Question about Lite On LH-20A1H DVD RW Dual Layer Burner
LiteOn Dual Layer DVD driver won't read burned double layer DVDs
I recently burned two dual layer DVD discs with a LiteOn SHM 165H65 Burner.
I had to put on a new installation of XP after that and now it won't read the dual layer discs I recently burned on it. Can you please advise?
  • 2 more comments
  • brucern Mar 29, 2008
    That's a good point. I burned them with Roxio 10 and it may have been set by default to be left open. SO that may be my problem. I wonder if I can check that or close them somehow to make them work ok.
  • Anonymous Jul 08, 2008
    no recognize
  • Anonymous Mar 06, 2009
    Ma i ja imam sličan problem, narezao sa na jedan računar koji ima neki drugi rezač ,proverio i tamo čita, ali neće da čita na mom Lite on dh 20a1s.
  • Ronald Homer
    Ronald Homer May 11, 2010
    when you burned the disks, did you leave them unfinished, so that more data could be added later?
    In general, if you don't finish the disk, only the computer and software that created the disk can read it.
5 Suggested Answers
Boggsj
  • 20 Answers
SOURCE: Can't Burn Dual-Layer Disks
First, be sure your DVD burner is capable of burning dual-layered discs- Second, it may be rather an issue of copy protection on the disc. Have you succesfully copied commercial DVD's in this fashion? I'm unsure if I'm allowed to mention any software that might assist you in that regard- google is your friend.
Posted on May 22, 2007
  • 55 Answers
SOURCE: internal dvd writer not reading/writing dual layer dvd rw
try different type of media
Posted on Mar 30, 2009
SOURCE: My HP Lightscribe 1040p does not recognize
solve the problem for because i want to copy cd.it has not be workink since 3 days.
Posted on Aug 21, 2009
  • 108 Answers
SOURCE: DVD recorded refuses to read dbl layer dvd it just burned
try burning the dvd's at a lower speed, most of the dbl layer drives have similar type of problems.
Posted on Jul 29, 2010
HL-DT-ST DVDRAM GT51N ATA CAN IT BURN DUEL LAYER DVDS
If it is not a dual layer DVD burner then it will not burn those dual layer disc.. Sould like all you have is a ROM read only
Oct 27, 2014 | Computers & Internet
Can this device burn double layer DVD disk?
That would depend on the burner drive and if it has dual layer support built in. Look on the front plate of the drive tray and look for DL somewhere near the DVD letters. If you see a DL then it will burn double layer disc. You would also need to have blank Dual Layer DVD-R discs. It will not burn dual layers on a standard 4.6 GB DVD it would have to be an 8.6 GB DVD. You will also need a burning software that has Dual Layer burning support.
Apr 07, 2011 | Computers & Internet
Won't recongise DVD+R dual layer 8.5Gb TDK DVDs.
Most of the drives are not capable of recognising specific color medias (specifically purple), try using perl, silver media for dual layer disc
Jul 17, 2010 | ASUS DRW-2014L1 DVD±R Dual Layer Burner
Hp dual layer dvd burner with light scribe doesnt recognize the dual layer disc as dual layer
You may have to install some kind of DVD burner software such as Nero burning ROM to burn dual layer DVDs. the default windows CD burner does not recognize dual layer disks. You can also use this free software for burning dual layer disks
http://infrarecorder.org/
Dec 04, 2009 | Computers & Internet
What does "multi layer support" mean. Does it write multi layer discs? or is it able only to read them? Also, what is a lightscribe?
Multi-Layer support means the drive can Read/Write a Dual-Layer discs.
Lightscribe means you can create a label on a disk.
Check these Links fro more information:
http://en.wikipedia.org/wiki/LightScribe
http://www.lightscribe.com/gettingstarted/index.aspx
Good Luck!!!!!!!!!!!!!!
Sep 18, 2009 | HP Pavilion dv1000 Notebook
How to burn dual layer dvd with windows dvd maker only 150 minutes pie showing
Everything is the same except you have to choose "DVD-R 9.0G" at the bottom of the DVD maker window. R4.5G is single layer and 9.0G is dual layer.
Let me know if you need more help,
Sai.
Apr 02, 2009 | ASUS P5GZ-MX Motherboard
Hi : I have a HP Pavillion a1218n (P4) computer that is about three years old. I would like to burn data to 8.5 GB Dual Layer - Single sided DVD storage media disks. My CD/DVD burner : burns, flip, burn...
Greetings,
Your dvd drive is not capable of burning a dual layer disc. You need to have a burner that is capable of sending the laser through to the second layer of the disc. That said you can get a DL burner for around 30 dollars. Click HERE to see one from Newegg.com.
I am not sure what you mean by 'burns, flip, burn dvds.' but if you make another comment I will respond.
Take Care,
-WN
Aug 30, 2008 | HP Computers & Internet
HP DVD 740e wont burn Dual Layers anymore!
Try re-installing the software associated with the burner, so it installs the necessary drivers and files needed for the burner to work according to your needs.
Also check the connections and cables... sometimes moving it around causes the cables to loose some contacts.
Hope this helps...
Feb 26, 2008 | HP DVD 740VI 16X16 Dual Layer LightScribe...
Lite On LH-20A1H DVD RW Dual Layer Burner Logo
546 people viewed this question
Top Lite On Computers & Internet Experts
Rommel Balcita
Gbenga
William Alequin
Are you a Lite On Computer and Internet Expert? Answer questions, earn points and help others
