The Converter would need a set of Composite (also called RCA inputs, yellow/red/white) inputs on the back, then it would just be a matter of changing the video source on the converter...
However, seeing as how there would be no additional benefit to hooking up a game console or DVD player through the converter to the TV, I'm not sure why you'd want to in the first place...
please help me i can watch my movie since i connect my converter box.. i connected my video cable to the converter when i press play nothing is showing up PLEASE HELP..
u need a stronger antena , best check without the converter box and see if u get chanels , if u do hookup the antena to the converter box then to the tv and do the scan again , move the antena to diferent places
you need to hook up the ps2 directly to the tv not the converter box the converter box is only for digital Chanel's that will go off air on june 12 but if you have cable or satellite then you don't need a converter box this is only for free Chanel's with they don't requires subscription to cable or satellite your playstation should work with out the box try to hook it up directly to the tv not the box
Sounds like a connection problem, if coaxial connection was made and box is turned on, then something should show up on channel 3. If rca composite connection was made something should show up on video 1 or 2. Make sure box's power button is pushed to 'ON'.
3/23/09 --- I don't understand why you would hook your converter box or antenna to your DVD Player. Converter box is only functional between an antenna and a vcr (and/or a TV). DVD Player hooks directly to TV (NOT thru a vcr, coding on dvd discs will screww up the signal and make it fade!) Good luck.
If you're not on cable or satellite, you will need an antenna to get off-the-air reception. This TV does not have a DTV tuner, so you will also need the converter box. Depending on how far you are from the broadcasters' transmitters, you might be able to get away with an indoor antenna. Or you might find that you get few channels with the inside antenna and then you'll need something outdoors. There are a number of styles to choose from.
The antenna hooks to the converter box, and the converter box then goes to the TV. It can be hooked to the TV's "ANTENNA" connector. This should be covered in the set's manual where it shows you how to connect a regular antenna. With the box, your TV will always stay on channel 3 or 4 (depends on how you set up the box) and you'll change channels on the converter.
You can also connect the converter to the TV with audio and video cables like you would a DVD player. Most of the "coupon-eligible" converter boxes include direct video and audio output jacks. This gives you better picture and sound quality than by hooking it to the TV's antenna input.
Hooking up a converter box is like going back in time to when cable TV was new and you had to get a converter box from your cable company. Same way of hooking it up. Hope this helps!
