Question about Jensen VM9510 Car DVD Player
Dual xdvd-700 video bypass code
Will you please give me the correct and "safe" way to bypass the brake safety feature? I'm using it on a boat....
Make a connection to the ground side (-) or negative side of your starting battery.
Posted on Apr 29, 2008
    Problem Solver:
  • 15 Answers
Ground parking wire
Posted on Apr 10, 2008
SOURCE:
SYMA RC CENTURY BOAT DOESN'T WORK OUTSIDE WATER
Actually the Syma Brand Boats are designed to not to work out of water. It is a safety feature. You can bypass that if you like. You remove each wire that is soldered to each propeller shaft and twist them together.
Apr 10, 2014 | SYMA Toys industrial 30" RC SYMA Century...
Parking Brake Bypass.
i would suggest not ground the cable because as you know that a signal will travel the path of least resistance. you could interfer with your ecm and that is a whole different set of problems that will cost you a ton of money to fix. there is a reason for the safety features. I know it's a real pain, but the devices were designed this way so that the liabilty issues would never come back to bite them. I know this is not what you want to hear, but please rate the solution anyway.......thanks
Sep 19, 2008 | Panasonic Strada CN-NVD905U GPS Receiver
What does it mean when my dashboard
Could mean fluid needed or brakes need replacing,or there is air in the brake system,and cold need master cylinder os calipers,anything realy
Apr 20, 2010 | 2000 Volkswagen Beetle
What does pink/brake wire on dvd hook up to?! Ex: -LF- spkr or red power?! what?! I have a "Farenheit TID 580" car cd/dvd player. I have all the wires hooked up except the pink/brake. Is there a wire on my...
Hi all car dvd players have a emergency brake safety feature. The pink wire is to be spliced into your emergency brake wire, or there is a code you can purchase to bypass this feature.
Thank you for using fixya.com
Feb 09, 2010 | Eclipse (AVN7000) Car DVD Player
How do i bypass parking brake so i can watch movies
There is a parking brake switch lead that goes to the unit. You need to permanently ground it to bypass the safety feature.
Apr 28, 2009 | Car Audio & Video
Brake bypass for in dash dvd- DP432
dbd805 dp video deck how do you bypass the safety feature when you put the car in gear.
Dec 17, 2008 | Car Audio & Video
How do i bypass the parking brake switch in order for my video to play
get a toggle switch hook to a ground then to the e-brake wire flip on and off 3 times 4th time leave on worked for me
Mar 19, 2008 | Dual XDVD8265 Car Video Player
Bypass didnt work
Connect the parking break wire to the chasis ground. This is a safety feature that is used so the driver will not view the movie. I have these units installed on our boats and just simply hook to ground.
I hope this helps!
T-Mo
Feb 09, 2008 | Car Audio & Video
Bypassing the parking brake feature
just earth the handbrake cable (light green) on a good earth point.
May 01, 2007 | JVC KD-AVX1 Car DVD Player
Bypassing the parking brake safety
PUT THE GREEN WIRE TO THE GROUND IT ILL WORK I HAVE ONE
Apr 26, 2007 | Kenwood DDX-6019 Car DVD Player
Jensen VM9510 Car DVD Player Logo
402 people viewed this question
Top Jensen Car Audio & Video Experts
Larry Tezekjian
Larry Tezekjian
Mike Duncan
Mike Duncan
xxxxxx xxx
Are you a Jensen Car Audio and Video Expert? Answer questions, earn points and help others
