Question about Husqvarna Garden
How to assemble the chain brake on a Husqvarna 137 chainsaw
    President:
  • 2,220 Answers
A link to a Husqvarna "IPL, 137/ 137 e, (revised 2008-04) 2006-12, Chain Saw" follows (may not be your saw):
http://weborder.husqvarna.com/order_static/doc/usa/2006/I06000/I0601906.pdf
Page 1 displays the chain brake in good detail. The hand guard must be rotated aft to latch the brake band in the expanded position or it will not be possible to reinstall the cover. It requires a fair amount of force to latch and a vise (use wooden blocks on cover flats to protect the finish) or a large C-clamp to a work surface will probably be required.
HusqvarnaUSA.com (if the above is not your saw, IPL displays parts)
http://www.husqvarna.com/us/homeowner/support/download-manuals/
Enter the 3 digit model number (no XPs, Es, just the numbers)
Serial number decode – useful when downloading IPLs and Manuals
06 1500198
06 = year produced – 2006 (single digit before 2000; please contact Husqvarna for single digit clarification
If you have more questions or need additional help please reply below and I will get back to you. HTH & Good Luck.
Lou
Thank You for using FixYa.
Posted on May 06, 2010
Model 137. How do I assemble the brake spring?
Husqvarna Chain Brake - YouTube
? 7:13
https://www.youtube.com/watch?v=gK7eKakMCz8
Feb 13, 2011 - Uploaded by thoughtfulace
... brake assembly and install the spring in the cover of ahusqvarna saw. ... Next time I will try to remember to disengage the brake first. .... How to Remove a Chainsaw Clutch Cover and Reset the Chain ... Restricted Mode: Off.
husqvarna chain brake is stuck. easy fix - YouTube
? 6:31
https://www.youtube.com/watch?v=usP5XaXO7-8
Dec 19, 2012 - Uploaded by Plotnikoff Nate
How to fix your chain brake from being stuck locked to unlocked the easy way. ... BTW, I will NEVER sharpen a chainsaw again. This new chain ...
How to assemble the brake spring on a 137 husqvarna ...
www.fixya.com/.../t26010777-assemble_brake_spring_137_husqvarna
Dec 16, 2015 | Husqvarna Garden
How to remove the chain from a husqvarna 235e chainsaw?
Like this or pretty close.
  1. Cock brake while expanding chain brake binder by pulling brake handle towards left-hand (wrap-around) handle grip, hard, until it locks in place.
  2. Loosen 2 brake-asssembly-and- bar retaining nuts but do not remove yet.
  3. Unscrew (turn CCW) bar adjustment screw on front face of unit in order to shorten bar and slacken saw chain.
  4. Slip chain off bar over bar tip and towards inward side of bar.
  5. Remove two nuts loosened in step 2 and pull brake assembly and bar straight out and off bar mounting studs.
  6. While rotating clutch/brake-drum, maneuver saw chain off sprocket and around drum perimeter to remove from saw.
  7. Repeat/reverse steps 6 thru 1 in that order to reassemble.
25045742-0m3nstwfcb55vn4usb1qox2f-3-0.jpg 25045742-0m3nstwfcb55vn4usb1qox2f-3-2.jpg
Sep 01, 2014 | Husqvarna 14-Inch 34cc Gas Powered...
How do I remove the chain on a Husqvarna 455 Rancher chain saw
Start by making sure the chain brake is off, pull the hand guard fully back to the top handle, remove the bar nuts ( 13mm ) if it has tooless chain adjustment flip the nut wing out and undo the big grey nut, screw the chain adjuster fully back, if tooless wind the knurled adjuster fully back, now remove the side cover/brake assembly, loop the chain off the nose of the bar, and then over the sprocket and remove.
Apr 15, 2011 | Husqvarna Garden
I have a husqvarna 137 chainsaw. The problem is with the bar oil. When the saw runs oil is flowing but where the rubber corner piece which allows the oil to flow out of appears to be just dripping the...
Hi marcus,
The bar and chain oil goes into the oil tank on the side. The oil for the engine is mixed with the gas before filling the gas tank.
Hope that helps.
Handy Andie
Mar 20, 2011 | Husqvarna , No.455 Rancher, 20" Gas -...
The chain brake on my little 137 husqvarna saw is broken. The metal strip is snapped . Do I need to buy a complete new brake assembly or can I get only the metal strip and fit it into the perfectly good...
You ask a 2 part question, I start with brake band repair/replacement.
A link to a 2004 Husqvarna 137/137E IPL (exploded parts list) follows (may not be your saw):
http://weborder.husqvarna.com/order_static/doc/usa/2004/I04000/I0401903.pdf
See the Chain Brake illustration, item 13 for the band. Item 14 (see Bailey's description. Your local Husky dealer will save shipping fees and is likely about the same price.) is a complete clutch cover $22
Sep 13, 2010 | Husqvarna Garden
How do you start a husqvarna 137 e series chain saw
Hello Sally;
A link to an OM for a Husqvarna 2005 137 (no e listed, the procedure is the same) can be found here:
http://weborder.husqvarna.com/order_static/doc/HOUS/HOUS2005/HOUS2005_O0501001.pdf
The start procedure begins on page 9.
The part that says once it attempts to start open the choke is often overlooked and they flood.
This is the only 137 listed, normally there are many to choose from. If you need additional help Husqvarna can be contacted here:
http://www.husqvarna.com/us/homeowner/support/customer-support/)
Lou
Aug 12, 2010 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
137 stalls
Sounds like an air leak somewhere. Or possible a clogged fuel filter.
Mar 14, 2009 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
Replacing brake assemble for husqvarna chainsaw model 141
Hi Hope this link help you a little http://wssemw.arinet.com/scripts/EmpartISAPI.dll?MF&app=EWSS&session=b091f8d2-6ba8-44df-9037-edddf1788be6&cat=10&TF=epcFrame&assem=148&ignoreHist=Yes&level=1
regards savumihai71
Oct 28, 2008 | Husqvarna Chain Saw 20" Bar
Garden Logo
462 people viewed this question
Top Husqvarna Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
