Question about Keurig B70 Coffee Maker
It doesn't uptake water/brew about every third time; it spontaneously shuts off. I've only had the machine for less than a month. Please help
    Sniper:
  • 92 Answers
Glad to...
I have 2 of them...
you can try brewing nothing... put vinegar in the water container, and try to run just a few cycles...
I allways use filtered water... never from the tap... I have a brita pitcher that's allways at the ready.
You can start by unplugging the unit... wait 30 seconds... then plug in, turn on and wait till its ready... select a different size then what your used to.
press brew and the first thing that happens is the unit will draw water from the container and fill the main water heater. If that doesnt work... then we have an internal problem.
Calling Keurig, they will allways tell you to clean the K-cup holder needle... then the upper needle... then barrage you with water questions... then question regarding usage of Cocoa...
If it's not under warranty, then you have to take it apart and reseat the wiring, as mine went intermittent.
I have a post on how to take off the black plastic shroud...
Once that's off... you have access to everything.....
Posted on May 06, 2010
    Problem Solver:
  • 5 Answers
Try this:
http://www.nate-lewis.com/blog/?p=288
You have to really press the water tank on the machine -- then you just never take it off after you get it going.
Posted on Jun 05, 2010
My Keurig coffee maker will not pump water into the chamber, I have tried the fixit suggestions but to no aavail. Machine was used less than 6 months.
Take the K-cup insert out.
Insert a small paperclip and carefully insert upward into exit needle, swirl to dislodge debris (clog could be preventing H2O uptake).
Do this for all three of the holes in the exit needle.
Add distilled white vinegar to reservoir.
Run "Brew" without a KCup to see if this clears the reservoir uptake and exit needle.
Fill reservoir with water and run to clear vinegar from system.
Mar 13, 2014 | Keurig B60 Coffee Maker
My Platinum brewer has begun brewing on it's own.
They advised me to stop using it and buy a new one. and why do you not listen to them
Nov 26, 2017 | Keurig Platinum B70 Coffee Maker
It's says it's brewing and the water will go into the "warming chamber", but then it like freezes and the Keurig won't do anything. It just continues to say brewing, but nothing...
There is air in the lines and it is blocking the water flow...
Here is a tip that will help you getyour Keurig to prime...
Keurig CoffeeBrewer will not prime
heatman101 ./.,.,
Aug 13, 2011 | Keurig Platinum B70 Coffee Maker
My krups 4055 that is less than 2 mos old suddenly wont brew. it brewed about 2 cups and stopped. water still in resevoir & turning it on & off & unplugging doesn't help.
Dec 13, 2010 | Krups KM4055
No water uptake, then shuts itself off
just a little bit of water comes out
Jan 27, 2010 | Keurig B60 Coffee Maker
My new Breville Keurig machine randomly turns off. I noticed a few times it was right after brewing a cup and it's about to uptake more water or it's in the process of taking up water and heating it. Has...
I just tried the solution from comment dated 1/13/10. I took out the water tank and reseated it. As I did that, I noticed a small gap at the top back of the tank, that it wasn't resting completely against the unit well. I pushed it back and it has not shut off since.
Dec 09, 2009 | Breville BKC600XL Coffee Maker
My Keurig platinum B70 will not pump water through the system. It says "Ready to Brew",I push the brew button, it says "Brewing", but nothing happens. It also defaults to the largest cup size, and will not...
Please get a hold of the company at the number in the manual, they will send you a new one if they cannot fix it. Magic words, I got it as a gift three months ago, it worked fine until now. Worked on mine. Sending out a new one today. This company works with you until you are happy. and I am getting 4 boxes of coffee! Free!
Dec 01, 2009 | Keurig Platinum B70 Coffee Maker
GE 169164 Coffee Pot Not Brewing
Loosen the charcoal filter. You only need to GENTLY place it in. Your problems will all be solved. I just did it 5 minutes ago and i just brewed a 6 cup pot of coffee completely.
Jan 07, 2009 | GE 106591 Coffee Maker
BUNN CWTF-15 Not brewing full pot, only 1/2 pot..?
If this problem started after moving the machine, pull the machine out a little & look behind it for a kink in the tubing coming to the brewer. These brewers time the water coming through them, so if a kink is restricting the water flow, running the same amount of time equals much less coffee in the airpot.
Oct 03, 2008 | Bunn CWTF 15-TS Coffee Maker
Keurig B70 Coffee Maker Logo
738 people viewed this question
Top Keurig Coffee Makers & Espresso Machines Experts
Lisa
Lisa
Jason
Oloyede Monsuru
Are you a Keurig Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
