Question about Crunch PZi1000.1 Car Audio Amplifier
Speakers aint hitting????
My amp crunch 1100 is all hooked up right but my subs aint working???wats wrong????????
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 155 Answers
I had the same thing happen to me and turns out my wires on the speaker inside the box popped off. might help
Posted on May 06, 2010
Crunch 2000.4 car amp, need help tuneing
re-check the speaker connections are correct and use a matching ohm test speaker on the other connections for a sound check. Sounds like hi frequency output into the sub amp. Sub-woofers are a mono signal!!
Jul 17, 2017 | Crunch Car Audio & Video
1000 watt amp problem. Speaker + Wire
hey wats up, let me see if i cud help u out here...i will give it a try and use bigger wire, the prob. cud b the wires cnt take pwr thts running through them, but tht cud only b the reason if ur wires are small...other thn tht u cud check 2 see if all ur fuses are correct & thy aint letting 2 much pwr through tht cud the prob as well...let me kno how tht gose & if those dnt wrk there might b sum thing else we cud *** up wit.
Jan 28, 2010 | Car Audio & Video
My friend jus bought 2 10 inch kicker l5s and when we hooked them up to his boss 1100 wat amp and hooked everything up they are moving but are not producing any sound. boss amp i do not know any thinbg...
it must be reversed polarity in coil voices of speakers check + - wires from amplifiers fit on coil voices of speakers try to get each speaker to 8 ohms wiring in serial the two coil voices n'd put in paralel both speakers in bridge mode output from amplifier to get most stable power ,
Nov 04, 2009 | Kicker Solo-Baric L5 Car Subwoofer
No sound
hi there
on your CD deck or what ever unit you plugged the RCA wires to needs to be set on subs the radio needs to be set to put sound to your amp.....on your CD player if you press the F/function button a few times it will scroll to SW which is for the subs set this to the on position or if your CD player has a button with SW press it and turn on this feature......if this has been done......check the fuse or fuses on the amp.......if you have done all of the above check the back of the CD unit to make sure you are plugged into sub-woofer RCA or R (rear) RCA ..........sometimes people accidentally put the RCA wires into the aux input RCA,,,,,, double check this.........
hope this helps
Mar 07, 2009 | Crunch PZi1000.1 Car Audio Amplifier
When i hook up my amp. i have all my wires hooked up right,
this is a signal crash either your speaker wires are crossed (wrong wiring phase) or your RCA jacks need replacing also it could be inside your amp the solder lines may have fused. If after checking and replacing wiring problem persists return to MTX for repair.
Feb 03, 2009 | MTX JackHammer JH202 Car Audio Amplifier
Wiring Diagram
i HAVE 2 12 KICKERS L7 RUNNING ON A PERFORMANCE TECHNIQUE AMP 2000 WATS THE ampl its a mono //and i want to know how to wire the speakers
Jul 26, 2008 | Kicker Solo-Baric L7 S15L72 Car Subwoofer
Ok this problem is killing me...
maybe the speaker is bad
First try one thing, switch the rca jacks around and see if the other speaker stops working this time.
If so the problem is in the rca jack or head unit.
If the same speaker is still not working, the problem will be the speaker, you will have no other options left since you changed amplifiers and checked all wiring.
Let me know if this helps you
Jun 18, 2008 | Visonik Dual Bass Box with Amplifier Car...
No sound?
Check the outputs on the stereo. Maybe there's no audio signal going to the amp.
Mar 24, 2008 | Crunch Powerzone P2200 Car Audio Amplifier
Yeha it help me but my amp aint pushing them good i dont know wat its it my amp or my speakers i just got mje two kicker 10'' cvx wat do u think?
i like rockford fosgate.mtx are strong ,also sound steam make very good speakers for the dollar.i had the old zues 600. the 1st 1.best amp ever made that thing doesnt quit.also most speakers on the market couldn't handle it,except for the 1212 foscates, and i had mtx thunders. broke my window.i haven't really been on the seen .kickers are good but they r not wat they use to be..i asked you oncer wat kind of vehicle u have.for type of encl;osure
i put a small 8 pyle driver sub.w/ small 1000 watt ampsin aseel enclusre in a vw golf. in the car u wooupld ve thought he had 2 12's.wat r u looking for in a sub? want to be heard from blocks awy?
or u want clean .,window breaking sound?
all the spkers you mention and amps should be plenty for any sub enthusiast.enclosure and application isd very imporant ..go to car audio magazine they have a website .they always haave good reviews a testing s on new equipment
Feb 27, 2008 | Audiofonics ADF-272 Car Speaker
Crunch PZi1000.1 Car Audio Amplifier Logo
Top Crunch Car Audio & Video Experts
Steve Sweetleaf
Steve Sweetleaf
Matthew Spark
Matthew Spark
Tygh Duval
Tygh Duval
Are you a Crunch Car Audio and Video Expert? Answer questions, earn points and help others
