Question about Nikon N2000 35mm SLR Camera
Can't get my camera to advance the film. I put new batteries in but still nothing Is there a particular type of battery I should be using for it??
    Champion:
  • Nikon Expert
  • 225 Answers
Hi Susanabbott2, As long as you are using AAA batteries, unless you have the holder for AA batteries it should advance the film. Things to look at: With the batteries in camera turned on do you see the red display in the view finder, if not there is an electrical issue, if you do see it do the following. Open the camera back make sure the leader is pulled to the red marker on the lower right. On the camera back door is there the chrome springy thingy with the little roller? If not then as you close the camera back there is nothing to place tension on the film so that the sprockets can grab the film.
Posted on Aug 24, 2010
I have an old Nikon FG 35mm Camera that I haven't used for a long time. It worked fine when I put it away, however now after loading new batteries and film, I can't ****/reopen the shutter, film doesn't...
Were the old batteries left in when you stored it? Alkaline cells can leak and cause corrosion, no matter what anyone says. A coating of metal salts on the battery contacts could be the problem. I hesitate to suggest that you may have put the cells in the wrong way up, or forgotten where the on/off switch is, but these will certainly stop the cameras working.
Nov 18, 2010 | Nikon F3 35mm Film Camera
My film advance seems to be stuck. I took the film out of the camera and it still will not move. Does this have anything to do with the battery?
No, the only thing that the FE uses the battery for is the light meter and shutter. You can operate it completely without the battery using the M90 and BULB shutter speed settings.
Your film advance problem is a mechanical problem - check for any small objects that may be jammed into the film transport mechanism. If nothing is obviously causing a blockage, then the camera will need to be serviced.
Nov 14, 2010 | Nikon FE 35mm SLR Camera
I have a pretty old Pentax 35 mm that has not been used in awhile. The film advance crank is stuck. I put new batteries in it (I don't know if I needed batteries for it to advance and for the shutter to...
Given the age of the camera and the fact that it hasn't been used for a while, it's quite likely the lubricants have dried up, causing the mechanical parts to stick. I'd suggest taking it in to a reputable camera shop for a CLA (Clean-Lube-Adjust), the camera equivalent of tuning up your car.
Jul 06, 2010 | Pentax K1000 35mm SLR Camera
How to open a Vivitar 845 camera?
On the back of the camera, there are two sliders. The left hand one is the battery cover, and the other is the film back release.camera03a.jpg
Film advance is automatic when batteries are in it.
If this picture doesn't come out clearly, look at the ebay listing I copied it from ....
http://cgi.ebay.com/VIVITAR-845-TELE-MOTOR-110-POCKET-CAMERA-w%2FMANUAL,-CASE_W0QQitemZ380209378342QQcmdZViewItemQQimsxZ20100225?IMSfp=TL1002251310008r37318
Feb 28, 2010 | Cameras
Cannot take picture, no film advance, new battery
The shutter could be stuck or the mirror could be stuck. (Guessing you have an SLR.)
The film advancing is normal; means it is cocked and ready to go but something is stuck.
Take off the lens and see if anything is keeping the mirrors/shutters from returning.
Oct 23, 2009 | Canon EOS-AE-1 35mm SLR Camera
Olympus iS-50 film camera with new batteries not working
Film door switch is not working.
When you close door make sure door latch is clicking.
Feb 17, 2009 | Olympus IS-50 QD 35mm Point and Shoot...
What does A ERR mean?
There are several situations when this message happens and the camera locks up, and almost none of them has anything to do with the cause stated in the camera manual: film DX coding error. (If it is truly a DX-coding error, manually setting the ISO speed of the film should solve the problem. This could happen in cold weather.) Scenario One: when using Alkaline batteries and the batteries are almost exhausted, and yet one continues to shoot. The battery may not have enough power to complete the shutter firing operation (which usually includes: mirror up, close down diaphragm, shutter fire, mirror down, open diaphragm, advance film, and charge the shutter for next frame). The camera could be lock up in the middle of the operation, left with a dimmed viewfinder. Usually an indication appears quite early if one pays attention: when the batteries are almost exhausted, the film advance becomes noticeably slow. In normal situation film advance is very fast and one cannot distinguish it from other noise such as mirror flipping. When the batteries almost exhausted, the film-advance could take almost 1 second, and the noise of film advancing has been mistakenly identified by some as "beep". I think those is the result of over-adjustment for the Premature Battery Indication problem. This scenario is particular to using alkaline batteries, due to the peculiar behavior of the alkaline battery: even when its power is almost exhausted, it still has a pretty high voltage. Solution: replace the batteries and fire the shutter once should solve the problem. I am pretty sure this is normal, since it happened to me several times, and I once deliberately repeated this happening. Scenario Two: At the end of a roll, when the remaining film is too short for one more frame but long enough to fool the camera, the camera could end up with "Err" message. Solution: rewind the film and load with the new one, and possibly fire the shutter once could solve the problem. (This has never happened to me, but summarized from other’s reports.) Scenario Three: I've heard of two reports: happened in the middle of a roll, with sufficient battery power. I have no idea what’s going on. (Could be really a DX-coding problem, which does not necessarily occur just at the beginning of a roll.) Solution: probably should send the camera in for a check. (Also, both reports of this problem occurs while using Kodachrome films.)
Oct 15, 2008 | Nikon N90S 35mm SLR Camera
Pentax zx 50 35mm slr
Others here have suggested the problem lays with the plastic gear on the advancing motor beside the mirror.
This might cost $100 or so...?
Oct 22, 2007 | Pentax ZX-50 35mm SLR Camera
Film won't adanvce
Needs new batteries, or the film isn't loaded properly. Check the battery area for rust too and clean the contacts gently with a pencil eraser.
Sep 12, 2007 | Minolta Maxxum HTsi Plus 35mm SLR Camera
Nikon N2000 35mm SLR Camera Logo
56 people viewed this question
Top Nikon Photography Experts
Ric Donato
Bart Pulverman
Are you a Nikon Photography Expert? Answer questions, earn points and help others
