Question about Troy Bilt Tb425cs 26cc 4 - Cycle Curved - Shaft Gas Trimmer with Ez - Start and Speed Spool
How do I change the oil filter on my troy built 4 cycle trimmer
    Scholar:
  • 47 Answers
You do not have one. Like 4-cycle push mower engines, these are splash lubricated. They lack a full-flow/pressure oiling system. When the oil gets dirty, dump it out and refill to proper specifications. Do this every 20 hours on this trimmer and it will stay happy for a long time.
Posted on May 09, 2010
TROY-BILT TB525 EC 4-cycle Gas Trimmer+how to fix oil leak
Oil runs back out of the carburetor air filter intake if I fill to oil level indicator on no oil gas mix engine. Anything wrong or am I just over filling the oil?
Jun 28, 2012 | Troy-Bilt Garden
Excess white smoke coming from exhaust of TB 75SS string trimmer
This model is a four cycle engine meaning that it does not a mix of gas and 2 cycle oil. You just fill it like your lawn mower, gas and fill the crank case with oil
May 25, 2009 | Troy Bilt Tb425cs 26cc 4 - Cycle Curved -...
Troy built 27cc string trimmer Model TB21 EC. What is the gas oil mix ratio?
4 cycle engines do not run on mixed fuel. Run on straight fuel. They have a spot to put oil in just like a lawn mover, and should be changed regularly. @ stroke engines run on mixed fuel.
Sep 27, 2010 | Troy-Bilt 4-Cycle Curve Shaft Gas String...
How to change trimmer ine in tb525cs - troy built 4 cycle trimmer
You need to unscrew the black bumper button. I believe it is counter-clockwise. Mine was very tight and took a pair of channel lock pliers to loosen.
Jun 21, 2010 | Troy-Bilt 4-Cycle Curve Shaft Gas String...
Gas mix?
Straight Gas no mix for a 4 cycle.
May 16, 2010 | Troy-Bilt 4-Cycle Curve Shaft Gas String...
Oil type for troy bilt weeder 4 cycle model # TB575SS
Non detergent, straight 30 weight.
Sometimes can be found labeled as "Tractor Oil". Otherwise, any premium 10w-30 I find in my experience with these stout 4-cycles to be just fine!
If breaking in engine from new, out of the box? Change oil with 10 hours on the clock with engine is still warm. You only need 3.2 Oz. to fill the crankcase!
So pour slowly. It is full when the trimmer is placed on a level workbench surface with the trimmer head dangling off the end. There is going to be a slight forward tilt away from the oil fill plug. Fill only until it just literally comes to the bottom of the oil fill plug with the trimmer laying flat on your workbench.
*DO NOT FILL IT UP WHILE HOLDING IT VERTICALLY!*
(I warned you. ;D )
Also at this time, clean and re-oil air filter and check your manual - these trimmers after break in require a valve lash adjustment. .005" @ TDC if my memory is correct....The manual I *think* states anywhere from .003 ~ .007 to be within spec. After break in, only need to adjust valves seasonaly. Regular oil changes @ 20~25 hours of run-time keeps them happy.
May 08, 2010 | Troy-Bilt 4-Cycle Curve Shaft Gas String...
Troy Built 4-cycle engine Trimmer
there should be a label stating the oil type somewhere on the engine or cap or owners manual, if not most manufacturers recomend a 30 weight oil. be sure to drain out the old stuff first.
Sep 21, 2008 | Troy Bilt 17 Inch 29 Cc Gas Powered...
Spark plug
You can obtain a spark plug at any Troy Built dealer. Lowes is ours. Your owners manual should tell you what type of oil to use. Again you can obtain it at Lowes.
Sep 15, 2008 | Troy-Bilt 4-Cycle Curve Shaft Gas String...
Troy Bilt Tb425cs 26cc 4 - Cycle Curved - Shaft Gas Trimmer with Ez - Start and Speed Spool Logo
238 people viewed this question
Top Troy Garden Experts
Jim Parker
Jim Parker
Matt Olenzek
Matt Olenzek
DROPNDEAL
DROPNDEAL
Are you a Troy Garden Expert? Answer questions, earn points and help others
