Question about Akai PT4298HD Rear Projection Television
Green color gun shot
The green color module (for lack of a techy word)seems to have gone out. I have a red arc at the top and bottom of the pic, and any writing on the screen is arched to match, with ghosting, straight red writing. This is the second set of RGB color modules. Is this something an average DIY'er can fix?Is it worth paying someone to fix?
  • jcarrollt1 May 13, 2010
    Thanks, found a guy to come out and replace them for $195.00 cash, but he discovered the blue color is completely shot, no blue at all. He wouldn't give me a price to replace one, as he feels you need to replace all 3, and at that point I'd be better off buying a new TV. At least he was upfront with me on the cost, but is he right? Can I get just the blue lamp replaced? Is it worth it?
    Sergeant:
  • 418 Answers
Bad convergence ICs. Much soldering. About $300 to fix by shop.
Posted on May 06, 2010
Sony 36fs130 picture red , no green
There are two adjustments for the guns on those old tube type sets.
Oct 09, 2012 | Sony FD Trinitron WEGA KD-36FS130 36" TV
Have gone from a good picture to green and blue picture.what happened?
Hi:
If you are connecting the unit by componet cables (RED,GREEN<BLUE) check the cables first to make sure all are connected. If you find they are ok then your red tube may not be lighting up. If you are using a cable box try connectioning the set direct to the cable outlet on your wall. You could also be missing red drive signal to the CRT, in which case service is needed.
Mar 10, 2011 | Samsung Televison & Video
LG Projection TV Model# RT-49NA11T Green color gun shows bent arc on top & bottom.Red & blue guns are ok.How to adjust the green gun to remove the bent arc. This is causing picture shows mix...
This problems ur tv have can't not be fix by adjustment.The tv have a problems known as convergence problems,it dead.Tv have colors lines R,G,B mis alignments,have colors shadow pictures or 3D pictures look alike?The tv convergence board have dead 2 STK convergence ICS and some or all of it resistors too.These parts on the tv convergence board,must be replaced to repair the tv convergence board to solved the tv convergence picture problems.The shop,will cost u like $300-350 for parts and labors.
Jan 10, 2011 | Panasonic PT-53WX53 53" Rear Projection...
When the display is dark i get red and green arcs on the screen
Color arching is an easy fix. You need a screw driver and some patience removing the front panel. You will be looking for a box with 3 screws on it. This is the color gun. THe scews are Red, Green and Blue color only, however, they usually don't indicate the color on them. Turn the screw (Slighlty) till the arching is no longer there. You have to do this with the tv on.. LOL
Best Regards and Semper Fi....
Aug 06, 2010 | Sony KP-65WS500 65" Rear Projection...
My E771 monitor colors suddenly shifted with
Possibilities:
1. video-card gone bad;
2. video-cable gone bad;
3. video-cable not tightly-connected to CRT;
4. video-cable not tightly-connected to video-card;
5. "red" gun inside CRT gone bad.
Disconnect the video-cable from the computer, and try again to adjust the "red". If red-free, then it's time to responsibly recycle the CRT.
Reconnect & wiggle the video-cable, to see if that induces any "red" onto the CRT.
Connect the CRT to the VGA-output port on a notebook computer, to see if that video-card generates "red" as one of the primary colours.
Give the CRT a strong "whack" on the side, to see if "red" makes an appearance.
May 07, 2010 | ViewSonic E771 17" CRT Monitor
Pink,blue,green colors only on sony kp53hs30
U have one color gun is dead.The red color gun is gone.
Jan 05, 2010 | Sony KP-53HS30 53" Rear Projection...
Green picture only
The projection TV has 3 guns RED GREEN BLUE. In your case the red and the blue guns are gone. So you are getting the green color screen. You got to replace the picture tube.
Jul 25, 2009 | RCA TruFlat 27F520T 27" TV
Uh oh... the colors are curved and wacky
replace the amplifier IC chips for the convergence.  part # stk392-???  could be from 040 to 120..  90% chance that'll fix it.
Oct 08, 2007 | Panasonic PT-47WX49 47" Rear Projection...
Center adjust on Red gun is not aligning with B&G vert.
frist set blue and green than set red itwill shoew yu single chakall will be focous in single line than than gun will be allign horizontal if it will correct if itisnot comming than cathode problem.
Oct 06, 2007 | Sony VPH D50HTU Multimedia Projector
Toshiba 32A41 TV -- color problem
Toshibas are notorious for developing shorts in the inernal guns of the picture tube. In your case the green gun is shorted to G1. The noise you heard was an internal arc between the elements. It is unfortunate however, the repair of this problem usually requires the picture tube to be replaced. Sometimes a savvy technician with sencore picture tube rejuvenator can remove the short. This however usually does not last. Scrivitron
Jun 16, 2007 | Toshiba 32A41 32" TV
Akai PT4298HD Rear Projection Television Logo
297 people viewed this question
Top Akai Televison & Video Experts
Jaime Hernandez
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
