Question about Home
I have a cracked and damaged area on the bottom of my fiberglass tub insert. Can I fix it myself? Where would I find the kit needed? Thanks.
  • 708 Answers
My secondary bathtub is that way. I was told it was just a surface crack and wouldnt leak. It can be fixed with a fiberglass boat repair kit. However, it would not look very good. I took clear caulk and squirted into mine and it seems to be working fine. Once you put the caulk in rub it in with your fingertip and remove the excess.
Posted on May 06, 2010
Do you have a glue I can fix a crack in fiberglass
Yes there are glues and sealers that will repair fibreglass though for an effective repair the crack should be ground out to a vee and a hole drilled at each end in the normal way.
If the area to be repaired is not stressed and the crack is small impact damage a reasonable temporary repair after preparation could be made with a structural polyurethane adhesive sealer, similar to that used for bonding windscreens.
If the crack is stressed it must be properly prepared and filled with fibreglass repair paste and then reinforced with layers of random mat and resin and finally woven mat for a reasonable finish.
Nov 17, 2017 | Boating
The casing around the jet on the tub side is cracked and is causing water to leak on the outside of the tub. This has happened to three of the 10 jets. What can I do to fix this?
Cheap plastic fatigues with heat . Silicone will work but will not keep the crack from continuing. The fix depends upon what type of plastic you have . It is likely a polyester like fiberglass in which case you can use regular fiberglass to fixit . Rough up the outside with 80 grit , brush in fiberglass resin ( don't forget to mix in hardener) lay in glass material , repeat until built up . Repair the front with a good "gelcoat " repair kit which allows you to mix match color.. sand with 220 , then 600, then 800, then 1500, then 3000 , polish with automotive whit polishing compound , wax
Nov 14, 2017 | Jacuzzi Home
My Whirlpool WFW8310sw2 is leaking water during the rinse and spin cycles. After opening the bottom panel, I noticed that the water was coming around the cement. After tracing it, I found out that it is...
Hello, W/D here.
If you washer is still in warranty, you should let the company make it right.
If not, you can make repairs yourself. First, determine why the leak occurred. One common problem is a loose or damaged counterweight. If loose, it will need to be tightened up. I have seen a counterweight that was pre-stressed, with a rod between the mounting points that had broken, allowing the counterweight to hit the strainer. This can be repaired by replacing the counterweight part, or by strongbacking with aluminum, and epoxying the weight back into a solid mass. Epoxy also is useful for repairing cracks in tubs. I roughen up the area to be epoxied and apply fiberglass mesh (the self adhesive wallboard tape) to the area, and then applying J-B weld. I've never had a repair like this break. For your repair, I would recommend that you build the joint up well, with layers of the fiberglass tape and epoxy, and feather the repair out onto the drum surface area several inches. The fiberglass tape can be cut into strips and applied like a bandage, if you need to make wraps. Overlapping the joint of the tape pieces contributes to the overall integrity of the repair. Just don't put down so much tape at one time that the epoxy can't get to the surface of the drum. Several layers, with curing time in between applications is the best way to go. Depending on where the crack is, the repair is easier to apply if the surface is more horizontal than vertical as the epoxy tends to try to run until it sets, so try to place the washer in a good position, if possible. Removing the tub may make this easier for you, but it isn't critical. If you DO remove the tub, make a similar epoxy repair from the inside of the tub, if possible. This will provide greater strength and sealing.
Hope this gives you better options, --W/D--
Feb 11, 2011 | Whirlpool WFW8300SW
I am getting lots of water in my tandom outfitter kayak . one hour trip produced about 3 gallons of water. how can we fix this problem leak?
Probably a crack in a seam rather than an obvious hole in the bottom. Empty the contents and submerge in water. Or conversely, fill up the kayak with water and make note of the leaks. Food coloring in the water may help to identify the area.
Fiberglass repair kits are available at the hardware store for minimal cost.
May 31, 2010 | Hobie Mirage Outfitter Kayak
Torn bow
Repair any cracks or damage to the hull with fiberglass repair kits, available at most hardware stores. Use an overlay prior to the fiberglass if the area is bigger than a quarter so you don't develop a soft spot.
May 10, 2010 | Advanced Elements Advancedframe...
Patch for tiny holes in fiberglass tub (8 yrs. old)
From my own experience I had a crack in mine. I sanded the area I wanted to patch. I bought a fiberglass repair kit from the hardware store. I mixed the hardener with the resin and applied it without the cloth. Make sure you have good ventilation and don't get it on your hands. After it dried I sanded it smooth it didn't look the best so I hit with a little spray paint. I have since replaced the tub but it held until I was ready to do that. A couple of years. Hey if this helps give me a vote please.
Mar 03, 2010 | Home
We have Builders #6032 and it has small hairline cracks in tub bottom. Its starting to leak into our basement. What do we do to fix it?
alot of times if you call the tub builder they have service guys who will come and fix your tub. most tubs have a 3-8 year warrenty against defects so you could get the fix for free. if not you can always try and get fiberglass resin and mix a batch up and seal the cracks yourself
Aug 01, 2009 | Hydro Systems DUO6648GWP Designer Series...
My porcelain covered bathtub has tons of ''spider cracks'' all over
crack in porcelain is going to affect the cased iron shell. if you don't fix them. water will seep through and cause the iron to rust.
the cause of the cracks are from the extreme temperture change in the room or the floor.
there are no easy fix for this. you can get a tub insert from any of the home center. I can tell you what the price is, since I haven't done any home remodeling for 3 years. price change.
Apr 25, 2009 | Home
One piece fiberglass tub cracked in the middle of basin (4'' crack
The only sure fix is to drill holes in the bottom of the tub and shoot in a commerical grade low expanding foam to fill in the void. The foam you find a Lowes or Home Depot will not work as it is a high expanding foam and will ruin your tub. Call a reliable tub repair company experienced in this type of repair. It should not exceed 200.00 including rolling in a new floor.
Mar 05, 2009 | Home
I have a chip in my bath tub
This is something best handled by a tub resurfacer. It is an area of specialized repair. Results varied depending on material tub is made of. Cast iron tubs Show repair more so than fiberglass. Check for tub resurfacing in Repair Service Link.
Dec 09, 2008 | Home
Home Logo
115 people viewed this question
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
