Question about Nelson Sprinkler: Traveling Tractor
Clicking noise when sprinkler head is turning. Makes the noise even if I spin it by hand.
Philips pt920 makes clicking noise but doesn't 'spin'. When turned on there is a clicking noise. The 3 rod like things which normally spins no longer spins. The head should be working as its removed.
If you flip the head up and the shaver will run without the blades engaged, there is a problem with your blades. The may be installed incorrectly or damaged. Check that they are installed correctly using the video below
https://www.youtube.com/watch?v=Al2GIfK5bZM
When removed, each cutter should turn freely inside its corresponding comb. If one or more do not turn, there is damage and will need replaced. Replacements for model PT920 can be found at shaveroutlet.com at the link below
http://shaveroutlet.com/norelco-philips-hq8-spectra-sensotec-replacement-heads-p-251.html
Sep 11, 2016 | Philips Health & Beauty
Goes backwards is there a button to push to make it go forward?
No, but if you turn the sprinkler heads so that it spins the opposite way, you will change the direction to forward..
Here is a tip about how to get parts for your traveling lawn sprinkler and also a great article about how traveling lawn sprinklers work.
Traveling Lawn Sprinklers
heatman101
May 05, 2011 | Nelson Sprinkler: Traveling Tractor
The turning head of the tractor doesn't want to spin
Check your water pressure... you need to have 40-60 PSI for the tractor to work...
heatman101
Aug 12, 2010 | Nelson Sprinkler: Traveling Tractor
LG gas dryer DLG0452W drum makes a clicking noise
one of the dry drum baffle screw might be lose are there might be something caught inbetween the dry drum front seal are rear
Apr 24, 2010 | LG DLG0452W Gas Dryer
Sprinkler will not move forward properly
I have 2 John Deere 4010 traveling sprinklers and they both do the same thing. I took them apart and the plastic worm gear has flat spot on them. I am having difficulty finding replacement parts.
Mar 08, 2009 | John Deere Gilmour Traveling Sprinkler -...
Washing machine
your transmission is fried
Oct 15, 2008 | Washing Machines
Loud clicking noise - wont agitate or spin
I had the same clicking noise. Turned out to be the coupling between the motor and transmission. A $15 plus 1 hour labor fix
Nov 10, 2007 | Kenmore 22422 Top Load Washer
Nelson Sprinkler:  Traveling Tractor Logo
69 people viewed this question
Top Nelson Garden Experts
Dennis
Mike Squire
Phil Walker
Phil Walker
Are you a Nelson Garden Expert? Answer questions, earn points and help others
