Question about Casio FX-9750GPlus Calculator
Degree and radian function Casio fx-9750GA Plus
Hello, I'm in algebra 3/4 and I'm calculating angels with sin cos and tan amn my teacher told me that I have to be in a degree mode (?) but I can't find it =( Pls answer fast b/c I can't do my homework right now !!
  • Casio Master
  • 7,993 Answers
Press MENU, then select RUN and press EXE.
Press SHIFT MENU to access the SetUp.
Move cursor to highlight Angle.
In the botton of screen you see the Deg TAB. Activate it by pressing F1.
Here is a screen capture.
Posted on May 06, 2010
Testimonial: "Omg thank you sooooooooo much !!!!!! =) Now I can do my homework =) "
How to type sin theta and cosine theta in casio fx-85MS
Since this calculator cannot perform symbolic manipulations (algebra) you never need to type in sin(theta) or cos(theta). To calculate the sine of an angle (whatever the name of the angle may be) just press the sin key followed by an angle value and the function will be calculated. same thing with any other trigonometric function.
Make sure that the angle units is set to the unit required by your calculation: degree, radian, or grad.
Jul 16, 2014 | Office Equipment & Supplies
Sin cos tan
To use these functions press the sin, cos, or tan button followed by the angle you are looking for the value for if in degree mode or the radian value your are looking for if in radian mode.
May 12, 2011 | Casio FX-260 Calculator
How to use calculator on how to evaluate trigonometric functions
The FX-115ES is somewhat different to other calculators you might know. The sequence of keys is more like writing up a calculation in a textbook, whereas for "normal" calculators operations are reversed in some places.
For example, with most calculators you would type 30 [sin] to calculate the sine function of 30 degrees, with the 115ES its [sin] 30 [=].
The 115ES has all the standard trigonometric functions:
  • Standard functions (sin, cos, tan), type the [sin], [cos] or [tan] key followed by the argument.
  • Inverse trigonometric (sin?¹, cos?¹, tan?¹), type [SHIFT][sin], [SHIFT][cos] or [SHIFT][tan] followed by the argument.
  • Hyperbolic functions (sinh, cosh, tanh), type [HYP][sin], [HYP][cos], or [HYP][tan] followed by the argument.
  • and finally inverse hyperbolic (sinh?¹, cosh?¹, tanh?¹), its [SHIFT][HYP][sin], [SHIFT][HYP][cos], or [SHIFT][HYP][tan] followed by the argument.
Arguments can be given as numbers with mantissa (2.718), as fractions (use the fraction key below [CALC]) or as degree, minute, second (30°12'45") using the [°'"] key for input. To switch between degrees (1 circle = 360°), radians (1 circle = 2?), or grad (1 circle = 400 gon), use [SHIFT][DRG>].
Jan 06, 2011 | Casio FX-115ES Scientific Calculator
For get the life of me I can not figure out how to get the degree of a cos angle. For ex. cos theta = 6.5/25 = 0.26 now how do I find the degree? Shouldnt it be 2nd key + cos + 0.26 + enter? the answer...
When using trigonometric functions (cos, sin, tan) and their inverses (arccos, arcsin, arctan) one must be aware that the result will depend on the default angle unit : radian, degree, or grad.
Apparently you are working with the degree as the angle unit, so you must configure the calculator for that unit. (See screen capture below)
Press [SHIFT][MODE] [3:Deg]
Jul 29, 2010 | Casio FX-115ES Scientific Calculator
Why the cos of 90 is -0.44... ?? and the tan sin its'nt correct in the calculator what can i do ?
The trigonometric function evaluations depend on the angle unit you are using: degree, radian, grad
While cos(90 deg)= 0,
cos(90 rad )=cos(90* 180/pi degrees)= -.448073616
ALWAYS CHECK UNITS before using trigonometric functions or their inverse functions.
May 13, 2010 | Casio FX-7400G Plus Calculator
I am getting the wrong answers with the tan -1 function
That habit of TI, Casio, and Sharp to label the inverse trigonometric functions with the -1 superscript can cause confusions.
  1. The inverse trigonometric functions arcosine, arcsine, and arctangent (labeled by manufacturers as cos^-1, sin^-1, and tan^-1) should not be confused with the other trigonometric functions known as secant(x) =1/cos(x), cosecant(x)=1/sin(x) and cotangent(x) = 1/tan(x).
  2. To avoid errors in the use of the inverse trigonometric functions, one must be careful and set the angle unit to the one required by the problem at hand (degrees, or radians)
  3. To make the trigonometric functions really functions, their range is restricted.
  4. In this calculator arcosine (x) gives results between 0 and 180 degrees (if angle MODE is Degree) or between 0 and Pi radians (if angle MODE is Radian).
  5. The range of results for arcsine(x) and arctangent(x) is between -90 degrees and +90 degrees (if angle MODE Degree) or -Pi/2 and Pi/2 (if angle MODE is Radian)
With this information you should be able to set the angle unit correctly ([MODE][Radian] or [MODE][Degree] ) and interpret the results. If you want to extend the angle to other values, use the periodicity of the trigonometric functions.
Hope it helps
Nov 06, 2009 | Texas Instruments TI-83 Plus Calculator
How to use the cosine,tangent etc functions of calculator fx-82ES plus
1.Set the correct angle unit required by your problem: degrees, radians, or grads. [SHIFT][MODE] [3:deg] or [4:Rad]
2. Press the key for the function COS, SIN, or TAN
[COS] displays Cos(
3.Enter the angle 12 deg Screen shows cos(12
Close the right parenthesis ) Screen shows cos(12)
4.Press [=] Screen displays 0.9781
If you want the inverse trigonometric functions you access them with arccos [SHIFT] [COS] (cos^-1)
arcsin [SHIFT][SIN] (sin^-1)
actan [SHIFT][TAN] (tan^-1)
You have to know the principal domain for the inverse trigonometric functions (see any book on trigonometry) to understand the results.
Hope it helps.
Nov 05, 2009 | Casio Office Equipment & Supplies
How to use trig function keys on my casio fx-300ES
You have 3 keys for the main trigonometric functions: [SIN], [COS] and [TAN]
To use them correctly you must set the angle unit to the one your problem calls for.
Press [SIFT][MODE] [3:Deg] for degree, [4:Rad] for radian, [5:Grad] for grad. Dependig on angle unit chosen a small D, R, or G appears on the top of the screen.
If you need the inverse trigonometric functions arcsine, arccosine, arctangent, you access them by first pressing the [SHIFT] key
Thus
arcsine [SHIFT][SIN] (sin^-1)
arcosine [SHIFT][COS] (cos^-1)
arctangent [SHIFT][TAN] (tan^-1)
The syntax for the function is
[SIN] # [ ) ] [=]; [SIN] 30 [ ) ] [=] gives 0.5
[COS] # [ ) ] [=] [COS] 19 [ ) ] [=] gives 0.945518576
Note: if the argument of the functions are numbers, the right parenthesis is not necessary. But if the argument is an expression (with various operations) better put the parenthesis to make sure the calculator is performing as one wants it to.
By the way, there are no keys, or key combinations to calculate cotangent, cosecant, and secant, but you can use the definitions:
cotangent (x) = 1/tan(x) Do not confuse it with tan^-1
cosecant(x) = 1/sin(x) Do not confuse it with sin^-1
secant(x) = 1/cos(x) Do not confuse it with cos^-1
Hope it helps.
Oct 30, 2009 | Casio fx-300ES Calculator
Need to know how to obtain the cot,csc, and see in the degree mode and radian mode
There are no dedicated keys for these trigonometric functions, for the simple reason that they can be obtained from the tan, sin, and cos by a simple division.
cotangent (x) =1/tan(x) . Do not confuse with the arc tangent tan^(-1)
cosecant (x) = 1/sin(x) . Do not confuse with the arcsine sin^(-1)
secant(x) =1/cos(x) Do not confuse with the arccosine cos^(-10)
If you know how to use the tan, cos, and sin, with angle unit in degrees or radians, then there will not be any problem
If angle unit is degree, any number you give a trigonometric function is interpreted as degree. For instance if mode is in degree , and you calculate cos(PI) do not expect the value -1. You will have the value corresponding to the cosine of of 3.14159 degrees, namely 0.99849715
Now for you if you are interested.
If [MODE] is in degrees you can still enter angles in radians
You use the [2nd][ANGLE] [3: raised r] [ENTeR].
Here is a screen capture to show you more clearly.
The raised r is obtained by [2nd][ANGLE][3: raised r] [ENTER]
Hope it helps.
Oct 13, 2009 | Texas Instruments TI-83 Plus Calculator
Casio FX-115 ES: SIN,COS,TAN (answer isnt correct)
It may be due to the angle unit used. You can have angles in degrees, in radians, and in grads. You should set the default angle unit to waht you problem calls for.
To set degree as default SHIFT MODE 3
To set radians as default SHIFT MODE 4
To set grads as default SHIFT MODE 5
The values of angles calculated by the inverse trigonometric functions are in the default unit that is set . This may be the source of the wrong answers that you get.
Hope it helps.
Sep 16, 2009 | Casio FX-115ES Scientific Calculator
Casio FX-9750GPlus Calculator Logo
1,064 people viewed this question
Top Casio Office Equipment & Supplies Experts
k24674
Are you a Casio Office Equipment and Supply Expert? Answer questions, earn points and help others
