Question about Dewalt Heavy Duty Xrp 1/2" 18V Cordless Hammerdrill/Drill/Driver Kit DC925KA
Removing a chuck from a dewalt 18v xrp drill - Dewalt Heavy Duty Xrp 1/2" 18V Cordless Hammerdrill/Drill/Driver Kit DC925KA
  • 94 Answers
SOURCE: Dewalt 18V XRP Hammer drill, stops on torque in drillpositio
The brushes might need to be replaced. You can find them on Ebay and are easily to replace.
Posted on Aug 22, 2009
  • 8 Answers
SOURCE: removing the dewalt DC925 'rohm' chuck
I have a DC927 and a DC926 that I removed 1/2" Rohm Supra SK key-less chucks on. This process is pretty simple. Put the drill motor in 1st gear. Put the clutch ring in drill mode and not in driver or hammer. Reverse or open the chuck all the way. Hold the chuck firmly in a vise and give the drill a good POP counter clockwise. The last step can also be done with a pipe wrench by placing the drill on a work bench and turning the chuck counter clockwise. Continue to un-thread until the chuck is removed. The replacement chuck must have the same mounting process and mechanism. Put a few drops of locktite on the threads and thread the replacement chuck back on. Tighten the chuck using the vise or pipe wrench. Place the short end of an allen wrench in the chuck and tighten down on it. Placing the drill on a work bench, strike the allen wrench with a mallet to finish tightening and locking down the chuck. Congratulations, you have just changed out your chuck.
Posted on Dec 10, 2009
  • 10 Answers
SOURCE: how do you remove the chuck from a dewalt 925 XRP
Open the chuck fully and look down the centre and you will see a philips head for a screw the thread on this is opposite so instead of undoing to the left, undo to the right. There is will be a spot of threadlock on the screw so may be a tad tough the first turn, Once removed unscrew the chuck from the spindle of the drill, you may need a good pair of grips or a vice for this as some get very well stuck on! I hope this helps
Posted on Jan 02, 2010
  • 15 Answers
SOURCE: de Walt DW988 XRP 18v 1/2" Hammer Drill have
Depending on how much play, thats normal. The hammer feature causes that.
Posted on Jan 25, 2011
rowdy45176
  • 2176 Answers
SOURCE: how can i replace the keyless chuck on my makita
I answered that question already on another post, but if you need to know how to remove the chuck I have detailed instructions in the TIP SECTION on how to do this. Let me know if you need more help
Posted on Jan 11, 2012
Dewalt dcd950 chuck
Its is about a 2 years modified the XRP chucks In Netherlands the model 950 is not QS made for europe but all the XRP machines have had a special solide looking Chuck For the original Chuck there was a special tool to remove the chuck the gearbox must be open to and a special N119912 a complete unit of repair tools to remove the chuck and replace , BUT the new modificated repair is by get a normal standard keyless chuck , asked them for about the modification because of the older repair tools and chuck http://www.2helpu.com/world/map.aspx it's about much more cheaper to choose for modification the N119912 is possible renumbered thats possible the right same tool because of the model DCD 950 is not selled in Netherlands . the DCD945 instead of but it means the same kind of modification .
May 29, 2014 | Dewalt DC920KA Heavy Duty Xrp 18V Cordless...
A dewalt dcd970 18v xrp and when i try to unscrew anything the bit comes loose. Can't figure out why?
check the inside of the chuck at the bottom(open the chuck to max). There should be small screw there with either a hex or a Phillips head. It is a left hand screw that locks the chuck in place and will not let it unscrew when you are removing parts.. If it is not there then you will have to get one from an old drill that is junk unless you can get one from an electrical appliance shop the repairs drills.
Oct 24, 2011 | Dewalt Air Tools & Compressors
How do i remove the chuck?
Try opening the chuck all the way open ,look inside and see if there is a nut or bolt head , remove whichever is there and pull off chuck.
Feb 07, 2011 | DeWalt& 18V Heavy Duty 1/2" XRP Hammer...
The chuck on my Dewalt 18v hammer drill will not stay tight. it loosens whether I am in forward or reverse
the chuck on my dewalt 18 volts hammer drill will not stay tight it loosenss whether i am in forward or reverse
Oct 14, 2010 | Dewalt DC920KA Heavy Duty Xrp 18V Cordless...
Chuck wont come off dewalt cordless drill 18v xrp my chuck bolt insid of the chuck wont come out and i need to know if it is reverse thred or not
i cant say 100% sure for that drill but im betting its not.
it probably has red loctite on it which is very tough to break free. put some heat to it. then it will come easily
Mar 16, 2010 | Dewalt DC920KA Heavy Duty Xrp 18V Cordless...
HOW DO I REMOVE THE CHUCK FROM A DEWALT DC926XRP DRILL?
Open the chuck and remove the screw that is down inside the chuck; it is probably a left hand thread
Aug 11, 2009 | Dewalt DC920KA Heavy Duty Xrp 18V Cordless...
Removal of chuck
this type of drill don't have any chuck screw in the center of the chuck.alos u need special jig to remove the chuck
Aug 11, 2008 | Dewalt DC920KA Heavy Duty Xrp 18V Cordless...
Dewalt XRP Drill Chuck will not come off
you need a special jig to remove the chuck on this kind of drill
May 22, 2008 | Dewalt DC920KA Heavy Duty Xrp 18V Cordless...
Dewalt Heavy Duty Xrp 1/2" 18V Cordless Hammerdrill/Drill/Driver Kit DC925KA Logo
230 people viewed this question
Top Dewalt Drills Experts
Jim Thurston
Are you a Dewalt Drill Expert? Answer questions, earn points and help others
