will want to get the impeller kit for this it will include the seal for the impeller
Drain & Wash Impeller Kit - Comes with drain & wash impeller, pump seal, chopper, gaskets, screw and instruction sheet.
Part Number: AP3115180
Our Price: $29.00
this is a quote from parts select.com
and is usually a fairly normal price
ok hope this is very helpful for you
Best regards Mike
Jan 06, 2010 | Bosch 23 in. SHU 8805 Built-in Dishwasher
Our Bosch SHU 4300 dishwasher does not drain fully
There is a recall on the control board of many of these models, butyour problem is likely not related. A sticking impeller indicates that the pump may be failing, but you are welcome to try my guide to help. It is here. Thanks!
Jun 15, 2009 | Bosch 24 in. SHU43 Built-in Dishwasher
My Bosch shu 42 just stopped cleaning. there is soap residue also on the dishes. It doesn't seem to be getting really hot water. We cleaned the filter and made sure it was loaded correctly.
When the heating element fails on dishwashers, the wash cycle water can not be heated high enough the activate the DW detergent powder.
Replacing the heating element should fix you right up.
Also, resist the temptation to switch the a cheap, generic powder. A brand name e.g. Electrosol or Cascade powder is proven to work well. The ultra-cheap powder will leave white patches on the dishes and it will not dissolve completely, even when the heating element is working properly.
Good Luck!
May 04, 2009 | Dishwashers
How do I replace the heating element for a Bosch SHU53 dishwasher
are you sure its the element, the control boards on them get bad soldering joints and the you get the impression that the element is bad, but its the solder joint that controls the element that goes bad....you can resolder that
Nov 24, 2008 | Bosch 24 in. SHU53 Built-in Dishwasher
Dishwashers Logo
375 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
