Question about Cell Phones
My samsung delve keeps flashing a telephone and a red arrow and i'm not doing anything. it's taking airtime for no reason. is there anyway i can fix this??????
  • 2 more comments
  • dafortune_qu May 06, 2010
    i've tried that and it continues to do it.....the symbol means data call. i've takin the battery out like 5 times.....
    ok well hoe do i reflash it?
    how do i flash it?
  • dafortune_qu May 07, 2010
    so i just download it and plug in my usb cord and thats all?
  • 10,515 Answers
It seems that this would need Flashing ( Re-Installation of Firmware ). The Only thing you could so is to Pull out the Battery for Few Minutes and then Put it Back in it. This would Reset the Memory of the Phone.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on May 06, 2010
  • 2 more comments
  • taran_2005
    taran_2005 May 06, 2010
    Thanks for your response!!
    In this Case, it needs Re-installation of Software.
    85 - 90 %, are the chances that this is a Software Corruption and it needs to be Re-Flashed.
    Hope i helped you.
    Thanks
  • taran_2005
    This is a Specialized procedure which could only be taken care by the Repair Shop ( Special Tools are needed ). It would be a job of 30 min to 1 hour. It could be tough to Find Firmware but, i guess most of the Repair shop would have the Firmware for Delve.
    Hope i helped you.
    Thanks
  • taran_2005
    I would recommend a Technician to Re-Flash. But, i could give you an idea. For Samsung, you need to have NSPRO Software.
    1. Choose model & connect cable .
    2. Press get info .
    3. go to flash .
    4. Then select speed 115200 or fast.
    5. Use flash Bin & Tfs .
    6. Then press Auto button.
    7. Now select the folder where you extracts flashing files of desired
    model.
    8. then press write .
    9. It will start flashing.
    10. Don't unplug the cable.
    11. Wait until flash completes.
    12. It will take 10 ---- 15 minutes for flashing .
    There is some more Details that you need to Follow.
    Hope i helped you.
    Thanks
  • taran_2005
    taran_2005 May 07, 2010
    But, the main issue is, there is a Proper technique to Install it and you need to have the Software for this Phone which would NOT be an easy task, i could say, next to NIL.
    Hope i helped you.
    Thanks
We have a Uniden N32 Model XDECT7055. How do I remove the red flashing light on top of all the phones.
If that is the Voice Mail Waiting indicator light at the top of the handset and on the base, you need to press Menu on the base. Use the up/down arrows to select VMWI Reset. Press Menu again to select this sub-menu. Use the arrows to highlight Yes and press Menu again. You may need to contact your telephone company to make sure that the voice mail service is still compatible with the Frequency-Shift Keying message notification. Some broadband (particularly DSL) systems can cause telephone interference. Check with the broadband provider if you need a DSL filter (or similar item) to keep the interference from corrupting the VMWI information.
The procedure is on page 17 (19 of the PDF) of the manual for the Uniden XDECT7055. This is available here: https://www.uniden.com.au/resources_main/pdfs/XDECT_7055_3WP_OM.pdf .
I hope this helps.
Jul 23, 2016 | Uniden Cordless Phone
Tip
Samsung Delve Manual Download
Download Samsung SCH-R800 Delve Manual
Have you misplaced your Samsung Delve Users Manual?
Would you like a digital, searchable, pdf version of the Samsung Delve Users Guide?
Follow this link (& click FREE) to download a pdf version of the Samsung Delve Users documentation.
I hope that helps.
on May 06, 2010 | Cell Phones
I try to call my safe link phone says check call restrictions 34,how to I fix this!
Did you make at least one call per month on the tracfone? If not this maybe one of the reasons the call is restricted. You may have to manually receive your minutes for the month by: Pressing the menu key, when the prepaid menu appears press select. Go to redeem airtime or add airtime. If your screen displays a message scroll down and press ok until you see Card# or Airtime Pin. Enter 555 then press enter. If it says promotional code select no. Make sure you keep your safe link phone on to receive your minutes and see if that fix the problem. If that doesn't work you may have to call safe link at 1-800-378-1684.
Best Regards!
Feb 25, 2015 | Samsung Tracfone Sgh T105g Cell Phone...
Sony bravia KDL-46EX725 6 flashing red light
Check the power supply. IT might have bad caps.
Aug 30, 2013 | Televison & Video
A red lightning arrow keeps flashing on the screen and the camera isn't doin anything,what can the problem be?
Hi.
A red flashing lightening bolt can mean different things on different camera's. The most common are that you are too far away from the object you want to take a picture of. That the flash on the camera needs to be turned off and that the flash itself is charging up and won't allow a picture to be taken.
Try turning the flash off and see if it will let you take a picture.
Regards.
May 01, 2011 | Cameras
My samsung delve screen in unresponsive
Hi Jordan,
The problem of your phone is the inner touch pad of your screen,probably there is no more contact between the inner touch pad and the outer touch screen of your phone,
Perhaps the inner touch pad is bad and needs replacement.
This is a good solution;
The samsung delve is a very fragile and sensitive phone that needs adequate expertise,so i'll suggest you consult the nearest mobile phone engineer to help you fix it.
Take care
Mar 18, 2010 | Samsung Cell Phones
What does a flashing red arrow mean? And the flash isn't working all of the time. Is there anything i can do to fix this problem?
Could be not enough light to take a picture, low battery, auto focus hasn't completed, etc.
This will help:
Here it is for free! Read the manual, just for your camera
http://www.olympusamerica.com/cpg_section/cpg_support_product.asp?id=1262
Dec 20, 2009 | Olympus FE-190 Digital Camera
Having trouble watching live tv on samsung delve
I had the same problem when using The Samsung delve, the problem occurred while trying to download yahoo messenger to my phone.
Heres the solution ...simply go to your browser settings and uncheck the box that says Java.
This solution should also work with other model phones
Dec 02, 2008 | Cell Phones
Remote control
I had the same problem.  The problem is strange and seems to be with the receiver in the TV and not the remote control.  The reason I say this is that when this first happened my Samsung brand DVD could actually control the TV.  This then also failed, but still works fine with the DVD player.
Anyway there is an even more bizarre fix to all this......
- Remove the batteries from your TV remote. - Press and hold the red (ON/OFF) button for at least 1 min. - Replace the batteries and hey presto!!
I know seems far fetched but I found it on the Samsung website and it does work.
Nov 16, 2008 | Samsung AA5900213A Remote Control
Cell Phones Logo
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
