External Hard Drive won't show up!
I bought a Fantom Titanium II 200GB External Hard Drive earlier this year. I have an iMac G5 with Mac OSX Tiger installed. It worked fine for the first few months, but this summer, it stopped showing up on my computer all together. I thought maybe it was one of my Mac updates, but after doing some research on that and a whole lot of fiddling, I realized it wasn't that. I've spent the last few months trying to figure out and troubleshoot the problem, but I have no idea what to do.
It doesn't even recognize it when it's plugged in for me to access it on Apple's Disk Utility to reformat it. Any ideas?
i have a seagate 100gb drive that has worked seamlessly for ages, but now it will not show up on my computer, i really need it as a lot of my work is on there. can anyone help?
I have tried to re-map the drive but if it doesn't show up I can't tell the computer what 'folder' to look into. any help is much appreciated
I have a External Hard drive that won't show on the desk top ether. I think It's too full. I've tried a number of things. Mac utilities sees it but, I can't run the first aid on it any suggestions?
  • 1 more comment
  • sfessler Mar 28, 2008
    My MY BOOK external hard drive will not show up anywhere on my computer. It did spiratically for awhile but now not at all. The fan is running, the power is on, the cables are good but it does not seem to want to boot up.
  • Anonymous May 25, 2008
    HD-HB250U2
  • homie535 Jan 05, 2009
    I have a WD mybook external and it has been working fine for the last few months but a few days ago it just stopped appearing on the desktop, firewire and usb don't work.
    Genius:
  • 1,019 Answers
i,m not too much up on Macs.
But i,m going to try my best to help you, as i do have a wide knowledge of windows operating systems.
I,d firstly suggest looking in the device manager, at what usb devices are set and configured. as the external drive is looking for a vacant usb port. try the drive(s) in another usb port if you have one. Why i state this, is that the usb slot could be configured to look for another/alternative device.
Secondly if you look in the device manager, to establish whether you have any devices conflicting. Then i,d suggest updating any drivers relating to the USB hubs where possible.
Also check in the Bios, to ensure the USB ports are enabled, this could have been changed with a software update or computer virus.
Finally try a double USB to single cable, 2x usb plugs one end, to single in the hard-drive end, i suffered a problem which the hard-drive did,nt get enough power from a single cable.
I hope this helps you resolve your problems.
Mike @ compurepair.
Posted on Mar 29, 2008
4 Suggested Answers
SOURCE:
  • 13 Answers
SOURCE: External Hard Drive won't show up!
if its usb then i have a feeling its not the hard drive thats bad i think it sounds like the case .
you can try buying another case and transfering the hard drive to it the case is around $20.00
Posted on Dec 05, 2007
i have a 500gb WD external drive and it wont show at all
Posted on Mar 30, 2008
  • 151 Answers
SOURCE: i went to fantom drives driver download page to
shouldn't need a driver for xp
Posted on Mar 15, 2010
I can not locate a driver for my Fantom Titanium II (TFD500C16) 500 GB USB Hard Drive. Do you know where?
Your device should not need drivers Fte Fantom/Titanium drives are fully supported by both Windows and Mac OS's.
Try replacing the cable or using a different USB port.
Sorry I cannot be of more help, The drive itself may be damaged, You can test this by physically removing the drive itself from the case and installing it internally to your system....If the drive functions properly, then the problem is within the board inside the casing.
Ed
Jun 08, 2010 | Fantom Titanium II (TFD500C16) 500 GB USB...
My mac G4 not recognize my 500GB external FantomDrive. HD light is on but Mac can't see it!
If you bought it from a friend, then ask them to reformat it for you as a FAT32 partition. Mac can not see NTFS, which most Windows users use since you get more space on the drive.
If it is brand new and your G4 isn't recognizing it, then I would return it for a new one. I don't trust things that aren't working out of the box, especially when they charge so much for things.
Dec 16, 2009 | Fantom Titanium II (TFD500C16) 500 GB USB...
Maxtor basics 160gb portable hard drive is showing error performi
go to my computer p[roperty then hardware -> device amnager then uninstall usb drivers from it then install aagain.
then connect your harddisk then it found.
Jun 23, 2009 | Fantom Drives Titanium II (TFD160U2) 160...
Mar 09, 2008 | Seagate (ST9100801U2-RK) (9W3638556) 100...
Drive not being recognized
Have you tried this in another PC with, say, WinXP? If it worked then it may be 1 of 2 problems:
1) Driver Issue- you may use a compatible driver and not necessarily a "Fantom" driver. WinME needs drivers for these devices unlike WinXP
2) The USB port is not giving enough power to the drive for it to run (a problem common in older PCs). I have an external USB harddisk that needs to use 2 USB ports in my old Dell laptop since 1 USB port can't supply the power it needs. The cable should have a dual-USB jack on one end, this is so you could use the power from the other USB port.
Hope this helps
Jan 20, 2008 | Fantom Titanium II (TFD500C16) 500 GB USB...
Nov 19, 2007 | Fantom Titanium-II (TFD200U2) 200 GB IDE...
Computers & Internet Logo
4,694 people viewed this question
Ekse
Marvin
Marvin
