Question about Motorola Mobility (BQ50 SNN5804A SNN5804) Battery OEM Standard LiION 910mAh
My micro sd card doesnt work with this phone
I found a micro sd card and plugged it into my phone and it comes up as some blackberry file the old songs worked on my phone but now when i deleted them and tried to add my own my phone says that microsd does not contain supported music files pleas help me and tell me why
  • 450 Answers
THIS WILL MAKE YOU LOOSE ALL FILES!!!
(even password)
Take the memorycard out of the phone and,
put it in a computer.Use filesystem FAT-32
to reformat your memorycard.
Now the card will work again!
No password, No files will be left after a
complete reformat
This is your solution! Please vote!
Posted on May 12, 2010
My Blackberry storm application memory is low how do i increase it
Welcome to FixYa.
To have more storage capacity for your phone, delete unimportant SMS in your INBOX, OUTBOX and SENT ITEMS. Delete also unimportant pictures, videos, music and ringtones. The phone memory is relatively small and is shared to all data and other files that are stored in the phone. By deleting some of these will free you some memory.
Alternatively, you can also put in a Micro SD memory card
to your phone (Memory Card model depends to what your cell phone is compatible of, Micro SD is a sample), which will also increase its storage capacity. A Micro SD Card look something like the picture below. jas247_78.jpg
A 16GB Micro SD is available at AMAZON http://astore.amazon.com/doityousol-20/detail/B001L1H0SC
Thank you for using FixYa. Have a great day.
Jun 16, 2011 | RIM BlackBerry Storm 9530 Smartphone
2GB Micro SD needs format code that I never gave it
You can format your micro-SD Card using a software which you can download by clicking this link. I uploaded it to my FTP site for you and it will be there for a limited time. Download that file and save it to your PC. Then unzip that ".zip" file.
If you format micro SD card connecting it to your PC via USB port, it may not ask for password. (I think your phone asks password to format.)
To format your micro-sd card:
- First plug in your micro-sd card into you PC.
- Run the downloaded "HPUSBFW_2.2.3_MASTER.exe" file.
- In the program menu window, select the device (your memory card).
- Select FAT32 as file system,
- Confirm that all the format options unchecked. (Uncheck the quick format option)
- And click the "Start" button to begin formatting.
Hope this helps you.
If you would like to vote for the answer, this will help the others to see the similar problems solved and also will be a satisfaction factor for me to continue helping you.
All the best.
May 12, 2010 | SanDisk 2GB microSD Memory Card
Can't see files located on the 4gb micro sd hc memory card on my Blackberry 8100 Pearl. Path:Media/Music/Media Card - the folder comes up blank. Any ideas?
your card may not work with the blackberry. try formatting the card via it ebeing in the blackberry, and then put everything back on the card afterwards. it should work. if not again, your card might just not be compatible wit the phone
Feb 17, 2010 | RIM BlackBerry Pearl 8100
I just received my new lg cf360 in the mail, inserted my micro sd card and it does not work, says "card not ready!" I previously had the sd in my blackberry pearl and it worked fine.
I ended up figuring it out myself. I inserted my sd card in my pc, copied everything into a folder, went in my computer & right clicked my sd card, (labeled blackberry) formatted it. Reinstalled my stuff from the folder I copied, and inserted it in my new phone. Voila!
Only problem now, my ringtones do not work, says file too big. & The phone tends to occasionally have a brain fart and lock up or erase my info. This is a cheap crappy phone.......
Sep 03, 2009 | LG CF360 Cell Phone
My blackberry knows the media card is there but I can't access anything synced to it. Already formatted it, and when I plug it in to the computer it reads the files as being on the phone. Why can't I...
This has happened to me also, check to make sure the memory card size is supported by your phone. For example, I have an 8GB micro SD card. It will work in one blackberry, but my other one only supports up to 4GB. You would have to check the instruction manual.
Jul 14, 2009 | RIM BlackBerry Pearl 8100
My blackberry stopped working after i put a micro sd card in
did you format the card first... this might help. It could be too much memory. I put an old SD card in from a former phone and it was doing the same thing...powering on and off repeatedly.
Apr 12, 2009 | RIM BlackBerry Pearl 8100
8 gig micro sd unable to format
you should download memory retriever it fixes your memory card and retrieves your data. i had the same memory card and i thought it was from the memory card acting up so i got a new one. but it was kind of from both the phone and memory card but i downloaded the program and = ] my new memory card wasn't formatted so now am all good! both of them working because my san disk memory card wasn't working and it deleted all my data. so now it retrieved and now is working! give it a try! and tell me what happens
Mar 21, 2009 | Electronics - Others
LG KC550
kk to add music make sure you syn the phone and the cp do the data and all then put .mp3 on all the media files and see if it works. Then if that doesnt go to computor format the card and then put it in the phone. Otherwise you need new stuff.
Mar 13, 2009 | LG KC550 Triband GSM 5MP Camera MP3 Phone...
Memory card lg kc550
omg... put your memory card with the bigger card witch you get when buying a memory card into the computer. i do everything with usb but if you cant then do it this way
Nov 13, 2008 | LG KC550 Triband GSM 5MP Camera MP3 Phone...
Memory card micro sd cannot format
Definitely your Micro SD Card has a problem. might be ita a virus problem.
Try to format it by your Computer not by your Phone. If you have a AntiVirus scan your Card and then try to format it.
if you are not successful in one chance Don't afraid at all, try it three or four times by removing and then inserting the Card again in the Computer........
Mar 19, 2008 | RIM BlackBerry Pearl 8100
Motorola Mobility (BQ50 SNN5804A SNN5804) Battery  OEM Standard LiION 910mAh Logo
172 people viewed this question
Top Motorola Mobility Cell Phones Experts
Rami Obeid
Level 1 Expert
Richard Lane
Vernon Taylor
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
