Question about Plantronics Explorer 220 Bluetooth Headset Wireless Headset
Need pin# need pin #
    President:
  • 1,118 Answers
For all the bluetooth headsets manufactured by Plantronics (except for the M1000 and M1500), the passkey (or pairing code, or bluetooth PIN) is 0000 (four zeros).
Hope it works for you.
Cheers! Carlos
Posted on May 06, 2010
Pin codes for **** at www.movieunlock.com movie i.d. 41941
need a pincode for bonus scenes id #41822 movieunlock.com
Apr 11, 2014 | Cameras
Building custom parallell adapter from j45 to b25 need colr code
If you mean DB25 connector you can try this:
RJ 45 Pin 1 to 5 Volt power
RJ 45 Pin 2 n/c
RJ 45 Pin 3 Gnd (DB Pins 18 -25)
RJ 45 Pin 4 n/c
RJ 45 Pin 5 to DB Pin 1
RJ 45 Pin 6 n/c
RJ 45 Pin 7 DB Pin 14
RJ 45 Pin 8 DB Pin 2
More info about DB-25 connector can be found here.
Jan 07, 2012 | Epson TM Office Equipment & Supplies
2008 flhr wiring skematic
Front or rear signals and brake??
Here is rear lighting for a start. Post a comment if you need front.
2002 DYNA ALL incl FXDWG
Connector 7 is under the seat. It is the main harness to tail lite connector. The wires from main connector are:
2002 All DOM and INT Including FXDWG
Connector 7 pin 1 goes to tail lite 94 connector pin 2 = BW
pin 2 goes to 94 pin 1 = O/W
pin 3 goes to 94 pin 5 = V
pin 4 goes nowhere = empty
pin 5 goes to 94 pin 6 = BK
pin 6 goes to 94 pin 4 = R/Y
pin 7 goes to 94 pin 3 = BE
pin 8 goes nowhere = empty
Connectors 93, 94, 18, 19 are all in the tail lite assembly.
19 = Rt Turn pin 1 = V/BN pin 2 = BK
18 = Lt Turn pin 1 = V/BN pin 2 = BK
93 = Brake and running lites pin 1 = BE = Dom running pin 2 = O/W = HDI running pin 3 = R/Y = Brake pin 4 = BK = ground
2008 TOURING is the same as 2002 DYNA and also has connector 45 in tail lite assembly where pin 1 = BK; pin 2 = Empty; Pin 3 = BK = licence plate lamp
Horn has 2 wires BK = ground going to main harness and Y/BK going to pin 6 of connector [2A] which is Main to interconnect harness 12-place Molex (gray) Inner fairing - leftt radio support bracket
You need What brake system front or rear??
Front signals from [31] pin one = BK = RT turn; pin 2 = BN = Rt Turn; pin 3 = BE = DOM running lite; pin 4 = BE = DOM running lite; pin 5 = V = Lt turn; pin 6 = BK = LT turn
[32] = pin one = BK; pin 2 = O/W = DOM Front Fender Tip Lite
[73] = 1 = GY/BK = Rt Aux lamp gnd; pin 2 = GY/BK = Lt Aux lamp Grnd
Nov 24, 2011 | 2008 Harley Davidson FLHR Road king
Need main wiring schematic for 2000 ultra classic speedo,speedo reset ,tacho, wiring wires got pulled out of plugs need help.thank you
Looking at the plugs on the meter side of the harness: for the speedometer there is a three position plug. Pin #1 is Orange, Pin #2 is White/Green and Pin #3 is Black. for the Tachometer there is a six position plug, Pin #1 is Orange, Pin #2 is Pink, Pin #3 is Black/Yellow, Pin #4 is Green/Red, Pin #5 is Yellow/Red, Pin #6 is Black
Jul 19, 2009 | 2000 Harley Davidson FLHTCUI Electra Glide...
I need the wiring diagram of pump it has 5 pins coming out of pump
hello, i holding a wiring diagram central locking system,model 201,it have a 6 pin,
  • pin no.1 brown goes to ground
  • pin .no 2 black ignition on
  • pin no. 3 red permanent 12 volt
  • pin no. 1 yellow trunk lid switch
  • pin no. 2 blue driver door switch
  • pin no.3 green passenger door switch
hoping it"s help to solve your problem,ty
Apr 28, 2009 | Mercedes-Benz 190-Class Cars & Trucks
Fitting a towbar for a caravan with 13pin europlug
black socket, black 7 core wire
pin 1 yellow left indicator
pin 2 blue, rear fog light
pin 3 white earth
pin 4 green right indicator
pin 5 brown right side/tail light
pin 6 red brake lights
pin 7 black left side/tail light
Grey socket grey 7 core wiring
pin 1 yellow, reverse
pin 2 blue, supplementary feed (ignition)
pin 3 white, earth
pin 4 green live feed (battery +)
pin 5 brown not connected
pin 6 red supplementary feed (ignition)
Pin 7 black earth
On the discovery there is a purpose made plug behind the panel on the drivers side rear, behind the rear lamp
i think the relay you have bought is for lamp failure you just need a normal 4 pin 30 amp relay.
Good luck Davelee
Mar 19, 2009 | 1997 Land Rover Discovery
Want to fit a watch band. take links out.
You need a link tool. You can purchase this item on Ebay or watch parts sites. Some have a little track that you put the band on and screw a pin into the pin on the band and it pushes the split pin out and you remove the link. Pay attention to the pins on the band. You need to push out the side with the split pin that looks like a flathead screw. It sometimes is. In most cases it is a pin. When the link is removed you have to connect to the next link and push the pin into the hole again and it shoul go in the direction of the other pins. The pin should go in on the side with the split looking pins. You will need special tools: pin pusher device, a pin block and hammer with pins to hammer out the pins on the band usually. Some or most folks take classes to learn this but you may be handy and figure it out.
Dec 03, 2008 | Invicta Watches
Need a wire color code for a ford radio f58f-18c815-aa
Notice, this is from the 2005 Ford F150 Wiring Harness. Other radios should be the same or very close. From the main 24 wire connector on back of radio (C290A).
Pin 1- Light Green w/Violet stripe - Voltage always
Pin 2- Light Green w/Yellow - Accessory delay relay output
Pin 3- Light Blue w/Red - Instrument illumination
Pin 4- Black - Ground
Pins 5, 6, & 7 - Not used
Pin 8- Orange w/Light Green - Speaker, left front +
Pin 9- Grey w/Light Blue - Speaker, left rear +
Pin 10- Orange w/Red - Speaker, right rear +
Pin 11- White w/Light Green- Speaker, right front +
Pin 12- Dark Green w/Orange- Speaker, right frt -
Pin 13- Black w/Light Green- Ground
Pin 14- Grey w/Black- Vehicle Speed Signal
Pin 15- Red w/Black- Voltage supplied in Start
Pins 16 & 17- Not used
Pin 18- Light Blue w/Red- steering wheel signal
Pin 19- Dark Green w/Orange- steering wheel return
Pin 20- Dark Blue- Parking Aid mute signal
Pin 21- Light Blue w/White- Speaker, left front -
Pin 22- Tan w/Yellow- Speaker, left rear -
Pin 23- Brown w/Pink- Speaker, right rear -
Pin 24- Not used
Good Luck
Feb 09, 2008 | Car Audio & Video
Need to replace drive pin
Hi. The pin in question is a tapered pin and can only be tapped out one way. This pin fixes the main driving shaft to the planetary. Use a metal punch slightly smaller in size to the pin and gently tap out the remaining part of the pin toward the largest part of the pin. Once removed, you can install the new pin in the reverse manner. If this solution assisted you, please rate it. Good luck! ricardok45.
Jan 11, 2008 | KitchenAid KSM50PR Professional Series...
Plantronics Explorer 220 Bluetooth Headset Wireless Headset Logo
124 people viewed this question
Top Plantronics Radio Communications Experts
LeAnna Mathews
LeAnna Mathews
Level 1 Expert
shaun taylor
Michael Vincent Cruz
Are you a Plantronics Radio Communication Expert? Answer questions, earn points and help others
