Question about White Sewing 1409 Mechanical Sewing Machine
My wife can not get the bobbin in correctly. we
My wife can not get the bobbin in correctly. we have no user manual. Where can we get a user's manual. How can she get the bobbin in correctly?
Go to http://www.singerco.com/accessories/manuals.html and type W1409 in the search box. Download a PDF copy of the manual. :-)
Posted on May 08, 2010
The bobbin thread gets stuck on the bobbin case holder what do I need to do the fix this issue
make sure the thread on the bobbin rolls away from you when you put it in the bobbin holder. insure that the bobbin and bobbin casing are installed correctly.
mike (really by my wife Sandy)
May 28, 2018 | Sewing Machines
When I press the pedal the string get tangled and I also have problems with the bobbin thread not being picked up! Please help! Thanks margaret
thread the machine correctly( follow the operators manual)
wind the bobbin properly and when placing the bobbin in the bobbin carrier pull the thread down the small slot and under the spring plate
thread for the needle always comes in from the left (The side of the groove in the needle ) and out the cut away side
pull a long piece of thread for the needle out and hold it while you turn the machine over
after 1 or 2 revolutions the needle thread will bring up the bobbin thread and you then pull both threads out a bit
if you don't have a user/operators manual there are 2 options
one is to go google and type in --user manual for bernina bernette model 65 sewing machine and down load the pdf version
the other option is to visit manchester shops ( cloth and fabric shops ) and talk with the sales people as may of these places have a sewing circle of people who will be only to willing to help you.
Feb 25, 2016 | Bernina BERNETTE 65 Mechanical Sewing...
How do you install the bobbin for the Singer XL 420 sewing machine?
It is explained and pictured on pages 14 and 15 of your user's manual. If you can't find it, you can download another free from the Singer Sewing Machine site.
There is a drawing on your machine near the bobbin indicating the correct direction the bobbin must be inserted, and it is essential that you put it in that way.
You must also insure that you have the thread in the correct thread path; the bobbin case exerts tension on the thread, but it can't do that unless the case is threaded properly. It is not hard to do, and those pages have illustrations as well.
Your machine does quite a lot, and because of that, there is a learning curve. You will not be able to just turn it on and press the button get good results with it. Use your manual as your BIBLE, and join a user's group. There are several Futura user's groups on FB--I strongly recommend that you join at least one or two.
Jun 26, 2015 | Singer Sewing Machines
How do i retrieve the bobbin thread to the head thread
The first thing you need to do is check with your user's manual on to make sure that your needle is inserted correctly--flat side to the back, and it is all the way UP in the holder. I find a small needle nose pliers helpful to hold the needle for this. If you don't have it, you can download it free at the Singer Sewing machine website--I just did before I answered this.
Next, make sure you have correctly threaded your machine, and when you did so, the presser foot was UP (ALWAYS thread with the presser foot UP--on ANY machine anywhere!).
The next part is on page 20 of your user's manual, and there are drawings. Then, insert your bobbin, with the lever on the case DOWN (it's the only time you can insert and remove a bobbin; with the tab on the case open, the bobbin is locked into place. Make sure the bobbin is inserted the correct way. In your case, when you hold the bobbin up vertically the thread should be unwinding from the left, or clockwise. After you have inserted the bobbin, take a look at the right side of the bobbin case towards the top; you will see a slot the thread needs to go into. Once it's in the slot, hold your finger on the bobbin so it that can't unwind, and pull the thread so that it is in the slot at the top of the shot you put it in. This part exerts tension on the bobbin thread, and it's VERY important that you get it in there. . Then open the tab or lever and put it into the bobbin basket (holds the bobbin case), with the projecting part on the top. A length of bobbin thread should be projecting outside the case at this point--you will be drawing it up to the needle plate.
How, hold the top thread end pull the hand wheel TOWARDS you (ALWAYS towards you--on any machine) at least one revolution and possibly two revolutions, then pull on the top thread and the bobbin thread will come up. When starting to sew on fabric, hold your hand on the top thread for the first two or three stitches.
Dec 18, 2014 | Singer 3116 Simple
How to replace bobbin assembly correctly on my singer merritt 4530 ? the threads been getting caught all around the bobbin assembly.
Yes, it should, and you might want to download your user's manual free at the Singer website, because replacing the bobbin case is pictured there.on page 41, along with instructions.
However, I can tell you that the feed dog plate with the two screws in is DESIGNED to be removed, and must be removed to get the bobbin case back in. It's important that you follow the instructions; the case must be inserted correctly so that it does NOT move, and make sure that it sits evenly in the bobbin basket (the thing that holds the bobbin case. While you are at it, you might want to also clean the basket, using q-tips with a drop of ONLY sewing machine oil on the cotton, making sure you also get under the lip before you put the bobbin case back in.
Jun 11, 2014 | Singer Sewing Machines
How to snap back the bobbin case for a inspirational singer 4206
I'm sorry, but I'm not sure what you want to do with your bobbin case. If you want to put it back or take it out, you must unscrew the two screws that hold the needle plate, remove it, and slip the bobbin case in. Make sure that you put the bobbin case in correctly. It is on page 64 of your User's Manual; if you cannot find your manual, you can download it for free from here. http://www.singerco.com/uploads/download/499_4206_4212.pdf
Jun 08, 2014 | Singer Inspiration 4206
Needle does not reach bobbin to to pull bobbin thread on surface
Sewing machine needles are specific to each model. If the needles are not for your model they could be too short or too thick so that they don't sit in the shank correctly. Check your user manual or Mr Google could help.
Jan 26, 2014 | Brother LX-3125FS 14/35 Stitch Lightweight...
How can I tighten the bobbin tension?
try adjusting the top thread tension
here are some link for a manual
http://www.brother-usa.com/ModelDocuments/Consumer/Users%20Manual/UM_LS_2125_EN_272.PDF
http://www.brother-usa.com/ModelDocuments/Consumer/Users%20Manual/UM_LS_2125i_EN_1628.PDF
Skipped stitches
1. The needle is not inserted correctly
Remove needle & reinsert needle( flat side towards the back of machine)
2. The needle is damaged
replace with new needle
3. The wrong size needle is being used
Choose a needle to suit the thread & fabric
4. The foot not attached correctly
Check & attach correctly
Mar 01, 2013 | Brother LS-2125 Mechanical Sewing Machine
Thread bunches up on Singer HD-110
my wife's hd110 singer machine is not keeping tension. what can I do/ look at to try and help this
Jul 07, 2009 | Singer HD-110 Mechanical Sewing Machine
White Sewing 1409 Mechanical Sewing Machine Logo
202 people viewed this question
Top White Sewing Sewing Machines Experts
Tally Girl
Tally Girl
tsalagi152
Are you a White Sewing Sewing Machine Expert? Answer questions, earn points and help others
