Question about Maytag Dryers
MDE/MDG16 coin drop counts coin down then reset at 1.50
OK boys and girls i got a problem on a costumers dryer and i cant figure it out, i tried with whirlpool what a joke that was.
the dryer is about 4 year old, i first cleaned the coin sensor, and passed some quarters thru it and it counted down to 1.00 then reset it self to 1.50.
I took apart and cleaned the coin drop. same thing. i did everything i could think of.
I then took the coin drop and sensor out of the working just fine washer next to the dryer and swapped it out. SAME PROBLEM BOYS AN GIRLS.
so i came to the conclusion the micro processor was defective. i replaced it with a brand spanking new one FSP number 3300005.
i then dropped a few coins in it it did it again. then it stopped resetting and worked fine and i maxed it out with coin and dryer time and it appeared to work just like it should.
now i get a call and it is doing the same thing.
I told my account i would come back tomorrow , so i hope i can get an answer tonight the 5-5-2010. why this rig is counting down a few coins then resetting and sometime not even registering coin movement.
I asked my buddy from MO that has a repair biz in Springfield MO and he wasn't really sure wither
(1)I dont think it to be a sensor since the other one from washer did same thing.
(2) can the coin drop be messed up even thou it is working fine, and maybe not letting the coin run the correct speed to the sensor and then throwing it off. but then again it did the same with the washer coin drop.
(3) could there be a bad wire??
(4) the door switch works fine.
Mike
jsrock516
  • 5911 Answers
SOURCE: Coin in dryer
The coin is probably rattling against the blower fan. First, unplug the dryer or turn off the main breaker. There are live voltages present inside a dryer even with the power shut off. Then, follow these steps: 1. Take out the lint screen. 2. Remove the lower kick panel under the door. There are a couple of screws under the front. The panel should pull straight down then come off. 3. Remove the blower fan housing. There will be 2 to 3 screws holding it in place. NOTE: If you did not take out your lint screen in STEP 1 you will know why I told you to take it out. The blower fan housing won't come off with the lint screen in place. Once you have the panel off you will be able to access the blower fan, and anything else that as gotten trapped inside the housing. This would be a good time to clean as well. Reassembly in the reverse order of what I just explained to you. Good luck and I hope this helps you.
Posted on Jul 31, 2007
  • 94 Answers
SOURCE: not heating
Check the exhaust vent and make sure it is completely cleared out.
Posted on Oct 21, 2007
SOURCE: kenmore dryer. 80 series. 6 years old.
Sounds like there is dirt and or lint in the fire eye that is used to keep the gas on. Find that, clean it, and try again.
Posted on Apr 27, 2008
SOURCE: longest 6 minutes ever
I wiped off the two rows of sensors located behind the lint trap inside the drum. Now my dryer shuts off at 0 minutes. The clothes are still a little bit damp so I let the dryer run for 10 more minutes. Try it before replacing the computer board.
Posted on Apr 29, 2008
appldoctom
  • 311 Answers
SOURCE: No heat and will just keep running
lets see hear,..when your dryer starts do you hear two clicks or one.the first click is the motor centrifugal switch the second is power going to the gas valve and energizing the coil.if only one click.you need to check the fuse in the back of the dryer .its white ,i call it a missile and it has two wires too it .you can put those wires together and isolate with tape and if problem unit will run.if that was the problem you need to make sure all venting is clean also inner dryer air channels,but it sounds like you checked those.if two clicks your ignitor may have failed.you check that with a volt meter 110 volts i hope that gives you somthing to run with . God bless ,tom
Posted on Jan 23, 2009
Where can I get clothing options for rave party?
aby st vinnies, or salvo clothing shops -opp shops
Jun 14, 2017 | Washing Machines
Where can I find a traditional swiss girl skirt and shirt?
Did you mean like a costume? here\'s a link: http://www.costumesupercenter.com/sexy+costumes-beer+girls.html
Jan 10, 2013 | Clothing
Where i can get kid's costumes for my little daughter?
I found kid' costumes for my little boy from mubuy.com. There are all kind of costumes. the one i have bought was very special. my son loved it very much. He said the costume made him very special that day. I think you will found a special and beautiful kid costumes for your daughter from there.Good luck to you!
Dec 25, 2012 | Toys
Speed queen commercial dryer model sdg109wf, the coin compartment is stuck because of compartment was full, after emptying the coin slider doesn't come out so we cant use the dryer. what is the...
Oh your bringing me back to the early days of my appliance repair career when i only serviced coin operated washers and dryers. Not in the coin box but the cover on top where you would get access to the timer is a bolt that holds the coin slide to the coin box asm. remove that bolt(if i remeber from 25 years ago its a 5/16th inch hex head and brass colored) and the coin slide will come out and then gotta kinda genlty presuade it in with a hammer so the coin will drop through or pull on the handle ya would push, to free it up and remove stuck coin
Aug 20, 2011 | Dryers
D5 (blocked coin 1 or coin drop control failure) is displayed yet the dryer is not coin operated
Try unplugging the dryer and wait 15 minuites and plug it back in. This should reset the computer.
Feb 03, 2010 | Dryers
Maytag coin op dryer timer programming for mde-16cs
The maximum run time on this machine's timer is 54 min. There is an adjustable peg on the white plastic index wheel which you can adjust anywhere from 30 to 54 min. For example peg in position E is 30min, D is 36min, C is 42min, B is 48min or for 54 min you have to remove the adjustable peg completely, but don't lose it in case you want to change the time in the future. If it is already in the Max "A" position and shuting off early you might have to change your torsion return spring. Hope this helps
Jan 06, 2008 | Maytag MDE16CS Electric Dryer
Dryers Logo
43 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
