Question about HP LaserJet M1522nf Multifunction Printer (CC372A)
I can't scan to e-mail on the 1522 device. I do not see a scan set up function when I HTML into the device. This device is attached to our network. I do not see any way I can scan to e-mail
  • 223 Answers
This is something that you have to set up using the scan set up button. Create a destination and update the printer.
Cheers,
Al
Posted on Aug 17, 2010
Why can't I scan to email attachment?
Without wishing to quote the obvious but: make sure you computer is turned on and your email program is active. Also check your email program is identified in the printer settings. If you are working on wifi, you may find that the scan to network (and e-mail) function is not supported and will need to be cable connected to your computer.
May 02, 2015 | Canon Pixma MX922
Hi, i got a ir3580 cannon copier and it doesnt give me an option to scan to email, it shows the message tx image set not to display..can anyone help please !
If you don't have the send button then it wont work
2sd1jiwyhgy0enk6bz++uuv7u7uo++889133+uec2opd8bcahhpotghfxcig6gnokodtwmlvknn8bpn818thyfuya9kvjsojqbav1555f8pn4qurspzoduaaaaasuvork5cyii=Make sure you have the send button available on the canon device as shown above, and fully networked, if so follow instructions below
setting up the device for scan to e-mail
1.select * head > SYSTEM SETTINGS > NETWORK SETTINGS > E-MAIL SETTINGS. You may need to scroll down the menu to find the e-mail settings
2. Fill in the required fields, SMTP or POP settings
Someone with a little IT background would help
images?q=tbn:and9gcqwahyvwfq_dazga7r3wmakfzbd5p63hemso8op0xszyghtsmvuiq
The e-mail address is for the recipient so they know where the scan-e-mail come from e.g canonscan@yourbuisnessname.com
The server address settings are important.
3.Go back to send screen to add e-mail address and test
Restart device may help sometime after changing device settings:) Good Luck
Apr 03, 2013 | Cannon Office Equipment & Supplies
I have a lexmark 464de mfp. How do i setup scan to e-mail on windows 7 on this network printer?
Multi-function printers cannot scan and then e-mail the scanned image. They can scan and then fax a document.
You need to scan the document, then save the scanned image, open your e-mail program and create the e-mail then attach the image file (file attachment) to the e-mail before you send the e-mail.
Jul 08, 2011 | Lexmark X464DE Mono Laser MFP, 38ppm A4...
Cannot access either dlinkap or 192.168.0.50 via web browser in order to set DAP-1522 up as a wireless bridge. My current internet provider is Verizon Fios using their router. Why can't I...
Assuming that all settings are still at factory defaults... It's likely that to connect to the device through the web browser or through the app, you will have to temporarily assign your PCs network card a static IP address that is in the same range as the router (for example: 192.168.0.10). The user name should be admin and the password should be left blank. Make sure to plug your router directly to your PCs LAN port with an ethernet cable.
This article on the extremetech website explains exactly how to do what you are trying to do:
http://www.extremetech.com/article2/0,2845,2329231,00.asp
In case the previous link has too much info, here's another site that simply tells how to access the manual settings of the router through the browser: http://www.paraesthesia.com/archive/2010/05/04/connect-to-the-d-link-dap-1522-access-point-configuration-manually.aspx
If you go through these steps and still can't communicate with the device, it's likely that router's default configuration has been modified and you will have to reset the router to factory settings to get it back to the defaults. Then you may proceed as listed above.
To reset (if necessary) follow these instuctions on the D-Link website:
http://www.dlink.cc/d-link-wireless/d-link-dap-1522-forget-password-you-will-have-to-reset-it-to-factory-defaults.html
I know it's a lot of stuff, but I hope this helps. It can be frustrating, but you'll get through it.
Steve G.
Mar 01, 2011 | D-Link DAP-1522 Xtreme N Duo Wireless...
I am trying to figure out how to use my Brother MFC-8440 scanner. I would like to use it to scan documents to email out. When I go to Brother.com and look at the direction book, it doesn't have directions...
It is part of the Network User's Guide (section 10) and the Software User's Guide (section 3 for a PC using Windows, Section 8 for network scanning), not the User's Guide. The directions below are for XP and Win2K primarily. Slight changes may exist with other OS versions. (Full software is not available for Win7 so the buttons on the unit will not work. You will need to launch scans from the computer only. You can use Windows Paint or Fax and Scan without needing third party software. Then attach the file to an email either in the email software or by right clicking on the file and choosing Send to Mail Recipient.)
For either use, put the document face down on the glass or face up in the ADF.
If you use a directly connected computer, you need to set the destination for the Scan to E-mail in the Control Center (section 4-4 in the Software User's Guide). Open this program and make sure the correct machine is in the drop-down menu. This program needs to be running to hear the buttons being pressed. Click on E-mail to set which program will get the scanned document as an attachment for your e-mail. You can also set the resolution and type of attachment. If you do not want to use available file formats, you will need to scan in PaperPort (or other software) and then use that to attach the file to the e-mail. Then click Scan to launch the scan from the unit. Hit Set when ready to send.
If you have the unit set up on the network, then you can enter the LAN setup in the Front Panel (or a browser). Hit Menu 6 (and then the appropriate number for the next feature), such as TCP/IP, DHCP or Static IP (these are under 1), SMTP, POP3, Mail Address (Menu 6 2). Setup the Scan to email with Menu 6 7 1 for color and Menu 6 7 2 for black and white.
This automatically sends the item to the email server or PDF as either a PDF or JPEG. Then you need register the PC that will get the file to the unit, if you use scan to email (PC). (Your version of Windows will matter for exactly where the information is: Control Panel > Scanners and Cameras or Control Panel > Printers and Other Hardware > Scanners and Cameras.) Right click on the icon for the unit and select Properties to see the Network Properties box. Go through all of this set up including the Scan To Button. Then the Control Center will launch the e-mail program when it "hears" you press Scan, select Scan to Email, press Set, then choose PC and press Set again. (or select the destination PC which has e-mail access and press Set again). Scanning will start.
If you have set the POP3 and SMTP servers and the unit can directly access them, then you can scan to e-mail and enter the recipient address. Press Scan, select Scan to Email, press Set, choose Email Server and Press Set again. Adjust the scan quality as desired pressing Set at each step. Once you go through all of the layers, the LCD screen will prompt you for the recipient's email address. Then press Start.
I hope this helps.
Jul 20, 2010 | Brother MFC-8440 All-In-One Laser Printer
Cannot connect to Dlink DAP-1522 at 192.168.0.50. Unit is plugged into home network router.
Hi. Is this to change its settings?
Plug directly in the DAP-1522.
Set your PCs network settings under TCP/IP, alternate config:
IP Address: 192.168.0.10
Subnet mask: 255.255.255.0
Default Gateway: 192.168.0.50
Give it a try.
Regards,
Nov 05, 2009 | D-Link AirPlus Xtreme G DWL-2000AP...
Scan to e-mail toshiba e-studio 205
Easy reply would be to make sure you have an email application installed on your computer such as Microsoft Outlook or Outlook Express. That will have to be setup first, and might require some information from you internet service provider. Many people think that if they have a personal email account such as Yahoo or Hotmail, that this will communicate with the scanner. The scanner program installed on your computer wants to transmit your scanned documents to an email program that is also installed on your computer. Otherwise, scan the document to your hard drive, and then attach it to a yahoo/hotmail email manually. Hope this helps clear things up.
Mar 25, 2009 | Toshiba Office Equipment & Supplies
Brother MFC 9840CDW
I'm trying to get my Brother MFC set up to scan to e-mail and open a new email with the scanned document attached. I am independant and not connected to any other service as I am a one man user operator.
Sep 10, 2008 | Brother Multi-Function Center MFC-240C...
Arc 260m network help?
You will need to use the Sharp Network configuration program. This should allow you to setup the printer for network printing. You will want to use 'manual' settings for the IP. Example
IF DHCP is used, you will want to switch to Manual and put in a 'correct' ip.
IP Address: 192.168.1.189
Subnet:      255.255.255.0
Gateway:    192.168.1.1
The Gateway will not be necessary if you do not plan to use the advanced functions to e-mail scans, and prints.
Sharp Network Administration software link
http://sharp-world.com/products/asia-doc/c/download/license_01.html?link=http://www.sharp.co.jp/print/document/download-e/utility/Sadmin.ZIP
Oct 10, 2007 | Sharp AR-C260M All-In-One Printer
Can not make bizhub c252 scanning trough e-mail feature
with scan to Email on this machine you need a mail server that is local with ftp scanning you need IIS running on either XP Pro or server OS SMB Scanning can be done but only if you are using an eithernet connection which one of these do you want do to do
Sep 20, 2007 | Konica Minolta bizhub C250 All-In-One...
HP LaserJet M1522nf Multifunction Printer (CC372A) Logo
181 people viewed this question
Seeker5211
Seeker5211
