Question about Toshiba 55H70 55" Rear Projection Television
When watching our Toshiba 50H71 it just turns off then back on.
When watching our Toshiba 50H71 Projection television, it just turns off then back on. Why and how do we solve this problem?
  • 160 Answers
The power supply will need to be repaired. This is with any tv that turns itself off and then back on.
Posted on May 06, 2010
Repair inner screen on my 50h71 toshiba
Remove the lower speaker panel. Then you will see a series of screws along the bottom edge of the screen frame. remove those screws and then grasp the screen frame and slide it up slightly to disengage the upper clips then lift the screen assembly away enough to unplug the wire and then the screens can be accessed.
Jul 18, 2010 | Toshiba 50H81 50" Rear Projection...
Double image in 2 colors one color red ofset above and at about 30 degree angle
The convergence needs to be repaired. The 50H71 convergence kit works in your model as well. You can get the kit at the following link which contains the parts and instructions.
http://servicemanuals.vstore.ca/product_info.php/pName/toshiba-50h71--50h81-convergence-repair-kit/cName/convergence-repair-kits
Jul 11, 2009 | Toshiba 43HX71 43" Rear Projection...
Getting 2 images on top of each other on Toshiba 50H71
How To Enter Service Menu is what you need to know and replace both of your STKs these ic chips control convergence.If they are STK392-110s use STK392-180s better ics.
Dec 18, 2008 | Toshiba 50H71 50" Rear Projection...
Toshiba 50H71
you need to replace both the convergence ICs they are STK392-110 you can get new replacement ICs at the following link and they will provide free instalation instructions with pictures so you can do the repair yourself. Heres the link.
May 29, 2008 | Toshiba 50H71 50" Rear Projection...
Red picture toshiba model 50h71
try to turn down the screen control and see how the tv reacts.
Apr 10, 2008 | Toshiba 50H71 50" Rear Projection...
Toshiba 50H71 50 in. Rear... Problem
set most likely has bad convergence ics J.D.W.
Mar 26, 2008 | Toshiba 50H71 50" Rear Projection...
TV KEEPS SHUTTING OFF
It may be solder related, but it may be something such as aleaky diode causing secondary voltages to increase thereby shutting down your set for protective measures. I would recomend getting a service manual and some free support to help you diagnose this. You can get both at the following link.
Mar 19, 2008 | Toshiba 50H71 50" Rear Projection...
Toshiba Tv 50H71
This is like so many sets I have seen here. This problem has to do with the shutdown circuit turning the set off to protect it. As has been said many times this is a problem with the HV section which inclused the deflection, convergence, and horizontal output. These sections can not be repaired by someone who does not have electronics experience. I would suggest that you take this telvision to a repair shop in your area.
Sep 10, 2007 | Toshiba 50H71 50" Rear Projection...
Toshiba 55H70 55" Rear Projection Television Logo
124 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
