Question about Canon MP610 Photo All-In-One Printer
Had a paper jam, corrected this made sure ther were no bits. Got error code 6A00 dont know how to get printer working again. tried unplugging, resetting.
  • 4,041 Answers
Hi there
This answers with a titch more detail.
The 6A00 is a Canon generic code for paper path jam.
Some where in the paper path a sensor is activated indicating paper jam so the printer will give off a 6A00 code.
As a Canon tech, I usually find the code, almost 90% of the time, is related to the purge unit being jammed with something and not being able to move.
Moving the print head assembly will not clear a purge unit if its jammed with paper, paper clips, push pins, screws, cookie crisp, flower bud pods or the like.
And yes I have found all those things in a purge unit.
The offending item needs to be removed or the purge unit needs replacement.
Incidentally, the 6A00 error pertains to all Canon printers made in the last several years, its not just used in one model.
And it’s always a paper path error or purge unit.
The purge unit, called a spittoon assembly in an HP, Lexmark, and other inkjet printers, is where the print head assembly parks when not in use, also its other job is to clean and make sure the print head is clean and open for printing.
That is where you'll find the print head assembly parked on top of it.
It also has an electrical pump to milk the print heads and test for ink flow.
So clean all under where the heads are parked and on IP6600D models you can take out the heads just by clipping them out, and then clean well.
Also clean the purge unit out make sure all is clean.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Posted on May 06, 2010
  • jeffcurly Dec 16, 2010
    Seems to have worked. Is it ncessary to dismantle the cover to the printer heads park place? I just put a piece of lint gently around the area and it seems to have worked.
There was a paper jam. I got the paper out but now error message 6A00 appears in the screen. I have tried to turn off and on.
The error code means paper path jam.
Inside your printer a paper path sensor has been activated indicating paper jam so the printer will give off a 6A00 code.
So please check for any stuck paper, debris
May 11, 2010 | Canon PIXMA MP610 InkJet Printer
Error Code 6A00
Hi
Error 6A00
Solution 1:
Move the printhead carriage back and forth a few times.
Solution 2:
Check the purge unit: Moving the print head assembly will not clear a purge unit if its jammed with paper, paper clips, push pins, screws, cookie crisp, flower bud pods or the like.
Solution 3:
Press the ink pads down in the purge unit.
All I ask is please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
Apr 24, 2010 | Canon PIXMA MP830 All-In-One InkJet...
Action to fix Error Code 6A00
Hi
Error 6A00
Solution 1:
Solution 2:
Solution 3:
Apr 09, 2010 | Canon PIXMA MX310 All-In-One Printer
Pixma MP500 has a ERROR code 6A00 and the printer
Hi there
Mar 01, 2010 | Canon Pixma MP500 All-In-One InkJet...
6A00 Error code? I reset, checked for jams, etc, but no results? Any clues? It is a MP830 Canon, with a bit of printing time, probably several thousand total documents by now. The error code just came on...
OK this is old but you may look back
Error 6A00
Solution 1:
Solution 2:
Solution 3:
Dec 27, 2009 | Canon PIXMA MP830 All-In-One InkJet...
Error 6a00 canon pixma 500
Hi
Error 6A00
Solution 1:
Solution 2:
Solution 3:
Jun 12, 2009 | Canon PIXMA MP830 All-In-One InkJet...
The printer cites error 6A00. I'm told that this
With thanks to a canon tech :-)
Ok Well again I will repeat this answer with a titch more detail.
The 6A00 is a Canon generic code for paper path jam. Some where in the paper path a sensor is activated indicating paper jam so the printer will give off a 6A00 code. As a Canon tech, I usually find the code, almost 90% of the time, is related to the purge unit being jammed with something and not being able to move. Moving the print head assembly will not clear a purge unit if its jammed with paper, paper clips, push pins, screws, cookie crisp, flower bud pods or the like. And yes I have found all those things in a purge unit. The offending item needs to be removed or the purge unit needs replacement. A Pixma MP830 would still be under Canon warranty, get it into a shop and save yourself the hassel.
Incidently, the 6A00 error pertains to all Canon printers made in the last several years, its not just used in one model. And its always a paper path error or purge unit.
I forget myself so here goes, the purge unit, called a spittoon assembly in an HP, lexmark, and other inkjet printers, is where the print head assembly parks when not in use, also its other job is to clean and make sure the print head is clean and open for printing. That is why you'll find the print head assembly parked on top of it. It also has a an electrical pump to milk the print heads and test for ink flow.
May 07, 2009 | Canon PIXMA MP600 all-In-One InkJet...
Service error 6A00
Hi
Error 6A00
Solution 1:
Solution 2:
Solution 3:
Mar 01, 2009 | Canon PIXMA iP4300 InkJet Photo Printer
MP530 - Check Printer - 6A00 error
Hi
Hope it will work for you
Solution 1:
Solution 2:
Solution 3:
Dec 11, 2008 | Canon PIXMA MP530 All-In-One InkJet...
Pixma mp500
Hi
Error 6A00
Solution 1:
Solution 2:
Solution 3:
Oct 08, 2007 | Canon PIXMA MP830 All-In-One InkJet...
Canon MP610 Photo All-In-One Printer Logo
505 people viewed this question
old marine
old marine
