Question about Rio Forge Sprot MP3 Player
Rio Forge 256 MB
I have 2 Rio Forge units. One I just purchased less than a month ago was a refurbished unit. Both units have demonstrated the same problem.
When you go to turn it on, it appears to start up normally but then the screen goes dark. Once it goes dark you cannot turn it back on again. The battery is good in both cases. That's it. Do you have any idea what is causing this? I really like this unit as I use the built-in FM tuner quite often.
I would appreciate any help you can offer about this.
Bob Vigna
Try hooking the player to your computer and reformat the memory in the player. Just like you would format a disk.
Kenny
Posted on Feb 11, 2009
My rio forge player is showing "upgrader"
When mine did this it meant the firmware inside had gotten corrupted. It started working again when I reinstalled the firmware. The official firmware is available at the official website, and wikipedia promotes an unofficial firmware that provides more features.
For either of them, plug the unit into the USB port of your computer, then run the utility to upgrade the your Forge.
(Eventually, my Forge's internal memory storage died - it still play music from card memory, but every time I turn it on I have tell it my language is english etc.)
I hope that helps.
Oct 27, 2009 | Rio Forge Sport Digital Media Player
Rio Forge 256Mb Mp3 Player
was there any cd given along with the purchase of this player???????
Feb 28, 2008 | Rio Forge Sport Digital Media Player
Need to know mem spd...333...400 etc to add cards
Memory Installed 512 MB (2 x 256) Maximum allowed 4 GB* (4 x 1GB) requires the replacement of the installed 256 MB DIMMs
*Actual available memory may be less Speed supported PC3200 MB/sec Type 184 pin, DDR SDRAM DIMM slots Four Open DIMM slots Two
Thats the sticks you need
Good luck
Nic
Feb 26, 2009 | HP Compaq Presario SR1630NX PC Desktop
MMC memory card does not work
It might just be the type of card. I put a SD card in mine and it works fine.
Dec 11, 2007 | Rio Forge Sport Digital Media Player
Just upgraded rio forge512 from v 1.33 to v 3.04.
I had the same problem, I tried everything I thought, I did see a tip from someone else about the contacts of the batteries. I thought to myself it has to be good. wrong, I used a razor charger and found that the system didn't like the battery. Even the good batteries didn't register on the unit flashing battery sign. Cleaned the positive side with a sharp object wa-la.
Dec 05, 2007 | Rio Forge Sport Digital Media Player
RIO FORGE 256
I had exactly same trouble - at least twice..
One time a battery switch and drain for at least 10 min fixed it.
another time I reinstalled firmware...
No big deal..
Nov 11, 2007 | Rio Forge Sport Digital Media Player
Rio forge 512mb problem.
When this happens to me (it does every few months), I re-flash the software following the instructions that come with it. Then the annoying "upgrader" message goes away for another few month. I use version 1.33 in my 512 forge.
Oct 31, 2007 | Rio Forge Sport Digital Media Player
Rio forge 256 MB mp3 player
This happened to my player also. To fix it, you have to go to the rio website and download the most recent firmware for whatever model mp3 player you have. I went to: http://www.digitalnetworksna.com/support/rio/product.asp?model=265&SKU=90260558) Next install. Plug in your player to your USB to your computer - BUT (and here's the important part) you need to hold down the menu key while plugging it in. Keep holding until it powers up AND the word "UPGRADER" shows on the screen. Now, run the firmware upgrade program and follow the directions and it will see your player and upgrade the firmware (yes, even if it's the same firmware version.) You'll have to run the .exe file to get the upgrades onto your player. Unplug the player and it should be like new!
Oct 28, 2006 | Rio Forge Sport Digital Media Player
Rio 258 cannot connect to computer
1. go to http://www.digitalnetworksna.com/support/r....asp?prodID=213 and download update 1.33 2. install update in C:\RioForge\Flash133 3. run RioForgeFlash_133.exe from C:\RioForge\Flash133 4. press Rio Forge menu button and turn the unit on. "upgrader" will appear on screen. 5. plug USB cable to RioForge. 6. click "next" on Rio Upgrade Wizard. Wizard will detect your player. Select and click "next". Upgrade will take place. 7. Unplug Rio Forge from USB and turn it on. Voil?!
Oct 12, 2006 | Rio Forge Sport Digital Media Player
Rio Forge Sprot MP3 Player Logo
94 people viewed this question
Top Rio Audio Players & Recorders Experts
Mohammad Abumuailek
Mohammad Abumuailek
Joseph Hoffmann
Are you a Rio Audio Player and Recorder Expert? Answer questions, earn points and help others
