Question about Microwave Ovens
I'm replacing a regular 40 Amp Breaker to my stove,with a 40 Amp GE shunt breaker. Using a number 14/2 romax wire,which is connected to my fire suppression above the stove,do in connect the two lead wires on the shunt trip breaker to the positive line on by 14/2 grade wire?
  • Microwave Ovens Master
  • 12,061 Answers
A Shunt Breaker works, and is wired, just like a normal circuit breaker. Bur, with one additional function. A shunt-trip breaker also has a built-in magnetic coil that can be energized externally to trip the breaker. This is an additional pair of wires, as they are essentially, "Signal" wires, they do NOT have to have the same current carrying properties that the main Wiring used, Basically, a "Breaker" sits in the Phase Wire, and using a pair of suitable rated Contacts, Joins, or disconnects, the Power form the "Hot" side to the "Cold" side. Now the extra pair of wires, is basically a "Switch" or an Activator. as such, you could use any convenient wire, so, yes you could indeed use that 14/2 wire. This circuit, is basically, a separate circuit. Whose only function is to externally "Trip" the breaker, as in when the "Fire Protection System", "Senses, or detects" a Fire, it will trip the breaker, cutting the Power to the Stove. By putting a Voltage, onto this magnetic coil, and trip the breaker. One lead is Plus, and the other Negative, Always meter out you connections before powering up, always check, between each wire and Earth, it should be infinity, on your meter, set to OHMS.
Posted on May 06, 2010
The microwave trips the breaker when used twice in a row.
First, verify that the appliance is the problam or not.
Get a clamp-on ammeter, such as this one: https://www.walmart.com/ip/Digital-Clamp-Multimeter-AC-DC-Voltmeter-Ammeter-LCD-Ohmmeter-Tester-Meter/272114348?wmlspartner=wlpa&selectedSellerId=7754&adid=22222222227092377675&wmlspartner=wmtlabs&wl0=&wl1=g&wl2=c&wl3=213509462359&wl4=pla-346089952276&wl5=9001910&wl6=&wl7=&wl8=&wl9=pla&wl10=115794707&wl11=online&wl12=272114348&wl13=&veh=sem
This can tell you right away if the appliance is drawing too much current.
A loose connection in the screw terminals on the outlet can cause the appliance to draw excessive current. If you house was built in the 70's, you might have aluminum wire. Sell the house and move since aluminum wiring is no longer legal to install due to the extreme fire hazard aluminum wire presents. Seriously, if you have aluminum wiring, then every junction needs to be checked. Every screw terminal, every wire nut.
Finally, you could have a bad circuit breaker. If the clamp-on ammeter says your appliance is drawing 10-Amps and the 15-amp breaker trips, then replace the breaker.
WARNING- If you don't know what you are doing around lethal voltages, hire an electrician.
Oct 28, 2017 | Frigidaire Microwave Ovens
We turned on our oven last night and it heated up to 345, wanted to get to 400, then my wife saw smoke form the right hand front of the inside of the oven. I wanted to check the element, but can't figure...
I am assuming you are referring to a conventional stove. First shut off power to the stove at the breaker panel. (either a 40 or 50 amp breaker). Check to see if the elements come on before proceeding.
Slide out stove and unplug it. Look on the back. There will be a vertical piece of sheet metal with 1 to 3 screws or a large flat panel with several screws (1/4 Inch socket). Remove this panel to reveal the leads to the bake element.
remove the leads. Then remove the two screws inside the stove (1/4 inch socket) to remove element. The model and serial for the stove should be located by sliding the drawer out at the bottom of the stove on the left side.
You will need this number for the correct element. They run about 20 dollars typically. Hope this helps.
Feb 17, 2011 | Microwave Ovens
I have a whirlpool stove and one of the burner doesn't work but the light on switch works. What could be the problem and how can I fix. Help pls.
1.TURN THE POWER OFF TO YOUR STOVE! In most houses, the electric stove is on it's own circuit breaker. If you are in an older home, you're probably lucky you even have a stove...just kidding! If you had your kitchen updated, every electrician should have wired your stove to its own circuit breaker. Shut off the circuit breaker.
2.Remove all the burners and catch plates under them. You are going to lift the top of your stove up. Once you've done that, see what kind of receptacle you have. You'll now have to shop around to find the part. The local appliance store charged us way too much. Lowe's or Home Depot might not have your parts, or they might. Amazon might have your part and if they don't, they will direct you to someone that will. We could have saved half the purchase price if we'd gone there in the first place.
*A quick note* The receptacle is wired to the switches at the front of the stove. They complete the entire circuit, so that is the only thing you need to worry about--from the switch to the receptacle.
After the stove top is lifted, you will find another tray under it. If the wires from the receptacles go under the tray to the "on" switches at the front of
your stove, you'll have to lift this tray up as well. Remove the tray and any other panels you need to in order to get to the switches.
3.Follow the wires, which should be color-coded for that stove top burner, until you find the switch it hooks to. If you have not purchased the parts yet, go ahead and disconnect the wire from the switch and pull the receptacle from it's aluminum cradle. You'll want these parts to take with you to find their replacements.
*note* Your new wire receptacle should consist of the housing for the burner to fit snug into, and two wires that extend from the other end. Electricity works in a circle. If the circle is broken, you have a short and that is where the spark comes from- your electrical current was trying to reach the other side and sparked to get there.
If you do have the parts, compare them to the old ones to make sure they are the same. Nothing worse than spending time on a repair with the wrong parts.
If you have the RIGHT parts, find the correct end of your wires and just slide it over the terminal at the switch. They might be the screw types. Whatever you have, connect it. It does not matter which one went where. As long as you are using the empty wire terminals you just uncovered with the old wires, you are completing the circle.
*Note* I have seen some receptacle kits that do not give you enough wire and require you to splice wires together. Not only is that a bad idea, but does not conform to electrical codes requirements and could result in fire. If the new equipment did not come with long enough wire to reach all the way from receptacle to switch, purchase a longer wire at your local hardware store. For a few pennies more you could be saving your family's lives.
4.Once you have hooked the receptacle ends to the switch harness, tie down the wires alongside the wire bundle until you get to the end.
5.Attach your burner receptacle to the aluminum clamp.
6.Attach your aluminum clamp to the stove top.
7.Screw down all the pieces you removed- anything covering the switches and the bottom tray. Put down your stove top and put in place all the shields and burners. Turn the circuit breaker back on for your stove and try it out!8_10_2012_8_42_55_am.jpg
Feb 12, 2011 | Microwave Ovens
15A breaker tripping; Is this the right size breaker for the unit?
The breaker is sized according to the size of the wire used in the circuit. The breakers task is to protect the wire from an over current.
The allowed sizes are
#14 wire .... 15 amp breaker
#12 wire ..... 20 amp breaker
#10 wire .. 30 amp breaker
To check if the oven and circuit are compatable .. run an extension for the oven to an outlet outside the kitchen and see if it holds.
Please Vote !!
Mar 08, 2010 | Hotpoint RVM1435 Microwave Oven
Wiring a microwave
For just the microwave, use a 20 amp breaker at 110V.. Wire the branch corcuit with #12 wire. While you MIGHT get away with lesser rating, it is not worth the gamble. Microwave ovens draw reactive currents so need to be safe.
Dec 31, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
GE Spacesaver microwave trips the circuit breaker
Since power = voltage X current, 1.58kW / 120VAC = 13.166A
So this unit should be fine on a 15A breaker unless the breaker is bad, the wiring or a connection is loose somewhere between the breaker and the microwave, or the microwave's magnetron or high voltage transformer are failing and drawing extra current.
Microwaves should really be on the own separate breaker if at all possible. Plus, the more a breaker trips, the more work out it gets.
Have you measured the voltage at the outlet? If that's off, current and power will be affected. It should be about 110-125VAC.
A good power test for outlet and wiring integrity is a toaster, toaster oven, or hair dryer rated at about 1500 watts.
If it doesn't run and heat steadily, then there may be a problem with the house wiring or breaker.
If it passes this test, the problem is likely in the microwave.
We're happy to help and we appreciate your thoughtful rating of our answer.
Jan 09, 2008 | GE JVM1190 Microwave Oven
Maytag Microwave Power Outage - Model MMV5000BAB
Found this under GE instead of Maytag, but can answer for you here.
It may be the internal fuse, but more likely it is the thermostat on the magnetron.
You can find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
If you or a friend decide to work on it, we have *critical* safety, disassembly, and troubleshooting info at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk
Nov 21, 2007 | GE JVM1190SY/WY/AY/BY Microwave Oven
Microwave Ovens Logo
32 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
