Question about Keurig Platinum B70 Coffee Maker
Will only brew small cup
Even when the menu is reset, only brews small sized cup
    Sniper:
  • 92 Answers
Every level is a physical sensor in a clear plastic housing just above the main water heater...
when you select a size, the main pump starts to push water into the heater, and the hot water fills this plastic housing... there are about 7 stainless steel sensors that make contact with the water level... based on what you selected...
without knowing how long you had the unit and the type of water is used... etc.etc. you can try the obvious... run vinegar thru it and see if the unit starts working correctly. replace the water with vinegar and let the vinegar work for a few hours...
Otherwise you are relegated to opening up the unit and resetting the connections... which go intermittent and lose connectivity.
I have a discussion on this site about taking off the black shroud and opening up the panel that has all of the connections that unplug...
those get reseated, and that usually fixed it.....
Posted on May 06, 2010
"brew unit block" medium cup in service mode dont work only the small cup works
When the alert came up- Brew unit blocked- this is before you started taking things apart, A, were you able to remove brew unit, Yes or No?
B, after turning power on and then off, Did the machine try to reset brew unit to home position Yes or no?
If Yes were you able to remove brew unit?
Aug 18, 2014 | Miele CVA615 Espresso Machine
Mr. Coffee single serve brewer won't brew
First clean and please try again
Fill the reservoir with water.
Place your mug underneath the machine.
Add the K-Cup.
Choose your serving size.
Press the brew button to begin brewing.
Enjoy your delicious cup of coffee! .
Sep 25, 2013 | Mr. Coffee BVMC-KG6 Single Serve Coffee...
After brewing a cup, lights are flashing and it needs to be unplugged to reset to brew
It's time to descale your brewer. Run a full reservoir of pure white vinegar through, and then a full reservoir of water, "brewing" and dumping one cup at a time. You might have to do two reservoirs of vinegar if you've never rescaled it before.
May 23, 2012 | Keurig Elite B40 Coffee Maker
I set the brew size on the Keurig, but can't figure out how to get the lights to stop blinking and make the coffeemaker actually brew me a cup of coffee. I've held down the brew button, thinking that would...
the blinking blue lights, means the water level is low...BUT sometimes it sticks, if the tank is not clean..its that round disk, on the side of the water tanks that sticks..try resetting the tank..set set the default brew size..goto menu, then goto brewsize to set the default size...when it says ready to brew..then you can select the size...
Dec 18, 2010 | Keurig B70 Coffee Maker
I am interested in purchasing this 6 cup brew station, but all pics I see use travel mugs. Can it be used with regular 10 -12 oz ceramic mugs for home use? How about 6 oz cups that match Corelle...
How does the coffee get into the cup? If it brews directly into the cup then the amount can be controlled by how much water you put into the maker. If it is a 6 cup then it must hold the coffee in a reservoir. Do you have to push and hold a button to dispense the coffee or do you push and wait for it to fill your cup? If it is the latter then it will need to know how large or small the cup size is. Is there a setting for that? If it is a push and hold method then you control the coffee flow so size is up to you. As far as it being a travel mug or ceramic mug as long as the mug will fit in the maker and sit securely under the nozzle then it shouldn't matter what kind of mug it is.
Feb 20, 2010 | Hamilton Beach 48274 BrewStation 6-Cup...
When I run water through the Keurig, it works fine, but the moment I put in a coffee, it balks, sniggers and refuses to brew. I think there must be something wrong with the perforation -- as though it...
Check the needle inside the k-cup reservoir to ensure it is clean and not clogged. You can completely remove the k-cup reservoir by pushing up from the bottom (where it normally dispenses into the cup) and it should pop out easily. Wash it out with hot water and check the needle for any debris. The manufacturer even recommends carefully inserting the tip of a small paper clip into the needles to push out any debris if needed. Then replace the k-cup reservoir by aligning the arrows and snapping it back into place. Lastly, brew a cup of just hot water on the largest brew size without a k-cup. This should further help clean out any debris or obstructions. Then try to brew a new k-cup as usual and see if the problem is corrected. Hope that helps...best of luck!
Dec 15, 2009 | Keurig B60 Coffee Maker
My brewer will not let me change the brew size.
I had the same problem, contacted Keurig and they suggested the descale procedure, which did not work. I was able to resolve the problem however.
First I went through a gallon of white vinegar, without results. Then I did the following:
Went to Walmart and bought "Brew Rite". Tried 8 cup mixture (8 cups of water, two tablespoons of mix), did not work. Being persistant, put in another 8 cup mixture, and when the reservoir emptied of the mix I unplugged it and let it sit 2 hours with the mix in it and then put in clear water. By the time I got half way through with the clear water, the device started working properly, no problems since.
Jun 10, 2009 | Keurig B70 Coffee Maker
Keurig Platinum B70 Coffee Maker Logo
621 people viewed this question
Top Keurig Coffee Makers & Espresso Machines Experts
Lisa
Lisa
Jason
Are you a Keurig Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
