Question about Ovens
My pilot went out. How do I light it? - Ovens
  • 10,515 Answers
Tell me the Make and Model of the Oven, so that i could Guide you.
Thanks!!
Posted on May 06, 2010
Pilot light went out- how do you light it
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
Nov 23, 2010 | GE JGRP17 Gas Single Oven
I have a bakers pride pizza oven and the bottom oven Including the pilot light) continue to go out for no apperant reason. I have changed the thermocouple 3 times and the pilot light once. Sometimes it...
Several things to check. First be sure the pilot light flame is directly striking the thermocouple. It is a pencil sized rod that is next to the pilot light. Sometimes people reduce the size of the pilot flame to save gas. You may need to increase the pilot flame. Follow the small gas line from the pilot flame back to the gas valve. There is a screw where the small pilot gas line goes into the valve. Remove the screw and then deep in the hole is a tiny screw that can only be reached by a tiny flat blade screw driver. Turn the screw counter clockwise to increase the pilot flame. The thermocouple needs to be red hot to work properly. The second item to check is to see if there are any breezes that occasionally blow through the kitchen. Sometimes the hood fan will draw air under the ovens and actually blow the pilot flame out. Same fix, increase the flame. You may also experience low gas pressure to the appliance during heavy usage. You would need a manometer gauge to check for proper gas pressure. In short, if the oven goes out during your busiest time when everything gas powered is on, the oven may be starved for gas.
Sep 09, 2010 | Bakers Pride FC-616 Gas Single Oven
Oven pilot went out due to power outage. I don't know where the pilot oven light is. where is the pilot light to light the oven?Ge XL44
pilot over lights do not require power to stay light or should it go out in a power outage! do you have to normally light pilot with a match? if not you have a glow coil and its a electronic ignition range and power will affect it. once power is restored you should just be able to turn on over and everything would be ok.if it is a pilot light you need to remove the bottom door stick arm in to back and you'll see the pilot assembly at back if you look up! hopethis helps...
Feb 06, 2010 | GE Ovens
Magic Chef range the pilot on the oven will not light.
Is this a manual lighting pilot,do you light it?
If so you may have a bad gas valve.
If this is an auto light pilot it could be the electronic spark is bad.Im guessing the popping noise is the autospark trying to light.
Jan 05, 2010 | Magic Chef Ovens
Whirlpool Super Capacity 465 Gas-pilot light won't stay lit
I have a whirlpool accubake system / super capacity 465 oven ... the top burners do fine...but my oven pilot went out... and I don't know how to re-lite the pilot... the owners manual doesn't help ... it doesn't show anything a layman could understand ... no visual illustrations ... when I turn on the oven ... the display shows that it's been activated... it clicks a couple of times but does not light ... what is a simple way to re-light the pilot? thanks, A
Nov 25, 2008 | Whirlpool SB160PEE Gas Single Oven
Wolf oven - oven clicks continuously
This sounds like you have a flame switch getting ready to go out. The reason you are hearing the ticking noise is that after the ignition is satisfied the flame switch is not detecting and sending a signal to continue to try for ignition.
Nov 02, 2008 | Ovens
Tappan Gas Range Pilot light went out.
throw the piece of **** out! nobody seems to know how to do this, and there is zero customer service or help available. there are problems like this all over the net with no answers.
Jul 28, 2008 | Tappan 30IN ELEC IGNa Oven
The pilot light for the oven went out.
Relighting Your Furnace's Pilot Light
furnace1.jpg - Turn off the gas at the main valve at your utility box - Wait five to ten minutes for gas fumes to waft away - Get a long match—yes, a fireplace match, not a standard match - Set the gas valve on your furnace to "pilot" - Press the red button as you hold the match to the pilot valve - Keep pressing the red button for 30-60 seconds so the pilot can heat the thermocouple. Release the button and see if the pilot remains lit - If pilot goes out, wait five to ten minutes and repeat the process - Once the pilot stays lit, turn the main gas valve back on - If the pilot light continues to go out, call a technician, who may need to adjust or replace your thermocouple or adjust your pilot
Interthrem mac 1165
You need a new thermocoupler
Jan 23, 2008 | Ovens
Ovens Logo
11 people viewed this question
Top Ovens Experts
Sal De
Craig Butler
Craig Butler
Are you an Oven Expert? Answer questions, earn points and help others
