Question about Video Cameras
Can not delete movies from memory stick pro duo. I backed up the movies from the card and I went through the motions of deleting them from the card on the camcorder and it still says ''memory stick full.''
  • 74 Answers
Delete them in the computer instead. then clear trash / wastebin before connecting it to the camcorder
Posted on May 06, 2010
Camera keeps telling me to reinsert the memory card. I've tried to new cards. When I put the memory card I was replacing because it is full, it goes back into the camera just fine.
As a last resort you could copy the full card to a computer and then delete the pictures on the card and use that again.
Here is the error list from the camera manual.
This is all I can suggest from here.
"Reinsert the Memory Stick Error"
Insert the "Memory Stick Duo" correctly.
The inserted "Memory Stick Duo"cannot be used in your camera
(See below).
The "Memory Stick Duo" is damaged.
The terminal section of the "Memory Stick Duo" is dirty
Compatible cards.
Memory Stick Duo (without MagicGate)
Memory Stick Duo (with MagicGate) *1 *2
MagicGate Memory Stick Duo *1
Memory Stick PRO Duo *1 *2
NOT compatible
Memory Stick (without MagicGate)
Memory Stick (with MagicGate)
Memory Stick PRO
Some Memory Stick Duo have a write protect switch on the back.
You cannot record, edit or delete images if you
slide the write-protect switch to LOCK with a
fine-tipped object
*1
"Memory Stick Duo", "MagicGate Memory
Stick Duo" and "Memory Stick PRO Duo" are
equipped with MagicGate functions.
MagicGate is copyright protection technology
that uses encryption technology. Data
recording/playback th
at requires MagicGate
functions cannot be performed with this
camera.
*2
Supports high-speed data transfer using a
parallel interface.
Oct 12, 2014 | Sony Cybershot S650 Digital Camera
The DCIM folder was deleted from my sony memory stick. How can I relaod this?
Assuming this is for a camera, put it back in the camera, using the camera's set up menu, re-format the card. (This deletes all data so make sure you've removed any photo's you want to keep before hand) Once completed, take a photo, the file system should be re-established.
Apr 06, 2011 | Sony 1GB Memory Stick PRO Duo Memory Card
Not able to copy movies on Sony 8GB Memory Stick Pro Duo for PSP
Before you go throwing any old video file onto your PSP, make sure you have the following items:
  • The PSP. This is self-explanatory.
  • The .MP4 video files.
  • Video conversion software to convert non-MP4 files to MP4, the format the PSP reads.
Oct 20, 2009 | Sony 2GB Memory Stick PRO Duo Memory Card
My camera tells me it's full when it shouldn't be. I have a 2gb sony memory stick pro duo for my Sony Alpha 100 camera. Today, I shot about 80 photos and it said it was full, but I had just deleted all...
hi, sometimes old photos tend to stay inside due to some defect or settings. instead of deleting photos. format the card once before you start clicking the photos. formatting can be done in PC or in your camera. if this does not solve the problem. please revert back to us. thank you. sweet rascal
Oct 18, 2009 | Sony 2GB Memory Stick PRO Duo Memory Card
I can't delete files from my memory stick on my cell phone
you need to go into the media folder on your phone and then look for option to go to card, then when you are in the card folder look for options, then hit options and look for option to format card, hit format and it will probably give you a message saying are you sure because if you do this it will delete all the files on card, hit YES! and then it should delete all the files and be good to go!!
Jun 19, 2009 | Sony 4GB Memory Stick PRO Duo Memory Card
Memory Stick Pro Duo says it's full when not - photos to iMac
move the auto install file then reformat the flash drive as fat.
Apr 06, 2009 | Sony 2GB Memory Stick PRO Duo Memory Card
My memory stick memory problem
I am not real familiar with this type card, do you know if you can format it like any other card? Sense you have already deleted everything on it( because formatting would delete) try putting you card back into your computer, to to my computer and find where it is located( which port) right click and see if it gives you an option to format, if so, try formatting it and it should bring it back to the state as if you never put anything on it. It is always good too format any memory stick ever so often.
Hope this helps.
Mar 28, 2009 | Sony 1GB Memory Stick PRO Duo Memory Card
Memory stick pro duo won't record pictures
stick in computer and reformat the memory stick but dont let comp add anything to it
Dec 06, 2008 | Sony 2GB Memory Stick PRO Duo Memory Card
Importing data from stick to computer - deleting data on stick
Yeah, all you have to do is delete all the pictures on the card. It's easiest to do on your computer, not the camera. Just put the memory stick back into your computer and find all the pictures and select and delete them. If you've already transfered them to your computer then don't worry about it. If you delete the photos off the stick, they will NOT be deleted from your computer so just go ahead and do it.
May 24, 2008 | Sony 2GB Memory Stick PRO Duo Memory Card
San disk memory stick pro duo 1.0 GB
is the movie downloaded to your sons device ? and the only way that you can erase the entire memory disk is if you do it from your camera you cant delete the files from your device send me a message and i would be able to help ya out further
Aug 13, 2007 | SanDisk Memory Media
Video Cameras Logo
96 people viewed this question
Top Video Cameras Experts
Are you a Video Camera Expert? Answer questions, earn points and help others
