Question about Sansui HDLCD3200 TV
Sansui HDLCD3200b Drivers for PC
I have connected a Sansui HDLCD3200b monitor to a vga cable to a Windows XP computer. I would like to install the monitor drivers so that XP knows the proper refresh and resolution rates. Does anyone know where I can download these?
Thanks
The TV has a resolution of 1366 x 768 for mine, I set the display properties to1280x768 the closest you can get to the actual 720p resolution.
Posted on Jan 23, 2009
  • fezilesihele May 23, 2012
    mine is showing not suppoted what must i do?
SOURCE:
Drivers windows xp
None are needed, Make sure the video input cable is properly
connected to the correct terminal, and that the
correct input mode is enabled. To illustrate,
when a VGA cable is connected to display a
computer screen, the PC input mode must be
enabled.
This is a 720p tv maximum on a PC is 1366x768 Use vga cable not HDMI, to connect to a PC
Manual at http://westinghousedigital.com/wordpress/wp-content/uploads/2010/06/SK-32H640G_User_Manual.pdf
Jul 18, 2014 | Computers & Internet
Haier L24B1180 24
Most new can now a days. In any case, took a quick look at your specs and simply connect to PC. Then choose input from TV. Like VGA, HDMI, depending on cable paring you choose for your PC video card. VGA is usually the easiest.
Aug 29, 2012 | Haier L24B1180 24 inches 1080p LCD 24 LCD...
Windows XP - Installed drivers from disk supplied with monitor and also downloaded from internet. Monitor doesn't appear to be recognised as touch screen - message returned from downloaded drivere -...
The touchscreen function is handled via a separate cable (you did not state the monitor model number). The VGA cable is only for providing a picture. There will be a second connection for a serial cable or possibly USB to provide the touchscreen input.
Mar 01, 2011 | Computers & Internet
Monitor only works with DVI/VGA adaptor.
if your monitor came with a disk try installing the drivers again you might still have the drivers for the previous monitor you had with your system if not try going to the manufacturers website and getting the drivers and install them
Aug 13, 2009 | Acer AL2016W 20" LCD Monitor
Computer in safe mode and monitor will go to sleep mode....help what can I do...my husband tried everything....
First, Shotdown your computer from start ,
then remove your computer power, remove VGA cable, remove VGA power cable. then
1- connect vga cable to computer.
2- connect VGA power but do not power on.
3- connect computer power on but do not turn on
4- turn on computer first and 3 second turn on your lcd.
if NOT try powering on computer then Monitor then power the computer then monitor.
IF NONE worked, YOU may have LCD that need drivers from manufacturing, some newer models required that, Specially for vista.You may use older Monitor to get drivers to computer and extracted, then you may connected, you will have solved the problem.
Goodluck
JMC
Aug 12, 2009 | Dell Dimension 4600 PC Desktop
Driver for monitor
if u r using xp sp2 ,sp3 or vista no drivers r required for any monitors as such drivers r installed by windows automatically.ok next is go to divice manager and search for monitors if ur monitor has any issues it is displayed yellow.ok even if the device manager doesnt show up any issues with monitor,u can always upgrade the drivers to the drivers that came with the monitors installaion disk that may be supplied with ur system.
Jan 17, 2009 | Sansui 19 in. LCD TV
My HP monitor (f50) has malfunctioned
Try these 2 steps if they don't work get back to me :)
Step 1. Connect the video cable and turn on the computer. What happens?
  • If the monitor screen remains blank (no startup screens or onscreen display messages), the monitor must be connected to another computer using a different cable to determine if the monitor is bad. Skip to the Step to connect the monitor to another computer.
  • If the monitor is capable of displaying boot screens but is unable to display Windows, use the following steps to set the computer to a compatible resolution:
    NOTE: Find the native display resolution for your monitor in the User Manual or in the product specifications for the monitor model. If you are unable to find the native display resolution for your monitor model, temporarily use 1024x768 for troubleshooting purposes.
    1. Turn on the computer and press the F8 key repeatedly when the first startup screen appears.
    2. If you are using Windows Vista, select Enable low resolution video (640 x 480) , press Enter , and wait until Windows opens. To set display settings that match the monitor, use the steps in the HP support document, Changing Display Settings, Background Image, and Screen Saver in Windows Vista . If you are using Windows XP, select Enable VGA Mode , press Enter , and wait until Windows opens. Continue using these steps to set display resolution. If you are using Windows 98 or ME, select Safe Mode and perform the following steps to enter into a standard VGA mode:
      1. Once Windows opens to the desktop in Safe Mode, click Start , and Run .
      2. In the Open field type msconfig and press Enter . The MS Configuration Utility window appears.
      3. Click the Advanced button, and select VGA 640 x 480 x 16 if it is available.
      4. Click OK and restart the computer.
      5. After Windows opens, click Start , and then click Run .
      6. In the Open field type msconfig and press Enter .
      7. Click the Advanced button, and remove the checkmark next to VGA 640 x 480 x 16 .
      8. Click OK . Do NOT restart the computer.
    3. After Windows opens, right-click on an open area of the desktop and select Properties (Windows XP, 98/Me) or Personalize (Windows Vista).
    4. In Windows Vista, Scroll down and click Display Properties . In Windows XP, 98, or Me, click the Settings tab.
    5. In Windows Vista, select the native display resolution size using the Resolution slider. Set Colors to Highest (32 bit) . In Windows XP, select the native display resolution size using the Screen resolution slider. Set Color Quality to Highest (32 bit) . In Windows 98 or Me, select the native display resolution size using the Screen Area slider. Set Colors to True Color .
    6. Click Apply after you have made your adjustment. The screen should blank out temporarily and come back.
    7. If you are satisfied with the new display settings, click Yes on the Monitor Settings windows. If you are not satisfied or if the screen just goes black, wait: Windows sets the screen back to the way it was before. Try another setting until you find a display configuration that is compatible with the monitor and meets your needs.
      NOTE: If the native resolution is not available, download and install updated video driver software for your computer. Updating the video driver software can add more resolutions (graphics modes).
    8. Restart the computer. The monitor should now display a full screen image in high quality. You are done.
Step 2: Connect to another monitor
Using a different cable, connect the monitor to another computer that has video. Turn on the monitor and the newly connected computer. What happens?
  • If the monitor works, the video hardware on the original computer is likely to be the source of the problems. You can try connecting the original computer to another monitor that works to update its video drivers.
  • If the monitor remains blank, repair or replace the monitor.
Dec 27, 2008 | HP Pavilion F50 17" Flat Panel LCD Monitor
The HP monitor stop working with systemax windows xp
no vga input message means that the monitor is working fine, and the problem is probably your pc. check the cable connecting the monitor to the pc. if that is ok, you ma have to open up the pc and check some components, most likely the RAM
May 02, 2008 | Microsoft Windows XP Home Edition
Connection
Your HP notebook PC probably has a VGA (aka HD-15) connector. Check page 16 of this PDF to make sure - connector #2 is the VGA connector.
Your Compaq monitor also has a VGA HD-15 connector, so it should plug directly into your laptop's port after unplugging it from the other PC.
You will still need to plug the Compaq monitor's power cable into a wall outlet for power.
If you are going to share this monitor between your notebook and the other PC, you may want to consider purchasing a Keyboard-Video-Mouse switch (known as a "KVM switch") - there are many different models - you will need one with VGA, and whether you need USB or PS/2 keyboard/mouse connections depends on what your other PC's keyboard and mouse are.
Apr 06, 2008 | Compaq TFT450 14" LCD Monitor
Sansui HDLCD3200 TV Logo
3,018 people viewed this question
Top Sansui Televison & Video Experts
matt martin
matt martin
Steve Allison
Steve Allison
Are you a Sansui Televison and Video Expert? Answer questions, earn points and help others
