Question about Weber Genesis E-320 Propane Grill
The lid has broken the back of the grill and the lid falls all the way back. I feel that this should be covered by warenty but not sure how to get help
    Guru:
  • 1,051 Answers
I agree, this should be covered under the warrenty. I suggest you call Weber customer service at 1-800-446-1071.
Posted on May 06, 2010
My top loading machine only goes when it feels like it. Opening the lid and letting it fall back has worked in the past. I thought a manual might have a troubleshooting section.
Safety switch that the lid activates is bad...with that switch not making proper contact, it thinks the lid is always open.
Hope this helps.
Jul 23, 2011 | Washing Machines
Lid is stuck, can't open it.
Have you checked the lift assist hinge springs on the back of the grill. If they are broken or have come loose, it's impossible for one person to lift the lid. Also, if the lid gasket is severely worn, this could cause the lid to stick.
If none of the above is the culprit, contact Big Green Egg by email or phone
Customer-Support@BigGreenEgg.com or call (800) 793-2292.
Hope this helped you to troubleshoot and solve the problem.
Jun 30, 2011 | Big Green Egg Large All-in-One Grill /...
I bought the Ducane Affinity 3100 from Ace Hardware in 2009. The paint on the inside of the grill lid has started to bubble, peel and fall off. Is this covered by the manufactory warranty. Is it still safe...
According to the Owners Manual for your and the reading of the Warranty, No the paint flaking under the grill hood is not covered under warranty (see link below). As far as safety of using it is concerned ... only if you clean all the flaking paint and any residue, and repaint it with High Heat Grill Paint. This should only be applied after all greasy residue has been removed and only in light coats. Several light coats, in fact. It should be allowed to thoroughly dry between each coat, before applying the next coat. Once the final coat is applied, wait at least five days before using the grill. Be sure no paint gets down of the cooking grates or the burners. You can get the High Heat Grill Paint , form the same Ace Hardware store you bought the grill from. I believe Ace carries Krylon, which is one of the best High Heat Paints.
Apr 10, 2011 | Ducane Affinity 3100
How to remove the cover to retrieve the broken belt
I'm not exactly sure on your model...but most have two screws that hold the control panel to the top lid... one on the right and one on the left. If your model has a lint screen on top of the dryer they'll be some screws there also... Once the screws have been removed try sliding the top lid forward an inch to release the clips then lift...Again not sure if your model is the same. Once you have the top lid off just flip it up and then you'll need to remove the front panel..screws on left and right top...along with disconnecting plug for door switch... lift up on front panel and it should come right off...becarefull the drum will want to fall down when you move the front panel.....Replace the belt and reinstall everything in the reverse order...Good Luck
Apr 20, 2010 | Crosley CDE6000 Electric Dryer
Where is a place cabin filter suzuki gran vitara 2006 i need change
Drop the glove box lid. Empty it and press the sides inwards while 'forcing' it open beyond it's normal stopping point. There'll be a kinda large black box behind the opening. In the centre (or almost) of the box is a vertical cover which kinda looks like a grille. Remove it by releasing the clips at the top and bottom. you might have to feel around for the clips. They're not exactly in front of you, the top one is almost on top of the box and the bottom one is towards the underside of the box. When the cover comes off slide the filters (there are two (upper and lower) out and replace them, then replace the cover and push the glove box lid back into place.
Sep 25, 2009 | 2006 Suzuki XL-7
My compaq laptop is fall down and laptop screen is damaged.so what to do? but i hava a warenty. tellme the lcd screen price
You'll have to contact HP for that. But from what I know, accidental damage are covered with a separate warranty coverage. And you should purchase it separately. I'm not sure if you have that or not. If you don't, then you'll have to spend for the out of warranty repair.
Dec 18, 2008 | Compaq Evo N610C Notebook
Hp deskjet5650
When closing the cover very slowly do you feel at the very bottom before it "closes" a slight resistance?You should have to push it down to finish the movement. Simply let the lid rest on your fingers and lower it into place, if there's no resistance just at dead bottom then the physical tab attached to the pegs of the cover may have broken off. The swich to "close lid" is probably internal by the lid joint.
Check to make sure the print carriage isn't snagged either. any little piece of anything can cause problems.
Good luck.
Sep 05, 2008 | HP DeskJet 5650 InkJet Printer
Loose end cap cover.
This actually applies to most of the newer Pfaff machine models:
  1. If the cover will come completely off, look at the inside of it to make sure the bracket that holds it in place is not broken. If it's not broken...
  2. Grab a flashlight
  3. Remove the stitch lid - there are little silver clips at the base of the lid on either side - push the lid either to the left or right against these clips and you'll be able to pop it right off. You will reverse procedure to put it back on. Removing the lid isn't absolutely necessary but does make it easier to see/access screw.
  4. Raise the handle of the machine
  5. Aim your flashlight into the machine behind the left side of the handle... you should be able to see down inside the machine to the set-screw that holds the side cover in place
  6. Check to see what kind of screwdriver you need - either a Phillips head or a Torx Driver. Most of the newer Pfaff models require a Torx Driver (this is a star-shaped screw-driver available at most hardware stores - Size T25 should fit this particular screw)
  7. Slide cover back into place - may need to wiggle it a bit to get the bracket under the screw
  8. Tighten screw & you should be back in business
If the bracket on the inside of the cover is broken, this part will need to be replaced. Pfaff parts are only available through an authorized Pfaff dealer so your local dealer will need to order it for you.
Hope this helps - please don't hesitate to respond if you need further help or clarification.
Happy sewing,
Kim & Linnette
Dec 20, 2007 | PfaFF Tiptronic 2030
Cover of laptop
do you mean the lid falls off has it been broken in half that would cause it to do that? please explain more the cover is the lid Im thinking of??????????
Sep 30, 2007 | Toshiba 2405-S221 Notebook
Weber Genesis E-320  Propane Grill Logo
199 people viewed this question
Top Weber Grilling Experts
paulcarew
Dan Webster
Dan Webster
Treefrog15
Treefrog15
Are you a Weber Grilling Expert? Answer questions, earn points and help others
