Question about Clarion DXZ445 RB Car CD Player with Remote Control (Factory Refurbished)
I have a clarion dxz445 on the dissplay it shows amp/grd but my amp has a good ground and good conntions then it shuts off the sound for the radio,cd but if i shut it off then turn it back on the sound is there but when i swtch it to the cd it shows amp/grd and is this tell me the radio is bad or what
4 Suggested Answers
kenw392
  • 2226 Answers
SOURCE: why does my radio say amp grd when there is no amp
sounds like you need to check your speakers and/speaker wires to make sure you don't have a short to ground or bad speaker. if those check out, you may have a bad output ic inside of the deck.
Posted on May 31, 2010
  • 222 Answers
SOURCE: The Clarion radio in my vehicle has the word AMP
Is this a newly insalled one? check your wiring's, you may be lacking ground connection.
Posted on Jun 08, 2010
  • 35 Answers
SOURCE: how to set clock on DXZ445 Clarion
Setting the clock 1. Press and hold the [T] button for 1 second or longer to switch to the adjustment selection display. 2. Press the [ '<< ] or [ >>' ] button to select "CLOCK". 3. Press the [ >'' ] button. 4. Press the [ '<< ] or [ >>' ] button to select hour or the minute. 5. Turn the [ROTARY] knob clockwise or counterclockwise to set the correct time. ∗ The clock is displayed in 12-hour format. 6. Press the [ >'' ] button to store the time into memory. 7. Press the [T] button to return to the previous mode.
Note: • You cannot set the clock when it is displayed with only the ignition on. If you drain or remove the car's battery or take out this unit, the clock is reset. While setting the clock, if another button or operation is selected, the clock set mode is canceled.
Posted on Nov 09, 2010
When i turn stereo on and there is no sound and AMP GRD comes up. how do i sort this out
The amp needs a ground green wire. Attach it to a metal object with a screw. The wiring harness will have a green wire sometimes with a factory installed ring on it to be able to attach it to a ground
Apr 07, 2013 | Clarion CZ109 Car CD Player
ITS SAYS AMP GRD
All you have to do is press the source button for 10 seconds till the power goes off and it only shows the time. Then turn it back on. It should be working then.
Feb 23, 2011 | Clarion DXZ275MP CD Player
Why does my radio say amp grd when there is no amp hooked up and it was playing just fine tell now
May 30, 2010 | Clarion DXZ438R CD Player
My clarion cd player in my boat was working fine now it says amp grd. I have looked but i see nothing unhooked what can i do to get sound out of my speakers?
Remove all the speaker wires.
Power the radio back on and verify it is not the radio at fault.
If it powers up, check the speakers with a Digital Multimeter set to OHMS 20x.
Each speaker should have a resistance of 4 ohms. (or 8 in some cases)
Any variance (+/- .5ohms) means the voicecoil is blown, and replace that speaker.
Thanks for using FixYa - a Very Helpful rating is appreciated for answering your FREE question.
Jul 14, 2009 | JVC AM FM CD DET FACE CAR STEREO
Installed and no sound or nothing
Im guessing you have an amplifier if not check the cd player ground " AMP GRD" means amp ground is faulty. In the event that you do have an amplifier check that ground wire as it's most likely the problem.
Feb 25, 2009 | Clarion DB285USB Car CD/ MP3 Player
Ihave power but no sound
hi bign,
try the following things:
1:Try checking your ground connections, if they are good, then try regrounding the head unit to some bare metal in the dashboard, you could have a problem with the factory ground.
2:try looking at your speaker connections, sounds you have a wire grounding,try disconnecting all speakers and see if it does it. If not, try connecting one at a time, see if you can single out the speaker thats causing the problem
and also check to make sure the speaker terminals are not touching any metal, which is unlikely, because they are factory speakers.
god luck! and please rate this solution!
Feb 13, 2009 | Clarion DXZ375MP CD Player
Car Audio & Video Logo
99 people viewed this question
Top Clarion Car Audio & Video Experts
xxxxxx xxx
Marco Avila
Marco Avila
Are you a Clarion Car Audio and Video Expert? Answer questions, earn points and help others
