Question about Poulan Wild Thing 2375 18" Gas Chain Saw 2.5 Cuin
ON a Poulan 220 Pro all of the fuel lines are
On a Poulan 220 Pro 38 CC all of the fuel lines are broken and I don't know where to route the new gas line hoses. This has a purge button with two pipes for hoses and there are two pipes on the carburator, one on each side and I know one hose goes thru one of the holes to tank filter but not sure what hole, one to front and one hole to rear top of tank. On the purge ball I would think one would go thru hole to gas tank to siphon gas to carburator, does it make a difference which goes to tank and which goes to carburator ?
    President:
  • 2,220 Answers
Your fuel lines are routed like the schematic below. I suggest you replace the filter, all hoses (2 different sizes), and the purge button (bleeder).
http://www.fixya.com/support/r3706813-2_cycle_fuel_system_repair
Let us start with the bleeder. The 2 hoses that connect to the bleeder are different sizes (Important). If the nipples are the same size connect a hose temporarily to one of them and place the free end in a small container of mix (please be careful with open gasoline and as soon as it is no longer needed put it out of harms way.). Squeeze the bulb if it blows bubbles that is the return side, it gets the large hose and attaches to a fitting on the tank. If it appears nothing happens but when released fuel is drawn into the bleeder it requires a short section of small hose and attaches to one of the carburetor fittings.
A second small hose goes through the tank and connects to the carburetor just like the video including the filter. It feeds the carburetor like it has since before bleeders were installed. I am not certain which carburetor fitting connects to the tank or the primer, please leave them long enough to swap until the saw is running. Logic says the upper most fitting (air bleed) goes to the primer but that is not always true. The Poulan drawing is deceptive it appears the filtered line feeds the bleeder it does not!!!
The IPL (exploded parts list) for your saw is the only detail for fuel line routing and it is sketchy at best. Fuel components and part numbers are listed but are on different illustrations. They are also beneficial with disassembly/reassembly.
A link to a Poulan "PP220 Gas Saw Type 5 follows (may not be your saw):
http://www.ordertree.com/modelinfo/PWE/PP220-Gas-Chain-Saw-Type-5/75.PP220-Gas-Chain-Saw-Type-5.1.59.1.html
If your saw is not a Type 5 you can find the correct IPL here:
Poulan.com
http://www.ordertree.com/modelinfo/POULAN-WEED-EATER/75.59.html
The dash number of your serial number is the type.
If you have more questions or need additional help please reply below and I will get back to you. HTH & Good Luck.
Lou
Thank You for using FixYa.
Posted on May 06, 2010
Testimonial: "Thanks for the information it did get the saw running again. Thanks."
Change the fuel filter in a poulan 38-cc
It depends on how yours is set up, but you have to hook the fuel line with a piece of wire and pull it out the fuel cap side. If there's not enough line to do that, then you have to unhook it from the carb and pull the line through with a small pair of needle nose pliers.
Sep 10, 2014 | Poulan 967146301 Gas Chain Saw, 38 Cc, 16"...
I have a wt820 carb on an echo cs400 how do the fuel lines route
wt820-carb-echo-cs400-fuel-lines-route-u2zok31ofbeqiqkdplhepnij-2-0.jpg which is for the fuel line with the filter and which is for the primer bulb?
Nov 13, 2013 | Poulan Pro 16-Inch 38 cc Anti-Vibration...
I need to change the gas hoses for my Poulan 221
As I promised Felix an IPL for a Poulan "PP221 Gas Chain Saw Type 4" follows (may not be your saw):
The IPL (exploded parts list) for your saw is the only detail for fuel line routing and it is sketchy at best. Fuel components and part numbers are listed but may be on different illustrations. They are also beneficial with disassembly/reassembly: It is deceptive it appears the filtered line goes to the primer, it doe not! It connects to the carburetor input. Trace your existing lines and they will bear my fuel schematic out.
http://www.ordertree.com/modelinfo/PWE/PP221-Gas-Chain-Saw-Type-4/75.PP221-Gas-Chain-Saw-Type-4.1.59.1.html
A typical fuel system and a couple of hints can be found here:
If your saw is not a Type 4, you can find the correct IPL here:
Poulan.com
If you have more questions or need additional help please reply below and I will get back to you. Thank you for using FixYa and Good Luck. HTH
Lou
Mar 29, 2010 | Poulan Pro 16-Inch 38 cc Anti-Vibration...
I need the fuel line routing or diagram for a Poulan Predator 2150 LE. I have parts list but it does not depict the fuel detail I need.
Jimmy there are no Poulan drawings with fuel system detail worth the ink it takes to print them, but that is all there is.
Fuel Line Replacement by SmallEng.com
http://www.youtube.com/watch?v=JrXpU70Hmi0
Routing runs from fuel tank to carburetor, (if equipped) through carburetor to primer bulb (once compressed bulb draws fuel as it returns to normal) , bulb (as it is compressed) returns displaced to fuel tank. HTH
Lou
Oct 22, 2009 | Poulan Pro 16-Inch 38 cc Anti-Vibration...
I may have lines on Backwards??
filtered line from tank goes into top inlet at carb. bottom inlet receives line that goes to carb side of primer {draw side} 3rd line goes from push side of bulb bach to fuel tank.
Mar 25, 2009 | Poulan Pro 16-Inch 38 cc Anti-Vibration...
I have a poulan pro 220 16"
Carb has 2 inlets top inlet connects to tank line with filter on it. Bottom inlet connects to bulb other line from bulb returns to tank on bar side.
Feb 28, 2009 | Poulan Pro 16-Inch 38 cc Anti-Vibration...
Walbro wt hose routing on poulan saw
Carb has 2 nipples. top nipple gets line with filter on it from tank, bottom nipple receives line from bulb other side of bulb returns to tank
Jan 22, 2009 | Poulan Pro 16-Inch 38 cc Anti-Vibration...
Poulan Wild Thing 2375 18" Gas Chain Saw 2.5 Cuin Logo
1,941 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
