Question about Black & Decker 19" Electric Lawnhog Mulching Mower
Reset power something shorted is there a reset button
  • 198 Answers
You might find a reset button on the motor housing---it works like a circuit breaker
Posted on May 07, 2010
Omg none of yall are fixing me so just tell me how to reset my irulu ax761 tablet and no dont tell me to hold the power and volume button down cuz it dont work???????
Turn it completely OFF. Then...
Press and hold down both the power button and the volume(-)
buttons and keep holding them down until you see some green android and some green text.
This could take as long as 20-30 seconds.
One of the lines of green text will say something like
wipe data/factory reset. Scroll to it using the volume(+) button and select it using a short push of the power button.
Another screen will come up with lines of no no no no
and line of proceed. Sroll down to the proceed line using the
volume(+) key and select it using the power key.
It will wipe the data and do a factory reset and prompt
you to reboot. To reboot press the power button to turn it off
the give it ten or fifteen seconds and press and hold the power button and it should boot into the original configuration. This could take up to a minute or two depending so don't get impatient.
Jun 22, 2015 | Tablets & eReaders
The test button on the plug in cord is stuck in and when you plug it in the reset button pops out
That sounds like the CGFI which is popping which indicates there is an excessive power draw through the item. You better have it checked out because that sounds like it could be quite dangerous! Something is shorting out in other words!
May 29, 2014 | Office Equipment & Supplies
Breaker Trips Immediately
Have a short in unit. Need to check continuity of each component to ground to determine where short is. Also make sure breaker is good.
Aug 29, 2012 | LG Electronic Window Air Conditioner
Reset button comes on after heater is running
this means that the heater is drawing more current than it is designed for. it could be a bad heating element that is shorted. the power cord could be shorted or last the reset button could be bad.
but usually it is something shorted.
Mar 28, 2011 | Heating & Cooling
Re-reset botton pw- power botton hdd led- hard disk led pw LED- power led idenfification problem help me
from the 1 pin that is single without pair..disregard that then put the pw button.. to make sure short it using a philips or long nose.. if you find the power on button...or just find first the power button by shorting the pins...
the sequnce are pw button reset button pw led hdd led..you just nid to align them to the power button..
hope i've help you..
rate...
Feb 06, 2010 | Zerus Intel Desktop Board D815EEA...
My 32in. rca sdtv wont stay on turns off as soon as you turn it on. please help as i love this t.bv. by the way it has been unplugged for at least 3 months is there a reset button to.
Something in high voltage section is shorted. check the horizontal out put transistor. take it out,ohm it out to see if it is shorted. Sometimes when the horziontal out put goes so does the flyback transformer. If the horziontal is shorted, put new one in and before you turn it on, put a 100w light bulb across the terminals where the fuse goes. Pull the fuse out,connect the light bulb across the terminals. Plug the set in, hit the power, if the bulb just flashes and goes dim thats good. Probably no more shorts. If it stays bright then something eles is shorted maybe flyback.
Nov 15, 2009 | RCA Televison & Video
Dell Monitor problem
check the secondary section, something is short. not sure what it is may be 5 volts regulator exceed voltage, EHT transformer drive transistors are short (some used the SMD) or may be the Power supply is not giving proper voltage (not able to take load).
Jan 06, 2008 | Dell E173FP 17" LCD Monitor
Whirlpool Duet HT WFW9200SQ Ser CST50067K7 Power Problem
I have the same problem. Did you ever find the solution to this problem?
Dec 10, 2007 | Whirlpool GHW9200L Front Load Washer
Error code e-3
Mp150 Reset Counter
Service mode operation procedures -
1) With the printer powered off but connected to a power source, press the Power button while pressing and holding
the Stop/ Reset button.
2) When the Power LED is lit, press the Stop/Reset button two times while pressing and holding the Power button.
3) When releasing the Power button and the Stop / Reset button (regardless of order), the printer will move into a
service mode. (Waiting for menu selection)
4) When the LED lights in green, press the Stop/Reset button the specified number of time(s) according to the
function listed in the table below.(Each time the Stop/Reset button is pressed, the LED lights alternately in
orange and green, starting with orange.)
The number of the Reset
button pressing
LED Function Remarks
0 time Green Power off
1 time Orange Service pattern print
2 times Green EEPROM print
3 times Orange EEPROM reset
4 times Green Waste ink counter reset See waste ink counter reset
procedures below.
5 times Orange Destination setting See Destination setting
procedures below.
6 times Green Print head deep cleaning
11 times Orange Button / LCD checking
12 or more times Returns to a menu selection
Oct 02, 2007 | Canon PIXMA MP150 All-In-One InkJet...
Tv was working fine...then shut itself off.
there is no reset button on any tvs that stop in 1980s when they no longer used tubes in chassis,s now the only tube is your picture tube. you probly have a shorted hori out put transistor.
Nov 21, 2006 | RCA F27242GY 27" TV
Black & Decker 19" Electric Lawnhog Mulching Mower Logo
413 people viewed this question
Top Black & Decker Garden Experts
Nick Olsen
Roland W VanLue
Roland W VanLue
Tim Whalen
Are you a Black & Decker Garden Expert? Answer questions, earn points and help others
