Question about Dryers
Dryer shuts off before time is up not drying clothes. it will not restart for a few hours later
    Problem Solver:
  • 7 Answers
Clean your dryer venting
Posted on May 06, 2010
When put in sensor dry setting, dryer shuts off in a few minutes before clothes are dry
I'd suggest the dryer "sensor thinks" the clothes are dry, or uses a diffenernt standard, or it's bad. I'd revert to the tried and true method of "time".
Mar 05, 2015 | Amana NED7200TW Electric Dryer
No matter what settin the dryer is on my clothes will only get a little warm, but won't dry. It won't heat up as usual.Had a load in there for a few hours yesterday. They are still damp. When dry clothes...
You vent could be the problem. Snow blocking the vent can cause the dryer heat to shut down rapidly. Make sure your vent is open to the outside. Get some windex and clean them moisture sensors inside the machine. If a film developes on them then moisture cannot be detected by the control. It might think the clothes are dry and shut her down. Maytag Bravos Dryer service Manual
Feb 03, 2011 | Maytag Bravos 7.0 Cu. Ft. Electric Dryer
When I use the "More
maybe to blower fan of your dryer has already accumulated too much cotton debris. Usually you can access the blower fan by opening the side panel of your dryer to check it out. but before opening be sure that the unit is unplugged from the supply.
Dec 31, 2010 | Dryers
My LG dlg2532 takes forever to dry clothes. When the drying cycle ends, the clothes are still quite damp. It's a gas dryer and the dryer seems to be getting gas since it does eventually dry the clothes...
How long are the vents? do they go for miles in your house?(sarcasm) Does the dryer have good ventilation? Check the vents again and make sure it is clear.
May 27, 2010 | LG DLG2532 Gas Dryer
Heats and runs, but not long enough to dry clothes; then would not turn on and run at all. maybe dryer ''thinks'' clothes are dry?
Hi, After the dryer shuts off, can you restart it right away or does it need to cool down before restarting? If it needs to cool down for a bit, the motor is going bad. If the dryer is running a full cycle but not completely dry, check your venting to the outside and make sure it is clean.
If this is a gas dryer, the coils on top the gas valve might be shutting down early and not reopening later in the heat cycle.
I hope this gives you some direction. Please let me knwo if I can assist you further on this problem
Vic
Jun 13, 2009 | Dryers
Maytag LDG 712 shuts off before clothes are dry.
First, The most common part would be the over limit safety, it will be mounted to the element housing. Second, there is a thermal fuse usually a small disk with a little fuse inside. You can find these (with your model no.) at www.Repairclinic.com .Good luck.
Apr 20, 2009 | Whirlpool LER5636P Electric Dryer
KITCH AID DRYER
YES MY DRYING IS HEATING UP. THE TIMER WILL NOT SHUT OFF AND STOP THE MACHINE FOR DRYING IF USE ANY TIME.
Oct 14, 2008 | KitchenAid KEYS850LQ Electric Dryer
Dryer stopped running, will not restart
When you try to restart do you hear a motor running? If you do hear that sound and the dryer does not turn your belt could be the problem. (broken)
May 26, 2008 | Maytag Atlantis MDG8400AW Gas Dryer
Dryers Logo
Top Dryers Experts
