Question about Samsung (SH-M522C/BEBN) CD-RW/DVD-ROM Combo Drive
What is CD ROM?
What is CD-ROM?
  • Samsung Master
  • 3,530 Answers
Short for Compact Disc-Read-Only Memory. this where are CD/DVD's are being read by computers.
Posted on May 06, 2010
How do i install this drive?
Unplug the power cable from your power supply and open up your computer Don't forget to wear your antistatic wrist band. Determine which drive bay you are going to install a CD-ROM into. You should pick on of the uppermost drive bays. Before you install a CD-ROM, make sure you have the proper jumper settings. Since we are only installing a single CD-ROM, set the jumpers as MASTER. The jumper settings are different for each CD-ROM drive, so consult your owner's manual so you know which pins to cover up. Once you have the jumpers set, install your CD-ROM in the computer's case. How you secure the CD-ROM in one of the uppermost drive bays depends on your case. Some CD-ROM drives have to be screwed into the drive bay, while other cases come with brackets (like mine) to attach to the CD-ROM drive so that it slides into the drive bay and locks in place.
Connect the power to the back of the CD-ROM drive, then connect the ribbon cable to the back of the CD-ROM drive. Your ribbon cable has three connectors, one in the middle and one on each end. The middle connector is a "SLAVE" connector that is used if you would install an additional CD-ROM or DVD-ROM drive.
Connect one of the end connectors to the CD-ROM drive, and connect the other end connector to the appropriate spot on your motherboard. Note, hard drives and CD-ROM drives have the same style of connector on the motherboard. You want to connect your CD-ROM drive to the motherboard slot that isn't red or is the highest numbered of all the IDE slots.
Power on your computer after you plug it in. Your computer should recognize the new CD-ROM. If it doesn't, Click start control panel administrive tools,computer management,device manager scroll down cd-dvd rom drives you might see a yellow question mark ? right click to update driver,roll back driver,or select properties general troubleshoot, select driver click to reinstall drivers click update driver
Hope this helps
Jul 04, 2011 | LG GH22NS50 22X DVDRW SATA Drive OEM...
How to replace compaq evo cd/dvd disk drive
hi.
open yr desktop cassing then u will see yr cd/dvd rom. then find for button to remove cd/dvd rom then pull tht tht boten and pull up yr cd rom.
new cd rom you must set jumper setting to slave then connect all cd rom cable. on yr system ten see yr cd rom will auto place in my computer.
regards
Feb 21, 2011 | Compaq Evo D510 PC Desktop
Bios sense cd-rom but not read cd
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Right click my computer and click on device manager then right click on DVD/CD-ROM drive then Scan for hardware changes. Then xp will automatically mount the cd-rom.
May 15, 2010 | Drive Deluxe Fly Weight Aluminum Transport...
Hoew to install CD Drive
You want to install a CD Drive. Ok you are Following these steps....
  1. Unplug the power cable from your power supply and open your Computer case.
  2. Determine which drive bay you are going to install a CD-ROM into. You should pick on of the uppermost drive bays
  3. Before you install a CD-ROM, make sure you have the proper jumper settings. You are only installing a single CD-ROM, set the jumpers as MASTER. The jumper settings are different for each CD-ROM drive, so consult your owner's manual so you know which pins to cover up.
  4. Once you have the jumpers set, install your CD-ROM in the computer's case. How you secure the CD-ROM in one of the uppermost drive bays depends on your case. Some CD-ROM drives have to be screwed into the drive bay.
  5. Connect the power to the back of the CD-ROM drive, then connect the ribbon cable to the back of the CD-ROM drive. Your ribbon cable has three connectors, one in the middle and one on each end. The middle connector is a SLAVE connector that is used if you would install an additional CD-ROM or DVD-ROM drive.
  6. Connect one of the end connectors to the CD-ROM drive, and connect the other end connector to the appropriate spot on your motherboard. Note, hard drives and CD-ROM drives have the same style of connector on the motherboard. You want to connect your CD-ROM drive to the motherboard slot that isn't red or is the highest numbered of all the IDE slots.
  7. Power on your computer after you plug it in. Your computer should recognize the new CD-ROM. If it doesn't, go into your motherboards BIOS and search around for the IDE channels, they need to be set to automatically.
Thank U
Aug 28, 2009 | LG Computers & Internet
The CD ROM Drive is not ejecting properly
hi,
Locking device / software installed
First, verify no locking software is being loaded, which would allow the CD-ROM tray not to open. If you are unable to determine this, reboot the computer and as it is booting up, attempt to eject the tray. No power to computer or CD-ROM drive
If you have recently installed a new CD-ROM drive or you have moved the computer, it is possible that the power to the CD-ROM may have become loose or disconnected. Check the cable connections. Bad eject button
If you are running Microsoft Windows 95, Windows 98, Windows NT 4.0, Windows 2000, Windows ME, or Windows XP, open My computer, right-click on the CD-ROM drive and choose the option to eject. If this ejects your CD-ROM drive tray, it is likely that the button on the CD-ROM drive has become defective and it is recommended that the drive be replaced. CD stuck within drive
It is possible that a CD may have become stuck within the CD-ROM drive. If the CD-ROM drive has a small hole (that is not the head phone jack), using a paper clip, place the paper clip within the hole and attempt to manually eject the CD-ROM tray. If the CD-ROM drive is only partially able to be opened, attempt to pull the tray gently to see if it can be manually ejected. If it cannot be opened any further, it is likely that the gears within the CD-ROM drive have become bad, dislodged, or that a CD is positioned in the drive, which does not allow it to open. Incompatibility with IDE / ATAPI interface
If you have an IBM compatible computer and recently installed the CD-ROM drive and are unable to open the drive, attempt to temporarily disconnect the IDE cable to verify that you not experiencing an issue with an incompatibility between the CD-ROM and motherboard. Once the IDE cable has been disconnected, power on the computer and see if the CD-ROM drive tray is now able to be opened. If the drive is able to be opened with the IDE / ATAPI cable disconnected, it is recommended you use the interface card supplied with the CD-ROM drive or the ATAPI interface on the sound card / motherboard. Bad drive
Unfortunately, if after following the above recommendations you are still unable to properly open the CD-ROM drive using the button on the front of the CD-ROM drive, it is likely defective and should be replaced. Caution: If you are able to open the CD-ROM drive using a paper clip. We do not recommend that you continue using the CD-ROM drive by manually ejecting the CD-ROM using a paper clip. The drive should be replaced and this is not meant to be used as a temporary solution. Additional information and tips for buying a new CD-ROM drive can be found on our CD-ROM buying tips section.
Jul 02, 2009 | Computers & Internet
DVD/CD-rom 52X cd-rom unable to recognize DVD
the lens inside the cd rom wil hav to be cleaned
then it wil detect
if the problem still remains then u have to replace the lens inside the cd rom
Mar 07, 2009 | Sony (CDU5212) Internal 52x CD-ROM Drive
How can i get my cd rom cable
you can get in some computer shops and tell you need IDE cable for cd rom.
Jan 01, 2009 | LG CRN 8245B (CRN-8245B) Internal 24x...
Is cd-rom and dvd-rom different?
CDROM drives can only read CDs while
DVDROM drives can read both CDs and DVDs
If you need further clarification please do contact me.
Sep 24, 2008 | Dell Compact Disc Reader CDR-1900 CD-ROM...
Cd rom
Where can I get the driver for my CD-ROM?
Visit our hardware download section to obtain a generic CD-ROM driver (oakcdrom.sys) and mscdex.exe if needed.
If you are looking for a specific driver for your CD-ROM drive or a Firmware update, please see our CD-ROM driver page.
Dont for get to Vote / Merry Christmas.......Good Luck!
Dec 06, 2007 | Computers & Internet
Cd rom 52x mtrp
check the driver version for an updated one on the internet
Feb 03, 2007 | AOpen CD 952E Internal 52x CD-ROM Drive
Samsung (SH-M522C/BEBN) CD-RW/DVD-ROM Combo Drive Logo
54 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
