Question about Maytag Neptune MDE5500AY Electric Dryer
Maytag MDE5500AYW ....All lights light up...do light comes on when you open door, ect. When you turn it on like normal it does not run and hear a very low hum. It just started doing this all of the sudden.
  • tbgrph May 06, 2010
    I gues ,....gonna have to go see
    President:
  • 1,902 Answers
One of two things, either the compositor is bad or the motor is bad. If you have a multimeter you can check the compasitor and see if it is making the proper amount of volts if it is then the motor is bad
Posted on May 06, 2010
  • Jeremy Reddick
    Jeremy Reddick May 06, 2010
    The reason that I am saying that is because you have power going everywhere else, which means that the compasitor and the motor are getting power. So 99% of the time the humming noise that you are hearing comes from the motor that has siezed and is not spinning anymore
My Maytag dryer will not not turn the drum. The red light (more or less dry time sensor light) come on. I relaced the door switch. I do not get a beep. What else could be wrong? MDE6000AYW
Hi godinae...
If you hear you motor running then it sounds like you have a broken drum belt...you will need to replace it or have it replaced.
If you do not hear the motor running then it could be the motor or control panel if you have one.
Free answer Please take time to rate me
Jun 05, 2011 | Maytag MDE6000 Dryer
Maytag Neptune MDE5500AYW panel lights work but not dryer
inside the control panel is a tech sheet that has some diagnostics on it . there is a membrane button test or something to that effect. I suspect that the start/pause button is the problem and you would need to replace the console w/touchpad.about $130-140 new. there are some used ones on ebay.
May 20, 2010 | Maytag Neptune MDE5500AY Electric Dryer
How do you open the top of a Maytag Neptune dryer model #MDE5500AYW
unplug the dryer,open the door and you'll see 4 screws,2 holding the door on and 2 opposite them,remove them and the door,now pull the front off you'll see a clip that looks like an L with a screw through it on each side,take the screws out and lift the top up
Feb 10, 2010 | Maytag MDE5500AYW Electric Dryer
When the light switch in the freezer goes out (by me holding the the switch in or by closing the door) there is a noise that comes from the ice maker. Turn the light on, it stops. Any ideas? The noise is a...
The door switch is designed to turn off the dispenser control when the door is open and the light comes on. Pressing the switch with the door open turns on the dispenser controls and the sounds of relays and solenoid coils would be normal unless it is affecting your dispenser or ice maker. Thanks, Sea Breeze
Sep 30, 2009 | Maytag MSD2651 HE Side by Side...
My maytag will not run
My neptune dryer electric mde5500ayw will not start the button seemed too be struck, and how can i take the side panel off to check the fuses inside
Nov 20, 2008 | Maytag Neptune MDE5500AY Electric Dryer
Maytag Neptune Gas Dryer "do" code
sonds as if you have abad door switch assy, uint not reconozing the door closed
Oct 29, 2008 | Maytag Neptune MDE5500AY Electric Dryer
Maytag MDE5500AYW dryer
If the motor is not running and it is heating, you need to replace the motor.
Jun 03, 2008 | Maytag Neptune MDE5500AY Electric Dryer
Gas Dryer does not run, light comes on in drum, everything else is dead.
do you mean it doesn't heat or does not run at all. i would check the door switch, if its not running at all. try opening the door and push the door switch closed by hand, if the light doesn't go out replace the switch
Nov 11, 2007 | Maytag MDG7600AW Gas Dryer
Maytag Neptune MDE5500AY Electric Dryer Logo
32 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
