Question about Canon Pixma iP6600D InkJet Photo Printer
Ink cartidges practically full but printer says they need replacing
I only use this printer for color printing, which isn't very often. It is now indicating that several of the cartidges need replacing when they are actually quite full of ink. The nozzle pattern is printing correctly. Any suggestions?
  • Anonymous Apr 02, 2008
    ink tanks full but lights flashing saying replace
    Scholar:
  • 141 Answers
Sometime the ink dry if you do not use it.....Try this :
Put warm water on a soft clothe and gently press the clothe with the printhead you'll suppose to see ink on your clothe. That's the better way to clean a printhead.
DO NOT SCRATCH THE PRINTHEAD WITH YOUR CLOTHE..
Posted on Mar 27, 2008
My hp C7180 all in one printer told me I needed to replace an ink cartridge as it would not print in color. I replace the one it said, still did not work, I have replaced all the cartidges and it is still...
First perform an observation of the printers compartibilty to color printing. For example, the printer ought to have been manufactured to capture color pixles to provide resource request in multimedia. usually is possible to have one printer that has several ink location areas to either install color media or dark ink media. In situations where a printer was designed to be black and white ink document compartible would least produce results on color when ink was interchaged. Ascertain that the printer is compartible with multimedia pixel printing proir to acquirng depeltable resources from retail.
Feb 18, 2011 | Office Equipment & Supplies
I've tried replacing the color ink cartridge with two brand new Lexmark cartridges, but still get the error message "Color cartridge replacement required" and printer will not print at all. Tech...
On the ink cartidge there is a ribbon that looks like a circuit board (NOT WHERE THE INK COMES OUT) clean the connectors on the cartidge and the printer and try again
Nov 16, 2010 | Lexmark X5470 All-In-One InkJet Printer
HP Deskjet 5740 I have not used my printer in some time and both cartridges are half full. It printed with the black but came out with gaps in the printing so i took the cartridge out and put it back...
it is better to change the black cartige becaue there is the jam of the ink in black cartidge. or pick out the black cartidge and clean with soft paper in the place from where color is pour. then reinstall the cartidge. i hope it will ok. otherwise, change the cartidge.
byee
May 09, 2009 | Office Equipment & Supplies
I only want to use the black ink, not all 4 colors
Color printer have sofware installed which stops all printing inless their is ink in all containers. No, their is no way around it. Someone would be rich making a kit to do so. since I see this question over and over  at least once a week.
Mar 09, 2009 | Brother MFC 420CN All-In-One InkJet...
Neither black or color will print..
remove and check cartidges it is quite possible that the cartridges must hve dried up.
Dec 08, 2008 | HP PhotoSmart C4180 All-in-One Color...
Printer Designjet 110 Plus not working
Ink supplies Description HP part number 11 Black Printhead C4810A 11 Cyan Printhead C4811A 11 Magenta Printhead C4812A 11 Yellow Printhead C4813A 10 Black Ink Cartridge C4844A 82 Cyan Ink Cartridge C4911A 82 Magenta Ink Cartridge C4912A 82 Yellow Ink Cartridge C4913A
alot of printers now if the ink in the cartidge is the first ones placed in the system from the box are those that are only half full if not less depending on the maker but I know HP only fills their cartidges only just under the half way make but the printer sees it as a new cartrige because of the chips programming.
Have you tryed to turn the power of and let is sit for about 5 mins and turn it back on with the same result? (ushally a yellow error light is on)
Also if you can find the settings to only print in black and white on the printers properties that might also work as well for a temp fix.
But ushally once one ink runs out it likes to do that you where correct with the "is it because of the finished color cartidges.." either that or the carts all have finally expired.
Nice printer by the way.
But your best way to do it would be to replace the color carts and if not reasonable to do now there is also a way to reset the color carts so that the printer thinks that there is ink in them as well.
hope this helps you a bit if you need more info please let us know.
Aug 02, 2008 | HP Designjet 110plus nr InkJet Printer
Dripping color ink
you need to replace the color print head.it right under your color cartidg.
Mar 01, 2008 | HP PSC 1410 All-In-One InkJet Printer
Color cartridge problem
the color cantridge u changed is genew or u have token the other and just fill them fith ink???
if u have bought new cartidges go try print a test page and check if u have installed the cartidges corectly
if u havn bought genew cartidges i seems that the heads are blocked with ink!! go buy some new ones and i believe u will be fine
dont forget to vote!! :)
Stratos
Nov 17, 2007 | HP PSC 1510 All-In-One InkJet Printer
Canon Pixma iP6600D InkJet Photo Printer Logo
122 people viewed this question
old marine
old marine
