Question about Whirlpool LER4634J Electric Dryer
Motor tries to run but tumbler won't turn - Whirlpool LER4634J Electric Dryer
  • 10,319 Answers
The belt that turns the drum has fell off or has broken
Posted on May 06, 2010
My maytag dryer is making a clicking noise and the drum won't spin. I just changed the belt and still not working
That's an interesting one. Does the motor run but does not turn drum? If the motor is running but the drum is not turning then there is a possibility that the belt is not attached to the idler pulley correctly. Go HERE to see video on belt install. I have also ran into the screws that hold the tumblers in the tub loose and making noise. Check to make sure there are no screws sticking out of the tub. Contact me at http://www.apcoplus.com/contact.php if you need more assistance or just comment back on FIXYA..
Apr 30, 2013 | Dryers
I put key in ignition and it won't turn. Steering wheel will turn but key won't turn. We have 2 keys and neither will work. What can I do?
If the wrong key was inserted it may have bent a tumbler pin,maybe try some wd-40 or similar and work it with the right key,might drop the tumbler back,,if not the whole ign. cylinder will have to be changed
Jan 26, 2012 | 2007 Cadillac CTS 3.6L
Took my ford focus to a dealer because key would not turn either way. They said it was the tumbler and would have to be replaced. They jusy called and said they installed new tumbler and reprogramed the...
The reason that the key wouldn't turn must have come from a malfunction of the ignition switch or the connecting rod, rather than the just the tumbler. Since the dash lights & gauges work now, at least part of the ignition switch is working, but apparently not the part that's engaged when the switch is turned to the "start" position.
By replacing just the tumbler, the dealership tech would have jiggled the connecting rod just enough to reseat it (and fix the jam that was causing the key to fail to turn in the tumbler), but didn't fix the real problem, which seems to be a worn out ignition switch or worn connecting/actuating rod.
Here's your steering column anatomy - illustration courtesy Ford Motor Company.
Oct 19, 2011 | Cars & Trucks
The tumbler won't turn.- Model DG7500
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Jul 20, 2011 | Maytag Dryers
Tumbler won t turn
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The
Dryer Repair - The
heatman101
Dec 26, 2010 | Kenmore Dryers
When I push the start button a buzz sounds and the
sounds as if the motor is not starting,try to turn tumbler manually.if tumbler turns but motor does'nt start check motor.
Oct 16, 2009 | Dryers
Ignition tumbler removal
There is a metal button on the ignition housing. Insert your key press the button while turning the key until the button goes in pull out the tumbler. Let me know if the helps. You need more help I will sent you step by step instructions. Hope that helped u out.
Jul 01, 2009 | 1997 Jeep Tj
Tumbler wont turn heater and everything still works but tumbler needs a push to start rotateing then i have to quickly shut the door while the tumbler is still going in order to work please help with any...
Sounds like the start windings or circuit is not engaging. When you press the start button, you engage the start and run windings of the motor. Once the motor starts running, the start windings drop out and the run windings keep it going. Your manual pushing is taking the place of the start process. I'd look at either replacing the motor or check out the start circuit. If the unit is electric, you may want to go price shopping as a new unit may be smarter than doing a repair. At least you'd know what's out there.
Good Luck and hope this helps.
May 21, 2009 | Dryers
Drum problem
While I don't know about your specific dryer, most dryers are set up the same. I just replaced the belt on my Maytag LDE8404ACE. It was easy. The hard part was cleaning out 14 years worth of lint and fuzz that coated everything inside. Here's the instructions:
1. Unplug the dryer or disconnect power.
2. Remove the front panel. There are two screws, each is about 4 inches up from the bottom of the front panel. Unscrew them. Then hold the front panel along the bottom edge and pull it away from the dryer. Once it's away enough, the clamps along the top will pop and disengage from the dryer. Be sure to note the wires connected to the door switch are connected to the dryer. Disconnect them if you need to move the panel away from the dryer.
3. With the front panel off, you should be able to reach inside the dryer to remove the old, broken belt.
4. Remove the tumbler from the dryer. It's held in place by the tumbler front which is secured by 4 screws, 2 on each side. That piece will pull straight out toward you. With the tumbler front out of the way, the tumbler itself will come straight out as well. I recommend taking it out and cleaning the inside of your dryer while it's open. A vacuum hose works great. Also, check the pulley and the back two wheels that the tumbler rests on to make sure they turn easily. If not, you may want to grease them. Also, it's normal for the idler pulley to appear to be loose and wiggle in place. Once a new belt is installed, it's under tension from the spring so any play that exists shouldn't be a problem.
5. put the new belt around the tumbler with the smooth side of the belt against the tumbler. Use the old belt marks on the tumbler to align the new belt. It's easier to hook the belt to the idler pulley and motor pulley from the back. So we'll get to that part in a minute. Just let the belt hang loose for now.
6. Reinstall the tumbler front and secure with the 4 screws you removed earlier.
7. Reconnect the wires to the door switch, if you removed them earlier.
8. Reinstall the front panel, reversing the steps you took to remove it in #2 above.
9. Go to the back of the dryer and remove the access panel along the bottom right hand side.
10. From there, reach in pull the dryer belt around the idler pulley. Then take the belt on the left side of the pulley and move both the belt and the idler pulley to the right, until you can get the grooved side of the belt onto the motor pulley. I've attached a diagram with instructions.
11. Once connected, manually turn the tumbler so that the belt will align and make sure the tumbler turns as easily as it did when you first removed it.
12. If the belt looks good and you've manually turned the tumbler at least one full revolution (to ensure the belt didn't get twisted), then plug the dryer in and turn it on to make sure it works correctly. If so, then re-attach the access panel on the back of the dryer. You're done!
Aug 28, 2008 | Kenmore 73952 Gas Dryer
Dryer tumbler won't turn but heats up
turn on for a short time and listen for a low hum. if present, this means the motor is stalled. take of top and give the drum a push. if it then starts to run then the motor capacitor is faulty
Apr 27, 2007 | Kenmore 64902 Electric Dryer
Whirlpool LER4634J Electric Dryer Logo
69 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
