Question about Craftsman Saws
Lost the set screw that holds the end frame in place. Need to know what size to buy to replace it. I went to Lowe's but they didn't have right size. The guy there thought it might be metric.
  • 623 Answers
Easy one, just take the whole saw to a local hardware store, and have them look at what you need. They should be able to come up with a replacement. By local I mean like a Tru-Value etc., not Lowes or Home Depot.
Posted on May 06, 2010
Lost screws for Mounting. Need to know size screws for mounting
To know more about this, you have to download the repair manual of this set. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy Pull up older posts. Surf the site with patience.
Disassemble procedure to many popular brand TVs are given.
Apr 18, 2014 | Sylvania LC370SS9 LCD TV
Tip
How to Repair Ray-Ban Sunglasses. ?Replace a lost or missing screw in your...
How to Repair Ray-Ban Sunglasses.<br />&bull;Replace a lost or missing screw in your Ray-Ban sunglasses with a small piece of wire. Push the earpiece back into place on the sunglasses and gently wiggle a small piece of wire through the screw hole. Pull the wire through the opposite end and push it back through. Push the wire through at least three times and use your pliers to twist together the ends.<br />Fill a small bowl with warm water and set your sunglasses in it. This is a quick trick for fixing loose frames. The warm water heats up the frames, making it possible to reshape the glasses yourself. Remove the sunglasses after a few minutes and gently bend the frames.<br />Hold the Ray-Ban sunglasses in one hand to replace a lens that popped out. Turn the sunglasses over, so that the front faces down and place the lens onto the back. Gently press down with your other hand, until the lens pops back into place.<br />Use an eyeglass repair kit to replace any missing screws. The kits come with several small screws and a tiny screwdriver. Line up the screw to the proper hole and gently screw into place. If the screw won't go in, it means that your screw hole is stripped and you need to use the wire method.<br />Seal broken parts with instant glue. For broken frames, apply a thin layer of glue to one side and push the broken piece back into place. Hold until the glue dries. Instant glue also fixes lenses for wireless frames. Apply a layer of glue to the bottom of the top piece and push the lens in place.
on Nov 07, 2010 | Clothing Accessories
Tip
Whirlpool: How to replace the coupler on direct drive washers
Removing the cabinet
UNPLUG the washer. There are two screws holding the control panel to the cabinet. Most models the screws are in front but, some models have the screws in back. They are on each end. Now raise the control panel up and let it rest on the hinges. Unplug the lid switch harness and locate the clips on each side (bronze in color) and release them. Now the cabinet will lift off the frame and you can set it aside.
How to replace a coupler Now that the cabinet is out of the way, remove the pump from the motor and set the pump off to the side. Remove the two screws holding the clips on the motor and remove the clips. Unplug the motor harness and on some models you will need to unplug the capacitor.
Now you will need to replace all three parts to the coupler. I use a ½” socket and a small hammer to force the coupler onto the motor and transmission shafts. Put the rubber part onto the coupler half on the transmission and then line up the post on the motor shaft with the holes on the rubber part and it should go on ok. Put the clips that hold the motor in place and plug in the harnesses.
Put the pump back on and the clips to hold it in place. Set the cabinet back on the frame. Make sure the lip on the front cabinet is under the front rail of the frame. Ease the cabinet on the frame making sure the two rear sides of the cabinet set down on the tabs of the frame.
Put the two clips back on that hold the cabinet and plug the lid switch back in. Fasten the control panel down and you are all set.
on Feb 12, 2010 | Washing Machines
I want to change the cartridge but am lost as to how the faucet comes apart.
From www.hamatusa.com
Turn off water at supply line. Turn and remove top ring. Remove handle. Remove top half of body of faucet. Remove diverter (using large screwdriver) and replace. Replace body handle and ring.
Let me know if this works or not.
Gary
Dec 16, 2010 | Hamat 3-2861ST Everest Pull-Out Kitchen...
Replace motor coupler on top loader Kenmore washing machine
Hi, Are you asking how to change the coupler?
Here is how:
Removing the cabinet. UNPLUG the washer. There are two screws holding the control panel to the cabinet. Most models the screw are in front but, some models have the screws in back. They are on each end. Now raise the control panel up and let it rest on the hinges. Unplug the lid switch harness and locate the clips on each side (bronze in color) and release them.
How to replace a coupler:
Now that the cabinet is out of the way, remove the pump from the motor and set the pump off to the side. Remove the two screws holding the clips on the motor and remove the clips. Unplug the motor harness and on some models you wil need to unplug the capacitor.
I hope this helps you. Please let me know if I can assist you further.
Vic
Jul 01, 2009 | Kenmore 24032\24036 Top Load Washer
Won't spin or aggitate there is a part between the pump and motor that looks broken and has a lot of rubber dust on it. can i just replace that part or is it more serious?
Hi, the part you need is a coupler. Here are the instructions for this repair: Normal 0 Removing the cabinet. UNPLUG the washer. There are two screws holding the control panel to the cabinet. Most models the screw are in front but, some models have the screws in back. They are on each end. Now raise the control panel up and let it rest on the hinges. Unplug the lid switch harness and locate the clips on each side (bronze in color) and release them.
Thanks
Vic
Jun 01, 2009 | Roper RAS6233KQ Top Load Washer
COUPLING
Normal 0 Hi, Removing the cabinet. UNPLUG the washer. There are two screws holding the control panel to the cabinet. Most models the screw are in front but, some models have the screws in back. They are on each end. Now raise the control panel up and let it rest on the hinges. Unplug the lid switch harness and locate the clips on each side (bronze in color) and release them.
Vic
May 28, 2009 | Washing Machines
Washer wont spin at end of cycle
Hi, it sounds like the coupler or lid switch is bad. Do you hear the motor running during these cycles?
If you do, the coupler has gone bad. Here are the instruction on how to change the coupler. Part# 285852
Normal 0 How to replace a coupler.
I know this is lengthy but I hope it helps. Please let me know if I can assist you further.
Thanks
Vic
May 25, 2009 | Washing Machines
Broken shift cable for Yard Bug
I had the same problem with the shifter cable braking.They were very expensive to replace.My cable tube(the outer part with the adjustable nuts) was still good.The cable itself was broken.I went to the nieghborhood hardware store and bought a length of cable of the correct size.I then used an electrical eyelet at each end (the eyelet has place to slide wire into it then it get crimped to hold the wire,also it has a hole in it so a screw or bolt can go through to hold it in place.I connected an eyelet to one end of cable,2nd I fed the cable through the tube,3rd, I put a screw through the hole were the cable connect to the shift linkage(@ trans),4th placed the eyelet on the screw 5th then placed the nut on the screw .At end of cable where shift nob is I placed an eyelet where the cable originally went,Pulled the new cable through taking out ALL the slack,Marked cable then crimped it,placed nut on screw.It works like new.MAKE SURE THE LINKAGE and SHIFT NOB ARE IN NUTURAL POSITION
Apr 05, 2009 | Mtd Garden
I replaced the headline recently and lost the parts to attach the rear seatbelts back up, what do I use?
The bolts at the end of the seat belts should be screwed into the mounting holes in the floor, which I believe are threaded at the ends, so u shouldn't need anything at the end of the bolt. Let me know if this is not correct.
Nov 02, 2008 | 1993 Jeep Grand Cherokee
Saws Logo
100 people viewed this question
Top Craftsman Saws Experts
Mike
Are you a Craftsman Saw Expert? Answer questions, earn points and help others
